Totally Tubular
#2701
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1303 Post(s)
Liked 958 Times
There are 3 options:
1. Pre-emptory sealant... the way tubeless tire riders do it. Statistically works pretty well but you never know if you would've flatted or not without it unless you pull out a goat head or something and watch it work... so most people pack a spare tire anyway. With smaller road tires though, you might lose enough air before the plug happens that you have to press the tire up again even if the sealant does work.
2. Repair sealant... keep a bottle in your pocket and after you flat on the road, inject the sealant and hope it works. It reportedly does work often enough that people find it worth trying... not well enough that people don't pack a spare tire also. Before sealants got as good as they are now, people would sometimes bring something like Vittoria Pitt Stop that had sealant and pressurized air in the same can... I estimate that has about a 50% chance of working.
3. Both
Summary: if you have a flat on the road and you're not in a hurry and you want to avoid swapping on your spare and throwing away the flatted one... worth a shot to try and seal it in place.
You need a spare anyway because some flats are absolutely unsealable, and success with the easier punctures isn't guaranteed.
3. Both
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Likes For 1989Pre:
#2702
Standard Member
Liked 958 Times
I also use their glue or mastic remover, when cleaning old, glue laden rims, back to their original condition.
#2703
Quoted: 253 Post(s)
Liked 223 Times
Extremely valuable information for me., Thanks. Primarily because I do not carry a cell-phone and I might be walking back home 30 miles in vintage cycling shoes, although the people around here are really nice and will usually collect any cyclist in trouble. I can't take any chances: I'm bringing an extra and leaving this bottle at home.
Likes For Positron400:
#2704
Standard Member
Liked 958 Times
"Pre-glued"?! I was hoping I could just put the spare on there and use the glue that was already on the rim. Maybe not. Maybe put glue on the tire when and where you puncture?
#2705
If I own it, I ride it
Quoted: 594 Post(s)
Liked 666 Times
For tape...IME some of the tape may stick to the tire, some to the rim, or all on the tire. Never had one that all the tape stuck to the rim. I carry a small piece of stiff sheet plastic with tape wrapped on it to use on the road. Also have a small sharp knife to cut tape as needed.
Likes For CV-6:
#2706
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3314 Post(s)
Liked 1,922 Times
Yes you do. The latex compound with the particles clogs up any would-be-punctures and only minimal air should escape.
Regarding the valve core, that is up to you really. If you remove the valve core, all the air will be let out anyways. So you can either deflate it beforehand, or just remove the valve core right away.
I think the amount of sealant is also dependent on the size of the tire. Stan's might have a reccomendation, but imma say go with 40 mL (since i presume you run a 25 mm tire at most)
Likes For seedsbelize2:
#2707
Liked 1,922 Times
#2708
Liked 1,922 Times
An unglued tire might hold okay. Putting glue on at the time is an iffy proposition. Easier to pre-glue a tire and then you have a better chance on holding and spend less time at the side of the road.
#2709
Freewheel Medic
Quoted: 1476 Post(s)
Liked 2,250 Times
The rim, definitely. The side-wall, my guess would be, yes. However, I've never had to use it this way. It is very VOC friendly, and barely has a smell that I notice. Also, Mrs. PB never complains when I use it in the garage. It would be worth the try.
Bob
Bob
Likes For pastorbobnlnh:
#2710
Standard Member
Liked 958 Times
How does one carry a pre-glued tire without reducing the glue's effectiveness and/or making a mess?
#2711
Standard Member
Liked 958 Times
I didn't get much glue on the brake-track of the rim(s). The side-walls of the tires is another story.
#2712
Bikes: 1980 Dawes Super Galaxy + 1981 Lotus Classique + 1986 Bianchi Sport SX + 2005 Van Dessel Project WR + 2021 Zizzo Liberté
Quoted: 148 Post(s)
Liked 489 Times
Back to this post from a week ago--unfortunately Velosaloon informed me that they can't ship Conti cement to the US because USPS bans flammable items in the mail. They refunded that portion of my payment. Fair enough.
What's not cool is that I put in the order on Tuesday 2/28 but didn't hear back, except for the automated confirmation email, until I enquired by email a week later about the status of my shipment. So today I get a response that the package, minus the can of glue, supposedly went out on Friday 3/3, but the refund didn't happen until today. This is seriously backwards. I can live with their system not flagging the cement as not shippable to the US from the start, but then I need to be informed, and my money refunded, as soon as they do notice. I've made it clear that I'm not a happy customer. In German
#2713
Quoted: 594 Post(s)
Liked 666 Times
Likes For CV-6:
#2714
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 282 Post(s)
Liked 989 Times
3. Both
3. Both
My rule of thumb is that if I didn't have an immediate pressure loss (think large hole), I will apply sealant, inflate and go. I've learned the hard way (repeatedly) that adding sealant when there is a big hole is a recipe for mess, so I just put on my spare.
Likes For SwimmerMike:
#2715
Quoted: 148 Post(s)
Liked 489 Times
So, back to square one in my quest for glue. To recap, I snagged a pair of Sprinter Gatorskins when they were briefly priced at $17 ea. or whatever it was, and they're going on the bike I'm building to try track riding/racing up in Londonderry, NH. It's a bumpy old outdoor track with wide, modestly banked turns, and I'm a spaghetti-legged almost 56 year old who's never done any racing before. Still, I would prefer glue over tape just for the peace of mind on a hot summer race day.
I guess for just these two tires, 2x25g Continental in tubes would do? Those are still easily found here in the US, looks like around $16 shipped give or take. Or does anybody have experience with Specialized? $28.99 for 120g, shipped.
ETA link: https://www.specialized.com/us/en/tu...Text=0332-0100
That sounds an awful lot like Continental, doesn't it? And says Made in Germany on the can. Same formula for carbon and alu, though.
I searched the thread but only found Specialized tires, not glue. Looks like last year around this time they were selling off track tires at $29 each, dang.
Derived from the most used and proven European recipe that has carried rubber on wheels for the Pro Peloton for decades.
#2716
Quoted: 148 Post(s)
Liked 489 Times
Might as well add that Specialized only has three tubular tires left in their line-up, two of which are on sale for $75 instead of $100. Looks to me like they're getting out of the segment.
https://www.specialized.com/us/en/sh...r:type:Tubular
#2717
Standard Member
Liked 958 Times
#2718
Quoted: 594 Post(s)
Liked 666 Times
#2719
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4381 Post(s)
Liked 3,047 Times
But the full version is HERE ... created 25 years ago!
Bringing a roll of tubular glue-tape along on every ride seems ridiculous.
Other bike riders see this and are either completely baffled, or immediately recognize sew-up tifoso.
The Hell of the North is a great tire
Likes For DiabloScott:
#2720
Quoted: 2395 Post(s)
Liked 2,951 Times
Been there, done that, nearly lost an eye
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
#2721
Freewheel Medic
Liked 2,250 Times
Bob
Bob
#2722
Quoted: 1976 Post(s)
Liked 2,094 Times
I don't like to fold the tire with the tape against tape on pre-glued tires because it puts too much stress on the base tape when I separate it.
Likes For Classtime:
#2723
Quoted: 594 Post(s)
Liked 666 Times
Get around that concern by using fingers or similar to spread it apart. Don't try to pull it apart.
Likes For CV-6:
#2724
Liked 1,922 Times
My objective of having the internet's #1 tutorial resource for folding spare sew-ups gains momentum whenever someone links to it.
Definitely not - changing a tubular with a pre-glued spare is fairly quick and easy - weather conditions can complicate it somewhat just like any other roadside repair.
I bought a pair of these last year but they're still unused because I love my Vittoria Pave's and they just won't wear out.
#2725
Quoted: 4884 Post(s)
Liked 4,049 Times
[QUOTE=DiabloScott;22822007]There are 3 options:
3. Both
You need a spare anyway because some flats are absolutely unsealable, and success with the easier punctures isn't guaranteed.[/QUOTE]
And it's a very good bet no one is going to happen to be carrying a spare. And sadly, there's no way to get a clincher of any sort on to get you home. (Unlike the reverse. If we carry a spare, anyone with a 700c wheel can roll home on it.) Now, 50 years ago it might have been a long wait for another rider but he probably had a spare.
3. Both
Likes For 79pmooney:
