An e-bike is going to happen eventually
#251
I do agree with BigAura on one point. There is really no difference between a thumb throttle and a pedal assist (speaking for my torque sensor, not sure how fast a cadence sensor responds).* If I want to take off fast with the flow of traffic when the light changes I just put it in level 4 assist and step on the gas pedal. The bike shoots ahead (as if it had a motor) the same as it would by pressing a thumb switch. Two different switch designs that do the same thing.
All of my riding now is on paved roads or gravel roads open to motor vehicles so I'm not going to join the above debate. I don't like riding on MUPs anyway. The nearest one is 22 miles away and doesn't go anywhere.
Who said that??? An ebike has either a cadence sensor or a torque sensor, not both. Most have a cadence sensor because they're cheaper.
#252
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
That is not true. Bicycles are not only not considered to be motor vehicles, they are not even considered to be vehicles.
Bicycles are exclusively human powered: Law section
Bicycles are not "vehicles": https://leginfo.legislature.ca.gov/f...0.&lawCode=VEH
It's a common misconception though, as we ARE subject to the most of the same laws and have the same responsibilities.
E-bikes are defined as "electric bicycles" (and not bicycles, as they are not exclusively human powered) and fall into 3 classes: Law section
ARTICLE 4. Operation of Bicycles [21200 - 21213]
( Article 4 added by Stats. 1963, Ch. 479. )21200.
(a) (1) A person riding a bicycle or operating a pedicab upon a highway has all the rights and is subject to all the provisions applicable to the driver of a vehicle by this division, including, but not limited to, provisions concerning driving under the influence of alcoholic beverages or drugs, and by Division 10 (commencing with Section 20000), Section 27400, Division 16.7 (commencing with Section 39000), Division 17 (commencing with Section 40000.1), and Division 18 (commencing with Section 42000), except those provisions which by their very nature can have no application.(2) A person operating a bicycle on a Class I bikeway, as defined in subdivision (a) of Section 890.4 of the Streets and Highways Code, has all the rights and is subject to all the provisions applicable to the driver of a vehicle pursuant to Section 20001, except those provisions which by their very nature can have no application.
#253
Seat Sniffer
Quoted: 955 Post(s)
Liked 2,091 Times
This one for example:
https://leginfo.legislature.ca.gov/f...tionNum=21656.
As a bicycle is not a vehicle, we are not required to pull over with 5 more more vehicles are behind us.
#255
Liked 374 Times
Yep. As I indicated, we have all the rights and responsibilities. But a bicycle is not a vehicle under the CVC. It is important, as there are laws in the CVC that do not apply to bicycles to because they are not vehicles.
#257
Liked 374 Times
Unless you have a torque sensor instead of a cadence sensor. My BionX assist is a rear hub drive. Its torque sensor inside the hub senses the amount of tug on the chain. Pedaling speed has nothing to do with it. If I put it in a big gear and push hard the torque sensor tells the motor to push hard and I get a big return for the increased effort. If I shift into a lower gear and spin faster and more lightly the motor backs off .
I do agree with BigAura on one point. There is really no difference between a thumb throttle and a pedal assist. If I want to take off fast with the flow of traffic when the light changes I just put it in level 4 assist and step on the gas pedal. The bike shoots ahead (as if it had a motor) the same as it would by pressing a thumb switch. Two different switch designs that do the same thing.
#258
Yep, because I was explaining a cadence sensor. Which is used on the majority of eBikes.Then you decided to say:
#259
Liked 374 Times
No, you specifically said "how the pedal assist switching system" works. You did not say "one type". It was at best a massive generalization. And torque sensors are on the higher end e-bikes and will show up on cheaper ones as the tech trickles down, as it always does. S0 - your objection to ebikes is about "effort"? Then banning torque sensor bikes would not be okay with you, right? Imo no one has any business policing someone else's effort on a bike - that's their choice and their business. The only justification is if they create a hazard and in that case, just like with autos, the appropriate response is a ticket. It's beautiful out right now so I am off to ride - and whether I take along my motor or not affects no one but me.
#260
Seat Sniffer
Quoted: 955 Post(s)
Liked 2,091 Times
I didn't say bicycles are not subject to the vehicle code. They are. They are just not "vehicles" under the CVC and that IS important for a lot of reasons that have nothing to do with e-bikes ... like the example I posted.
#261
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Your concern about access is.... you don't want ebikes to access your area. That's how I read it.
BigAura has the same vib. He doesn't like em.
Class one ebikes ride just like regular bikes.
There are many more people on push bikes that are even more annoying. Depends on the rider...... it's not the bike.
Likes For trailangel:
#262
Liked 374 Times
You just like to try to create arguments, don't you? IF the throttle is on the bike (which it only is for use on the roadways, not on the pathways) then I can use it to clear an intersection if there is a problem. Just like I don't wear my rear view mirror when riding MUPS but never forget it on the streets...sheesh. My bike is also my "car" and I have chosen different devices for running errands on the street compared to when I ride on MUPS for exercise.
#263
#265
Liked 374 Times
Nope, you got that wrong too. My concern about access is land managers lumping electric motor bicycles in with normal bikes when making access decisions - because electric motor bicycles can be indistinguishable from real bikes.
I think NEMBA has taken a balanced approach:
https://www.nemba.org/news/dealers-g...mountain-bikes
Except for that motor. Having ridden a few, they don't ride just like regular bikes.
#266
Liked 374 Times
I never claimed to be an expert nor did I make a any grand generalization. That’s just you making things up. Again.
My experience is that the electric motor bicycles that I rode did not ride like normal bikes. They made challenging climbs very easy while being porky and not as agile, nor as fun, on the descents.
Again, that’s not a generalization, just specific observations based on my real world experience.
#267
Seat Sniffer
Quoted: 955 Post(s)
Liked 2,091 Times
The CVC is a statute. Its words are not semantics ... they define what the rule of law is when riding on the road.
#268
What I mean is even if you determine a cyclist is not defined as vehicle or consider him a slow boat to China it does not change his rights and privileges and responsibilities.
#269
Seat Sniffer
Quoted: 955 Post(s)
Liked 2,091 Times
But it DOES. In my example, someone piloting a vehicle must pull over if there are more than 5 vehicles behind them and those vehicles are unable to pass. The law does not require a bicycle to do that, because they are not legally defined as vehicles. There are other places in the vehicle code where the distinction is important.
#270
#271
This thread is going to be a HILARIOUS read five years on.
There are only two sectors of bicycling with increasing sales: e-bikes and gravel, and e-bike sales are increasing at a far faster rate. Sales are declining in every other segment. E-bikes will enable bicycle companies to be able to support continued R&D in the other segments even though sales will continue to drop, probably sharply once e-bikes become synonymous with bicycles, and that will be the case in as few as 5 years, maybe 10 at the most.
It's just a waste of breath arguing about semantics, it won't make any difference in the adoption of e-bikes or in the decline of road and mtb sales for that matter.
Likes For radroad:
#273
Quoted: 1976 Post(s)
Liked 2,093 Times
In my experience and locale, legality is irrelevant. Motor bikes (electric and gas) with pedals are used on bike paths and in bike lanes and when I cornered a couple of law enforcement officers about that (one of whom is a cyclist), they informed me that they were given no directives, aside from stop sign infractions, to enforce the relevant laws. What is relevant is that with no experience riding at high speed, someone can use their Master Card and leave the store on a motorbike, get on a bike path, push a lever, and speed amongst, walkers, kids on training wheels, etc.
#274
Liked 374 Times
#275
Non omnino gravis
Alright folks-- cb400bill has been through this thread, Stan has been through this thread, and now I've been through it. That's it. No more. No more quasi-legalese, no more memery, no more nonsense.
It's been moved to e-Bikes, and it won't be cleaned up again. If any more bickering be certain parties occurs in the future (and you absolutely know who you all are) or another report comes in on this one, it's just gonna get locked and sent to oblivion.
Small apology to a handful of posters, some posts got obliterated in the purge that were not in and of themselves offenders, but either quotes or vaguely OT.
To be as absolutely clear as possible: this thread now resides in e-Bikes. If you have ANY issue with e-Bikes, go complain about it elsewhere.
