Post your utility bike thread
#376
Utilitarian Boy
Bikes: Check the sig to find out
2 of the same frames, but different purposes. Btw Crosschecks can fit schwalbe big apples!
For hauling and road biking (with a tire swap)
taking the new frame to get set up
For commuting and all weather (making mudflaps are fun). It's set up as a fixed gear in both versions
#379
Fred Wannabe
Bikes: 2008 Rocky Mountain - Sherpa 30 ** 1990 Diamondback - Apex ** 199? Fixed Gear Frankenbike
Bikes: Takara with Suntour 6-speed groupset, early 80s; Schwinn 21-speed mountain bike
Bikes: Raleigh 3 speed
...and band type hose clamps, found in automobile supply stores and hardware stores (since they are also used for in-ground lawn sprinkler connections). Because of the hex-head screws they can be made incredibly tight. (It would be easy to break a plastic "milk crate", so watch it.) They are stainless steel, so won't rust. If you need some "grip" so the clamp doesn't slide, or something to fill the slack, cut some rubber from a tire tube and put it under the the clamp.
By the way, those plastic ties broke the first time my bike fell. (Actually I put them as additions as a sort of field test. I didn't think they were as fragile as they turned out to be though.) Maybe some huge ties like they use on trailers would be reliable, I don't know.
The band clamps, being slightly stiff, relax over the months as they gradually adapt to the shape of what they are wrapped around, becoming loose, so it is good to put something with a little give (such as plastic) under them. The plastic expands a little as the pressure eases, keeping the bands tighter longer. Although rubber is good for grip, it squishes a little too easy to get things really tight (if you need it that tight).
Other clamps I know about are in the electrical department. They have some C-type wrap-around clamps with an integral plastic/rubber insert.
There are iron pipe-hanger brackets in the plumbing department. These are the kind that are about 1/2 wide, not the kind that look like wire clothes-hangers. They are used to anchor pipes to joists in basements. They have holes to be nailed to the joists, and the holes can be used for your screws. They come in all sorts of sizes and are dirt cheap. You would have to bend them to wrap all the way around a frame or rack. They are pretty stiff (which is good) but not so stiff you can't bend them with pliers.
#384
Bikes: Batavus Old Dutch
I'm not done coating her handlebars...
Batavus Old Dutch traditional omafiet.
Everything is mostly stock except for the grips and the brooks.
It's considered a woman's frame but I'm comfortable enough to sport her, and I love look and the easy dismounts of loop frames.
#386
Formerly Gordo Grande
I commented over in Classic & Vintage, but I'll say it here too. That bike is beautiful! I could just sit and look at it all day!
#387
Señor Member
Bikes: Ti Fatback
All of these are really swell-looking setups...I'm back on the hunt for a road bike...possible an LHT or Cross Check...just can't decide which one...
......_ .
O/---\/O
......_ .
O/---\/O
#388
xtrajack
Bikes: Kona fire mountain/xtracycle,Univega landrover fs,Nishiki custom sport Ross professional super gran tour Schwinn Mesa (future Xtracycle donor bike)
Here's me and mine
Latest version
Latest version
#389
Bikes: rockhopper, delta V, cannondale H300, Marin Mill Valley
Liked 5 Times
Very nice except the MagLite. A ulock is almost as good for bludgening and also secures your parked bike. Combining weapon and illumination makes less sense. Stick with the excellent bike lights available today. Just a suggestion. Keep that light saber handy for when your wife hears a noise downstairs.
#390
xtrajack
I hadn't thought of bludgeoning anyone with it,now that you mention it I suppose that it would make a fair club.
I did have a $150 12 watt light purchased from the LBS should have been good, right? Problem was that it threw light everywhere and the battery didn't even last a six mile trip to work. I already owned the three Mag-lites that I am using for a light system; 2 three cell, 3 watt mini-mags mounted low on the lowrider rack for close road definition, The large 4 D cell,3 watt gives good distance illumination. I also use a 3 watt light on my helmet. I still have 12 watts of light,just in a more usable manner. I also epoxied a Blackburn light to the big Mag Lite for a "see me" light.
#391
Liked 5 Times
Yeah, I was trying to be funny. That's what police use them for, I don't think they carry billy clubs anymore.
Many years ago I used a mini MagLite. The idea that this would work as a headlight was put in my head by the fact that a clamp was being marketed at that time for mounting mini MagLite on handlebars. When it failed to provide sufficient light, I hose clamped a 3 cell unit next to it.
I replaced that set-up with a $200 NightSun system that was state of the art at that time, but yeah, short run time as well as heavy, probably heavier than the MagLites.
Whatever works for you, I just didn't think you needed that extra weight. I know you aren't worried about weight too much, but the lights today are bright, light and cheap. I'm using a ~$30 headlight that has an array of eight LEDs and uses 3 AAA batteries.
The new NiMH rechargeable batteries work better than disposables which was a delightful discovery for me. They last a lot longer than Duracells, plus you can use them again. Sweet.
I don't know that my light would work in the Maine woods. You probably need more light than I do.
#392
gridlock junky
Bikes: 1944 JC Higgens Cruiser, 1988 Univega Aero Speed, 1993 GT Ricochet, 2005 Electra Cruiser, 2006 Cervelo Dual, 2007 IRO Mark V
mixte / cargo
frame/fork: AMF Roadmaster Nimble, beat to hell and heavy as BRICKS
rear wheel: J.C. Higgins 26″ rim/coaster hub w/1.5″ Specialized Armadillo Nimbus & Mr. TUFFY
brake arm: J. C. Higgins, this is real nice old school QUALITY
cog: J.C. Higgins 1″ pitch, crazy nice, but HEAVY
front wheel: 700c Vuelta mach. rim/Formula hub w/25mm Kenda & Mr. Tuffy - LIGHT and MODERN!
crank/bb: JC Higgins 1″ pitch, from another dimension, WTF, need to machine down to newer standard.
chain: J.C. Higgins 1″ pitch, from another dimension, TOUGH
stem: AMF quill riser, stamped trash
handlebars: AMF townie bars, OK
brake/lever: AMF, ? grip is stamped on LOL
seat post: J.C. Higgins 13/16″, trash
seat post collar: AMF, stamped, WEAK
seat: Electra, USED
pedals: AMF, actually… these are light and spin OK i like em.
grips: AMF, like first tricycle LOL
paint: rustoleum, can, easy cleanup
fenders: AMF, nice, but short
chain guard: AMF, its nice
rear rack: Topeak, way overbuilt, cheap, weird
rear baskets: Wald, used
front rack: diy milk crate, fun
bell: i love my bike, more fun!
more info:
https://www.jeremygrant.com/blog/?p=806
before:
idea:
romantic video:
https://www.youtube.com/watch?v=fhLss9-dTjg
birthday party haul:
#393
Big Doofus
Bikes: Trek 830 MTB, Fuji S10-S
Here's the (likely)final version of mine. I bought the bike itself last spring at Goodwill for $8. It's a Redline Conquest 2 from '88 or '89. Wheelst's from a GT Tequesta that met a bad end; fenders and brakes came off my old Trek 830; handlebars are from my Bridgestone CB-2, which is getting the MTB treatment for son #2; L-brackets are from my local Tru-Value store. Not shown: trailer hitch on left rear axle.
#394
Bikes: Ahearne CycleTruck, Marin Pine Mnt. Surly LHT,Spot SS MTB, Windcheetah trike
Quoted: 8 Post(s)
Here is a shot of my recently completed CETMA Cargo.
#395
Bikes: Miyata TripleCross
Here's my grocery getter. A Miyata Triple-cross with riser bars for a more upright riding position. And my recently completed, homemade CETMA-style front rack.
And with the attached grocery basket.
#397
I got the general idea from here.
My rack uses a different method for attaching to the bars, mainly because of the geometry of my bike.
It's also made of aluminum instead of steel and most of the joints are glued as well as bolted.
I've been hauling quite a lot of stuff over the last couple of weeks and it hasn't shown any signs of disintegrating, yet .
If you'd like some more detailed pictures just ask.
#398
Bikes: Assorted brand, model, & type
Bridgestone Utility Bicycle
Bridgestone Utility Bicycle after restoration. Newly painted and chromed carrier. Umbrella holder and stainless steel spokes installed.
Combo Stand
Carrier folded
Carrier expanded
Combo Stand
Carrier folded
Carrier expanded
#399
Bicycle Repair Man !!!
My home built longbike... I can toss 100 pounds of gear on this bike and not even know it's there.
#400
