ISO and for trade thread part 5
#403
Quoted: 7408 Post(s)
Liked 2,601 Times
#404
tantum vehi
Quoted: 1171 Post(s)
Liked 999 Times
Then you are using STI?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#405
aka: Dr. Cannondale
Quoted: 2175 Post(s)
Liked 3,532 Times
Nonononononono
Road and MTB from that period use the same pull.
#406
Quoted: 70 Post(s)
Need parts to fix Suntour Barcon friction shifters or will trade my good barcon parts for down tube Suntour ratchet friction shifters.
These are the parts I am seeking, 1 shifter housing, and 2 fixing bolts as shown in the photo:
#407
Liked 2,601 Times
Thanks for your offer. It might work, but I just ordered a new Sora derailleur that is likely to work. Yes, STI.
#408
Liked 2,601 Times
Oh well. It's so much to remember, and I was asleep in those years, so it's harder to acquire and keep that knowledge.
#409
Quoted: 1640 Post(s)
Liked 2,746 Times
FD 1300, looks like you need one with a cable stop.
#410
tantum vehi
Liked 999 Times
I can check at a bike co-op this weekend. I seem to recall seeing one suntour barcon that was non-functional. But I doubt it comes with two fixing bolts. Short of that, I've got the DT ratcheting shifters you need.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#411
Bikes: 75 Raleigh Gran Sport, 88 Bridgestone RB3, 72 Raleigh Super Course, 75 Jeunet 620, 95 Fuji Team
Quoted: 80 Post(s)
Liked 21 Times
Kind of a shot in the dark but I'm looking for a couple of spare tools to attempt to service my Shimano brifters.
Shimano TL-ST01 - for removing/installing the locknut on STI road levers
Shimano TL-ST02 - pin/guide tool for installing the outward return spring for STI road levers
I've got various parts for trade or I will buy. The spring guide tool seems to be more common than the lock nut tool, but I figured I'd see if anyone had both. If not I will take just the locknut tool.
I used one of these and cut the threaded end off when I serviced my RSX 7 speed STI Brifters. It fit right over the spring and worked great.
#412
Quoted: 70 Post(s)
Thanks! I appreciate you looking at a bike co-op. The Barcons I have are in great condition, but got damaged during teardown. The steel fixing bolts were seized in the aluminum housing, and the internal hex stripped out while trying to remove them from the bars. I had to slip the handle bar to release the Barcons. I would like to keep the build original using the Barcons if I can source the parts needed. If I can't then I will need DT shifters.
#413
Ellensburg, WA
Bikes: See my signature
Quoted: 315 Post(s)
Liked 494 Times
ISO: 130 mm French stem (I'm not even sure if you can find one that long). Need to shorten the reach up on one bike just a tad. Currently running a quill adapter and 140mm modern stem. Just checked the measurement of the adapter and it's 22.2 so that might fit in the steerer on the bike.
I have a couple of 90mm the French stems that I can trade. Also, have a couple of SR stems
1984 Gitane Tour de France; 1982 Nishiki Marina 12; 1984 Peugeot PSV; 1993 Trek 950 mtb; 1991 GT Karakoram, 1983 Vitus 979; Colnago Super, 1989 Spectrum Titanium,
#414
What??? Only 2 wheels?
Quoted: 1225 Post(s)
Liked 657 Times
ISO dust cap for Campy Record pedal.
I just discovered I've lost the dust cap from one of my Campy Record pedals on the Masi. Knurled edge, threaded. Anyone have a spare? Or know a source? Or a good substitute?
Real cyclists use toe clips.
jimmuller
jimmuller
#415
Old fart
Quoted: 3618 Post(s)
Liked 3,458 Times
MKS "Sylvan" pedal dustcaps are readily available, affordable, use the same tool as the Campagnolo dustcap (although the MKS tool is far less expensive), and can be anonymized by filing off the MKS logo on the cap:
https://www.benscycle.com/mks-sylvan...116-17/product
https://www.benscycle.com/mks-sylvan...173-11/product
#416
Liked 657 Times
Yeah, thanks. I had pretty much already decided to go that route.
jimmuller
jimmuller
#419
ISO Cinelli 1E 90mm
Hi, I’m looking for a Cinelli quill stem with the hex key on the front, which I believe is the 1E model, in 90mm. Thanks for any help!
#420
Bikes: Yes
Quoted: 3295 Post(s)
Liked 4,076 Times
Wouldn't a 22.0 stem work well enough in a 22.2 steerer? I've seen stems that were sold as 22.2 that actually fit a 22.0 steerer.
My Bikes
My Bikes
#423
No doubt it could be made to work, but I'd prefer to avoid having to fabricate and fit a shim.
Something to think about, if a 22.2mm quill can be 0.2mm below spec (as is the current stem on this bike), it seems quite possible a nominally 22mm quill could actually measure out at 21.8mm. That's almost half a MM below the standard spec, and would be a bad idea without a shim, IMO.
However, if anyone has successfully used a 22mm quill in a 22.2mm steerer, I'd be happy to hear about it.
Cheers!
#424
It’s why I took this stem out, it never worked well and I feared I would stress the stem cause I had to crank the bolt down to much. When I braked hard the handlebar seemed to chatter in my hands.
#425
