What did you just buy for your gravel bike?
Old 08-08-18, 11:53 AM
  #251
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Isadore Signature, wool/poly/lycra blend, $75 at Wiggle.
Looking forward to some cooler fall gravel rides.
TimothyH is offline
Old 08-08-18, 12:37 PM
  #252
taz777
taz777's Avatar
Bikes: 5
Liked 25 Times in 19 Posts
Treated my gravel bike to a D-Fly, a Shimano EW-WU101 Wireless Unit for Di2, for wireless comms paired to my iPhone/iPad and also my Garmin Edge 1000.
Works great with the Shimano E-Tube app on iPhone/iPad for configuration, firmware updates and diagnostics, and with the Garmin for additional Di2 data fields.
taz777 is offline
Old 08-08-18, 05:33 PM
  #253
jbell_64
Bikes: Trek fx 7.2, Raleigh Tamland
Quoted: 66 Post(s)
Liked 11 Times in 10 Posts
New set of hunt gravel disc wheels since the hubs in my factory tamland wheels are crap after less than. 1000 miles....
jbell_64 is offline
Old 08-10-18, 12:27 PM
  #254
taz777
taz777's Avatar
Bikes: 5
Upgraded the stock saddle, which wasn't that bad, but I've had good experiences with Specialized saddles. I have the Phenom Expert on two bikes already, but decided to go with a Specialized Romin Evo Expert Gel saddle for the gravel bike.
I usually get 143mm Specialized saddles, but went for a 155mm one to see if it feels better. I read a lot of reviews before deciding to get the next size up for the Romin.
taz777 is offline
Likes For taz777:
Old 08-13-18, 12:49 PM
  #255
pennpaul
Bikes: Diamondback Haanjo Trail, Fuji Team Road
Quoted: 160 Post(s)
Liked 68 Times in 46 Posts
For my DB Haanjo I got a Redshift stem last month (so nice) and now I'm working on a new Amazon cart with some lights and tube sealant. I've patched 3 tubes in 10 rides from thorns.
pennpaul is offline
Old 08-13-18, 01:57 PM
  #256
pamcinto
Motobecance WhipShot Ti
Just bought, assembled, tuned and got my first ride with this bad boy.FrameCycloCross Disc Brake 700C Butted / Multi-shaped Advanced Heat Treated 3/2.5 Titanium, 2xH2O mounts, Wide Tires Fit, 68mm threaded BB Shell, Headtube TITANIUM UPPER 1-1/8"/LOWER 1.5" TAPER (46x42/55x52.1mm) L: 50/53/55/58/61CM=125/145/160/180/200mm, DROPOUTS(DO) TITANIUM VERTICAL W/REPLACEABLE HANGER, W/FLAT DISC MOUNT . O.L.N: (142MM THRU-AXLE Equipped) Rear rack brazeons.ForkCARBON ( UD WEAVE ) BLADE 700C, Steerer: CARBON 1-1/8" to 1.5" Taper ( I.D.:23.6) CROWN: 57mm, BLADE: CARBON STRAIGHT ( 25.7x56.9mm ) W/FLAT DISC MOUNT FOR 160 ROTOR .W/45mm OFFSET W/FORGED DROPOUTS,12mm THROUGH HOLE /M12xP1.5, Customers report Fork Fits most tires up to 700x40c (29x1.6in)CranksetSRAM FORCE1 24MM XSYNC 42T Carbon Crank 170/172.5/175mm for 50-53/ 55 /58-61CMBottom BracketSRAM BB GXP XR ROAD68/WIDE AXLE73PedalsRC-713 ALLOY POWDER COAT BLK ROAD PEDAL W/9/16" CNC CRMO AXLEFront Derailleurn/aRear DerailleurSRAM FORCE1 LONG CAGE ( Max tooth : 42T )ShiftersSRAM Shifter/Brake Force Hydraulic, rear caliper, right control, rear shifter, 20mm Flat MountCassette/FreewheelSRAM PG 1170 11-36TChainSRAM PC1170 110 LINKS WITH POWER LOCK 11 SPEEDWheelsetDT SWISS C 1800 SPLINE db 23 " WHEELSET, 700C ALLOY BLACK ANOD. SLEEVED TUBLESS READY W/FV
SPOKE DT SWISS STRAIGHTPULL NEW AERO & AERO COMP, BLACK, F/R: 24/24PCS S.S. 2 CROSS W/DT ALUMINUM NIPPLES
F/HUB DT SWISS SPLINE ALLOY ROAD BLACK db HUB 24H. ( CENTER LOCK ) OL: 12x100MM, F/HUB THROUGHAXLE QR264F 12mm, ANODIZED BLACK, L:M12xP1.5x118.5mm
R/HUB DT SWISS SPLINE ALLOY ROAD BLACK db HUB 24H. ( CENTER LOCK ) W/ 3 PAWL SYSTEM , OL: 12x142MM, COMPATIBLE SRAM 11-SPD, R/HUB THROUGHAXLE QR269R 12mm, ANODIZED BLACK, L:M12xP1.75x174mm
TiresCHALLENGE GRIFO RACE 700X33C, 120tpi , FOLDABLE, BLACKBrakesF/BRAKE SRAM DB Force Hydraulic Disc CX1, front caliper, left control, 20mm Flat Mount W/FLAT DISC MOUNT
R/BRAKE SRAM INCLUDING IN SB-Force-HydraulicRoadDisc-A1 Shifters/ Hydraulic Disc Brake
ROTOR SRAM CENTERLINE 160 ROUNDHandlebarRITCHEY ROAD WCS EVOCURVE Alloy 7050 D.B. BUTTED B/CENTER:31.8mm 400/420/440mm FOR 50-53/ 55 /58-61CM, D/R:128/83mm, BB BLKStem/ HeadsetRITCHEY WCS C-220 84/6D ALLOY 3D Forged ALU2014 / SS Bolts. EXT-6°)70/80/90mm FOR 50-53/55 /58-61CM, C/S:31.8/28.6x42mm, BB BLKTape/GripMotobecane Black Gel EVA Synthetic CorkSaddleWTB SL8 127x263, Nylon Fiber Base, CroMoly Rail, Microfiber Cover, DNA Super Light PaddingSeat PostRITCHEY WCS 1B 20mm offset 6061 ALLOY BB BLK, 27.2 X 350MMSeat ClampAluminum with bolt
pamcinto is offline
Old 08-13-18, 04:31 PM
  #257
bsandovalb
bsandovalb's Avatar
Bikes: litespeed pisgah single speed, niner rlt-9, yuba sweet curry with family kit
Just put a brooks saddle, panaracer gravel kings in 700x40 and a lauf grit to my niner rlt-9.... its like a new bike, loving it!
bsandovalb is offline
Old 08-14-18, 02:18 PM
  #258
taz777
taz777's Avatar
Bikes: 5
Trying out a Fizik Aliante R3 Open saddle in regular width and the limited edition white colour on my gravel bike. Feels good, but it's very early days.
taz777 is offline
Old 08-14-18, 02:33 PM
  #259
redlude97
Quoted: 1975 Post(s)
Liked 232 Times in 173 Posts
seems pretty angled down for an aliante, they are meant to be ridden slightly nose up
redlude97 is offline
Old 08-14-18, 02:41 PM
  #260
taz777
taz777's Avatar
Bikes: 5
That's what I thought too! That is until I found this video by the Fizik product manager that seemed to show quite an interesting way to level the Aliante saddle:
Aliante levelling is at the 2:33 mark. I tried to follow that but then did my own thing!
taz777 is offline
Old 08-15-18, 01:24 PM
  #261
taz777
taz777's Avatar
Bikes: 5
I fixed the saddle angle today and got some supplies for my tool bottle toolkit.
Patch kit, missing link, multitool, pump, tyre levers, chain hook all to go in a Vittoria tool bottle.
I was a bit disappointed with the quality of the Vittoria tool bottle as I have another one from a few years ago which is of much higher quality. The one I received today is very thin and flimsy and deforms easily when I put it into the bottle cage. I may end up getting a plastic tool bottle that isn't so soft.
The multitool is a Crank Brothers F15, the patch kit is a Lezyne Smart Kit, the tyre levers are Silca ones that are supposed to work well with carbon rims, and the pump is a Zefal Air Profil Micro Mini Road Pump.
I've got a few more bits to get before the toolkit is complete (CO2 inflator, CO2 cartridges and inner tubes).
taz777 is offline
Old 08-15-18, 03:12 PM
  #262
EpicTwiglet
Quoted: 12 Post(s)
Loving my Gravel King 32mms. Fast and tough enough for light off roading. Perfect go anywhere tires.
Beware, with Bontrager TLR rims they are INCREDIBLY tough to get on and off. I pinched 3 tubes, bike shop 2.
EpicTwiglet is offline
Old 08-15-18, 03:32 PM
  #263
redlude97
why aren't you running them tubeless
Old 08-15-18, 06:02 PM
  #264
Jakedatc
Jakedatc's Avatar
Liked 10 Times in 7 Posts
I have this one and has a pretty rugged outside and nice pockets inside . Fits snug in my bottle cage
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Jakedatc is offline
Old 08-15-18, 10:08 PM
  #265
taz777
taz777's Avatar
Bikes: 5
@Jakedatc - thanks for that link. I’ll try to locate one in the UK. The Vittoria one that I received must be a new design. Whilst very light, it’s too flimsy.
taz777 is offline
Old 08-16-18, 06:45 AM
  #266
McMitchell
Bikes: Focus Mares CX, Rocky Moutain Sherpa
Quoted: 76 Post(s)
Last year I upgraded my Rocky MTN, Sherpa to a SRAM 1X 11 speed. I have steep hills outside my new backdoor in North, GA. My Focus Mares CX with Shimano 105 (46/36t front, 11-28t rear) was a royal pain to get up all the hills. The roads are sort of paved with a great deal of loose gravel on them, which can result in skids on the turns. Based on the fact that my 27.5+ MTB with the 1X (32t x 10-42t) was making the hills without issues I decided to upgrade the Focus bike as well. We were able to get 700-40c WTB Nano tires on it with good clerance. Went with Stan’s Grail rims so I could go tubless. The original rims now have Continental 28mm tires, for regular paved roads and hard packed gravel...
I read some very good reports on the new SRAM GX Eagle 12 speed group sets. I decided to convert the Focus bike to the newer technology. North, GA trails and gravel roads can be very steep and technical. I thought I might enjoy a bike geared even lower than the MTB. At age 69 I am not interested in riding fast anyway. I may end up with a 30t chain ring on the MTB. I measue about 5’ 7.5” with a 30-31 inseam, and a 32-33 sleeve. Now I am in the process of getting all the Eagle components put on the bike. I have tools but not every thing I would need to do this job, so the bike is at my local REI. I decided to go with a carbon riser handlebar as my hands and arms were occasionally going numb from the constant vibration on my local roads. I was also interested in trying out SRAM grip shifters. Sometimes it is nice to be able to shift through a bunch of gears rapidly, which I think the grip shifters will allow for.
Now I am working on a better saddle and double water bottle holder. I think I will end up with a bike that will be good on my local technical gravel roads and trails.
McMitchell is offline
Old 08-16-18, 09:23 PM
  #267
Jakedatc
Jakedatc's Avatar
Oh and i got some rotor shims to make my 2nd set of wheels fit without having to adjust the calipers (will come in handy if i need a pit wheel or swap tire tread for CX) . And ordered some new rim tape so I can put my chunky BOS tires on one set for CX grip
Jakedatc is offline
Old 08-16-18, 09:28 PM
  #268
EpicTwiglet
Quoted: 12 Post(s)
Here is my first "Gravel" bike. Loving it.
Old 08-20-18, 05:38 AM
  #269
taz777
taz777's Avatar
Bikes: 5
I finally got round to using the Zefal Air Profil Micro Mini Road Pump and Silca Premio tyre levers.
The levers are fine for the job and the pump worked surprisingly well, despite a few negative reviews on the Internet. You do need quite a bit of stamina to pump up your tyres to a rideable pressure but the trade-off is the very compact size and stealth looks when using the supplied bottle cage mount.
It's hardly noticeable against the bike's black frame and sits neatly tucked away.
taz777 is offline
Old 08-20-18, 07:25 PM
  #270
DarKris
DarKris's Avatar
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times in 54 Posts
Placed an order for Spesh Hover Flare Drop Bars in 46cm width for my Giant Toughroad GX. Using the rise as a replacement for my 20 degree rise stem So I can go back to my 8 degree stem. Plus the drops are shallower so I can use them more often.
DarKris is offline
Old 08-21-18, 06:21 PM
  #271
3speedslow
3speedslow's Avatar
Bikes: A few
Quoted: 1952 Post(s)
Liked 1,117 Times in 655 Posts
^^^Whoa, what outfit carries those? Mind telling what they set you back?
3speedslow is offline
Old 08-25-18, 01:51 AM
  #272
tangerineowl
Bikes: Curve Grovel v2 ti
Quoted: 257 Post(s)
Liked 91 Times in 75 Posts
The plan today was to drop by the Spec store on my ride; see if they had some long finger black Grail gloves to replace my worn out pair.
They did, so that was a bonus, as I really like them to keep the sun off during the warmer months.
However I've been wanting to replace my road shoes as they've been getting a hammering on the gravel rides, and I've had it with my flexy soled hike-a-bike other set.
Had narrowed it down to a Lake model due to the wide front, but in the store was the last size of a Spec S-Works mtb shoe on discount by a couple of hundred.
Nice wide front so I had to try it on.
and that was the end of that. My wallet took a big hit. Now I've got to sell off some wheels or something to justify the purchase!
tangerineowl is offline
Old 09-18-18, 06:37 AM
  #273
medic75
medic75's Avatar
Bikes: '19 Trek Stache 5, '17 DB Hannjo Trail, '09 Scott CR1 Pro, Schwinn Central commuter, '16 DB El Oso
Quoted: 108 Post(s)
Liked 57 Times in 29 Posts
Not judging, but what's up with that saddle angle? My bike came with a somewhat downward slope on the saddle and I tried it for 2 days - didn't work for me.
medic75 is offline
Old 09-18-18, 06:42 AM
  #274
Colnago Mixte
Quoted: 897 Post(s)
Liked 9 Times in 8 Posts
Dead level will always be most comfortable,IMO, but I see a lot of bikes here that don't follow that rule, for whatever reason.
I see it a lot on used bikes, and I always imagine the owner thought the bike was a POS simply because the seat was adjusted wrong and they couldn't get comfortable. I like seeing used bikes that are hopelessly out of adjustment, because you know the seller will be a motivated one.
Colnago Mixte is offline
Old 09-18-18, 08:29 AM
  #275
Metieval
Metieval's Avatar
Quoted: 1218 Post(s)
Liked 298 Times in 214 Posts
any feedback on this?
Metieval is offline
