3D Printed Accessories / Mounts
Old 02-26-16, 03:36 PM
  #251
WheresWaldo
Ride it like you stole it
WheresWaldo's Avatar
Bikes: 2012 Cannondale EVO Ultegra Di2, Pedal Force Aeroblade, Rue Tandem
Quoted: 128 Post(s)
Liked 20 Times in 18 Posts
Cygolite taillight to GoPro Adapter
I am pretty sure this one is the Cygolite and the larger of the two mounts is the Planet Bike Superflash. Took some time to work on this one this afternoon. It should work on most Cygolite blinkies (Hotshot Pro 80 USB, Hotshot 50 USB, Hotshot SL 30 USB)
Works exactly the same as Cygolite's original mounts except this allows you to mount on a GoPro mount, It should provide a few more mounting options. No additional hardware is required. I still have to clean up a few edges and verify all the dimensions are correct.
This will not fit the Micro or Hotrod models.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
WheresWaldo is offline
Old 02-27-16, 07:26 AM
  #252
WheresWaldo
Quoted: 128 Post(s)
Planet Bike to GoPro Adapter
Finished up the Superflash (Planet Bike) GoPro mount adapter this morning. It was too cold to ride. Planet Bike is more standardized than some of the other light manufacturers as this very same bracket is used for every Superflash and the Blinky 3/5/7 taillights. Makes much more sense to me rather than having different mounts for each and every model.
Planet Bike / GoPro Adapter Mount
Will probably take some time this week to make these two mounts available as Fizik ICS and Topeak QuickClip versions.
Old 03-08-16, 07:39 PM
  #253
JonnyHK
JonnyHK's Avatar
Bikes: Baum Romano, Brompton S2, Homemade Bamboo!
Quoted: 474 Post(s)
Liked 204 Times in 129 Posts
Bound to happen, but one of my light mounts designs has been copied by a company who is now selling them.
Not an exact copy, but close enough that (combined with the timing) it is pretty clear that they've seen my design and have worked from there.
Oh well! Lots of happy light owners out there...
JonnyHK is offline
Old 03-09-16, 07:36 AM
  #254
WheresWaldo
Quoted: 128 Post(s)
Sorry to hear this, but especially true if you have something other people find real useful. That was one of the reasons I chose not to publish all my designs on Thingiverse and YouMagine. Not that this would stop someone with a few CAD skills, but it does make it a bit more difficult. The early prototypes that might need a bit of tweaking I have no issues with. Other parts that are more expensive to make for the value they actually provide are also up there. Proprietary designs and ones I have had to reverse engineer will never be up on these repositories. I get requests and sometimes even hateful messages every week about someone wanting the designs for free. I have learned to ignore the hateful ones and politely decline the other requests then move on.
Old 03-09-16, 07:44 AM
  #255
WheresWaldo
Quoted: 128 Post(s)
Fizik ICS to Cygolite Hotshot and Planet Bike Superflash/Blinky Inserts
Been working on two more Fizik ICS inserts. The Cygolite Hotshot and Planet Bike tail lights can now be mounted on the Fizik saddles with ICS just like the Cateye and Fizik tail lights can. Mount the clip on your light the insert it into the ICS slot.
Fizik ICS / Cygolite Hotshot Mount
Fizik ICS / Planet Bike Superflash Adapter
Planet Bike uses the exact same mount for both the Superflash series as well as the Blinky series of tail lights. As a result this works on either. This does mount both tail lights about 1 to 2 mm higher than the comparable Cateye or Fizik, there is still plenty of room and it should not hit the bottom of the saddle regardless of Fizik model. I do like how study the clip is and I wished Fizik would have made the design public (ala Cannondale and the BB30) then we could get away from the weaker Topeak/ProLogo clip. If only I could find a Fizik saddle I would actually ride.
Old 03-15-16, 11:50 AM
  #256
WheresWaldo
Quoted: 128 Post(s)
Custom Garmin Edge Mount
I am sure @JonnyHK will appreciate this.
The following is a result of a dozen emails back and forth as well as outlined dimensions for a custom Garmin mount to fit a very specific setup. Here were the design criteria: Stem faceplate was 44 mm. Handlebars only had 60 mm total space in the center round section. Must fit a Garmin 500/520 just like the Barfly in length. Top of computer could not be above the top surface of the bars. Had to be printable. Took about 10 hours of actual CAD work and rendering and four iterations to get everything correct. The make sure it was printable got me a couple of times.
Overall dimensions are 111 x 60 x 38 mm, the Edge socket is usable in portrait or landscape modes, the socket is 75 mm center-to-center from the handlebars, the clamps are 45 mm inside-to-inside, mount is approximately 25 mm below the top of the handlebars. It uses two M3 x 16 mm bolts with matching nylon insert lock nuts to secure.
Old 03-21-16, 01:09 PM
  #257
WheresWaldo
Quoted: 128 Post(s)
Anyone seen or own a Specialized saddle with SWAT?
I got an interesting request, does anyone here use a Specialized saddle with the SWAT feature? I stopped riding Specialized after I broke three Toupe shells each after just a single year of riding. I never owned one with the SWAT inserts. I also can't find anything other than a couple of bags that use this mounting system. My big questions are what size bolts does it use? What is the center to center dimension of those bolts? What is the profile of the flat area around the bolts? And, is the SWAT mounting plane parallel to the ground when a Specialized saddle is mounted in a typical ride orientation?
Old 03-21-16, 09:25 PM
  #258
cccorlew
Erect member since 1953
cccorlew's Avatar
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times in 21 Posts
WheresWaldo made mounts that I needed and am I ever thrilled. I plan a long blog post, but here's part of the result: I can now mount my SuperFlash (or Cigolite Hotshot, I got that one too) and my Fly6 on my commuter bike rear rack. Killer. Plus, it makes the Fly6 so much more useful. Their mounting solution is not flexible at all. Having the Fly6 on a goPro mount is great.
Rear view 3D printed mounts
by curtis corlew, on Flickr
Side view 3D printed mounts_0029
cccorlew is offline
Old 03-27-16, 04:03 PM
  #259
WheresWaldo
Quoted: 128 Post(s)
I usually don't do a lot of Edge mounts but here is one of my more recent custom requests:
This is what the blue render a few posts up became. I know it's the lighting but it also looks like the color matches, not that we have any control over that.
Old 03-30-16, 11:48 PM
  #260
WheresWaldo
Quoted: 128 Post(s)
Some new stuff per custom requests
Here was another custom request from last week. Picture a K-Edge Garmin XL Combo Mount with 4 devices attached to it. Garmin Edge on top and two lights and a Di2 Junction 'A' box on the bottom. This is what you end up with:
Then how about a Garmin Varia Taillight mounted on a strap that usually sits on the rear of saddle bags, and you get this:
How about someone who wants to mount two Varia Taillights on the back of a Fizik saddle:
It is amazing what people will think of to add to their cycling experience/enjoyment. I could never have come up with all these ideas. Especially since I am content with Action cams and my Garmin Edge. I didn't even know you could pair two Varia's and use them as left/right indicators (or at least that's what I was told).
Old 04-05-16, 09:34 AM
  #261
WheresWaldo
Quoted: 128 Post(s)
A couple of new things this week (per request).
Two mounts for a Garmin Varia taillight to attach to the back of most bicycle racks. As long as the rack has the two mounting holes spaced 50 mm apart center-to-center this will work.
Style 1 centers the Garmin Varia inline with the rack mounting holes.
Garmin Varia Rack Mount - Style 1
Style 2 places the center of the Garmin Varia 17 mm below the rack mounting holes.
Garmin Varia Rack Mount - Style 2
Where did everyone go? I know it is the start of the riding season, but still, there has to be more people doing this kind of stuff. I know @JonnyHK is on business travel, but what about @ItsJustMe and some of the others? I can't be the only one.
Old 04-05-16, 10:53 AM
  #262
JonnyHK
JonnyHK's Avatar
Quoted: 474 Post(s)
Nice mounts!
I'm not just on business travel - I've actually moved continents! All my gear, including my 3d printer, is now in a shipping container and will take some weeks to get here. Then I've got to set it up...
JonnyHK is offline
Old 04-12-16, 12:26 PM
  #263
WheresWaldo
Quoted: 128 Post(s)
I just got a reminder from Shapeways that if you use the following code you can get $10.00 off your first order. The code is jtdg3. To use it you need to follow these directions.
This is how it works:
  1. Invite your friends to follow you on Shapeways.
  2. Which your friends do, because how can they resist seeing all the cool stuff you're doing and sharing?
  3. And, bonus!, they can use promo code: jtdg3 that saves them $10 on their first order placed by 4/15.
  4. You get treated like a hero for introducing them to Shapeways.
I am sure @JonnyHK might have gotten this same email, so maybe he should post his code also. His shop is https://www.shapeways.com/shops/wombats_widget_workshop
There are a growing community of people doing biking accessories on Shapeways, there is a 12 y.o. MTB racer who has designed some saddles and a bunch of others that have Garmin mounts and GoPro mounts. Just check them out.
Here is a guy that has some really neat inserts that mount in the brake bridge hole of a fixed gear; https://www.shapeways.com/shops/fixhole
How about some fancy presta valve caps; https://www.shapeways.com/shops/path...ike+Valves&s=0
Bicycle jewelry; https://www.shapeways.com/shops/velo-fab
Old 04-27-16, 11:58 AM
  #264
WheresWaldo
Quoted: 128 Post(s)
Compact Fly6 GoPro Adapter Mount
At the request of a few people on WeightWeenies, I have modeled a compact version of the Cyclic Fly6 mount.
Cyclic Fly6 Compact GoPro Mount Adapter
I also incorporated a few other improvements, the Fly6 should slide in easier and it will also be easier to remove. Just a reminder to everyone that wants to buy BLACK parts from Shapeways, BLACK is not polished, so it has a slightly fuzzier feel and is a few microns bigger. The polishing process makes it more satin like and removes a minute amount of material in the process.
As always, if anyone has a specific request please feel free to ask and either myself or @JonnyHK or even someone new will see if it is possible.
Old 04-28-16, 01:27 AM
  #265
mathiaspap
Garmin Varia on Specialized Saddle
Hi,
I would like to mount my Garmin Varia rear light onto my S-Works Power Saddle.
On the back and underneath the saddle there are two SWAT mounting screws. Could we use those screws to create a mount for the Garmin Varia?
Thanks so much,
Matthew
mathiaspap is offline
Old 04-28-16, 12:50 PM
  #266
WheresWaldo
Quoted: 128 Post(s)
Originally Posted by mathiaspap
Hi,
Thanks so much,
Matthew
Matt, I sent you a message on Shapeways responding to this. I don't have a Specialized saddle with SWAT, maybe someone else here does. I will try to find one if I can.
Old 04-28-16, 12:57 PM
  #267
mathiaspap
Hey, many thanks
I could provide you with any measurements you may need.
Old 05-01-16, 01:27 PM
  #268
WheresWaldo
Quoted: 128 Post(s)
Lightbulb New revision of Varia Saddlebag Clip, result of direct feedback.
Here is how a community works, I love this, had a couple of people who bought my Garmin Varia Saddlebag Clip and was not happy with it. I asked if we could email back and forth to see what could be done to improve the hold of the clip. One suggestion was to include a larger more pronounced hook end under the bottom of the clip. the other asked for a slot and provided a drawing that I have added here;
It was a great idea to make the clip even more secure. Now you can use a Zip Tie to further fasten the clip to the back strap of a saddle bag. Also, if you need/want to tether the Varia to the clip, there is a small hole for that too.
Garmin Varia Saddle Bag Clip
File Type: jpg
Old 05-13-16, 07:03 AM
  #269
WheresWaldo
Quoted: 128 Post(s)
Just ordered a STIX LED holder for the Specialized SWAT saddle mount. It should be here next week sometime. After that I will be working on Garmin Varia/Edge, GoPro and even Fly6 mounts that directly mount to select Specialized saddles that have the SWAT feature. I will probably try to fit Planet Bike and HotShot taillights too. Stay tuned.
I hate the way Specialized does their online stuff. I don't mind going to the shop, although it is quite a ways from my home, all in traffic. I don't like that I can't order online for shop pickup. That means two round trips to the shop for a $5.00 part.
Old 05-19-16, 11:04 AM
  #270
WheresWaldo
Quoted: 128 Post(s)
I will pick up the Specialized SWAT mount this weekend, and should have the first adapters by next week. If there is anything you guys/gals want to see first now is the time to speak up.
I am completely redesigning the Fizik ICS mount. The current design is overly complicated and flimsy, this new design should be more robust and I hope it may end up being cheaper to print also. Just let me know if you want to test the new design.
Where did @JonnyHK go? His move should be complete by now and I haven't seen any new activity in his Shapeways shop.
Old 05-19-16, 11:40 PM
  #271
JonnyHK
JonnyHK's Avatar
Quoted: 474 Post(s)
Still alive!
Very busy with new job and my move is anything but complete. Our shipment was held up, so none of our stuff has arrived yet. It will be over a month late. I don't suppose you need me to tell you how unhappy my wife is!
- Have been sketching some non-cycling ideas (rowing)
- Working with a guy who used to do a lot of injection moulding tool design
- Did a couple very small updates to products
Will be interested to see your Fizik mount. It is an odd beast to model and have work reliably.
JonnyHK is offline
Old 05-20-16, 04:41 AM
  #272
WheresWaldo
Quoted: 128 Post(s)
@JonnyHK I sent you an email to the sub-section.
Old 05-22-16, 02:25 PM
  #273
WheresWaldo
Quoted: 128 Post(s)
Specialized SWAT Adapters and redesigned Fizik ICS Clips
Been working on SWAT this weekend and here is the first item I have completed.
Uses 2 M5 x 10 mm pan head bolts to hold it on to the saddle. Even though I don't ride Specialized saddles anymore, I really think they got this one right. Much more secure than anything that snaps into the saddle. Also not nearly as dependent on manufacturing tolerances. This is what Fizik ICS and Toprak Quick-Clip should have been.
I also have finalized a redesign of the Fizik ICS clip and the first model finished is this GoPro mount using the new clip design.
File Type: jpg
Old 05-26-16, 08:33 AM
  #274
WheresWaldo
Quoted: 128 Post(s)
Matt,
I completed work on a Specialized SWAT / Varia Adapter, it isn't for sale yet I am waiting on some feedback on the SWAT section of the mount. Hopefully soon.
This will also work for track riders that use Specialized saddles and want to mount a Garmin Edge device on their bikes (where handlebar mounting is prohibited).
Hey, many thanks
Old 05-26-16, 09:30 AM
  #275
mathiaspap
Perfect, please keep me posted.
Thanks
