Thomas DeGent no fan of hookless…
#451
Quoted: 4546 Post(s)
Liked 5,054 Times
The same could happen with hooked wheels. DT Swiss already make a point of their rims being hooked - it is now suddenly a selling point again. Hookless could well end up losing more sales than it attracts if consumers are freaked out and don’t see any real benefits.
Disc brakes and electronic shifting haven’t really suffered from consumer backlash in this way. Most people who try them don’t wish to go back.
#452
Quoted: 3998 Post(s)
Liked 7,490 Times
I think that will depend on whether or not there is a major backlash from consumers. Look what happened with press fit BBs. It looked at one point as if threaded BBs were about to become extinct, but consumers had issues with creaking and there was enough backlash for some major manufacturers to make a U-turn. Suddenly threaded BBs became a desirable selling point again.
#453
Thread together BBs are a good solution for press fit bottom brackets. I have Wheels Manufacturing thread together with angular contact bearings on all of my bikes. I also have disc brakes, electronic shifting and hookless rims that require no rim tape. No complaints.
#454
Quoted: 2577 Post(s)
Liked 3,079 Times
Disc brakes and e-shifting are likely here to stay. Whether hookless is here to stay for road wheels remains to be seen.
#455
Advocatus Diaboli
Quoted: 4761 Post(s)
Liked 1,542 Times
Next up.. rebel against proprietary seatpost shapes and screwy clamping mechanisms.
Likes For Sy Reene:
#456
Bikes: SL8 Pro, TCR beater
Quoted: 1019 Post(s)
Liked 593 Times
Thread-together BBs represent a good workaround, although they seem to be somewhat expensive and on the heavy side. Nevertheless, it looks like manufacturers are backing away from press fit.
#458
Klaatu..Verata..Necktie?
Quoted: 10529 Post(s)
Liked 12,105 Times
Oops. But I don't mind the Wheels BB.
#459
Liked 593 Times
I had a creaking issue with my Canyon. I had my LBS replace the press-fit BB with a Wheels thread together BB. When I took my first ride on it after that.... same creaking. Came home, pulled the seatpost, slathered it with assembly paste, reinstalled it. No creaking.
#460
Liked 12,105 Times
I hate that - the problem stopped. It's not that you solved it, so if it happens again, you don't know how to fix it.
Likes For genejockey:
#461
Zipp has issued a new statement advising teams to use no smaller than 29mm tires on their hookless rims:
https://road.cc/content/tech-news/zi...debacle-307385
#462
No 28s with 25mm IW rims. 28 should be OK with their 23mm rims like 303s. This is CYA statement.
#463
RIP.
#464
Liked 5,054 Times
#465
Imo, if running hookless you should glue the tyre to the rim to prevent this from happening.
#467
look at the footage and notice the riding conditions. Looks like perfect asphalt, but zipp says it was an "impact" causing the crash. Suure .. !
Likes For Racing Dan:
#469
Liked 5,054 Times
I'm not defending hookless rims, but this wheel hit something hard enough to destroy the rim. Armchair conspiracy theory doesn't add any value here. If this was happening all the time while jra on perfect roads or hitting the odd pothole, then there would be no hookless rims on the market at this point. These are edge cases which have certainly raised questions, but it doesn't mean everyone's hookless wheel is suddenly going to assplode.
#470
Quoted: 682 Post(s)
Liked 456 Times
#471
I call BS. Tyre retention is too low to be safe, even with a tyre insert, that 99% outside the pro circus doesn't use either.
#472
It has been claimed it was DeGents rim, but the video above does not, IMO, support the claim the rim was destroyed by a big impact. To my eye it look like a JRA crash caused bu some minor incident, causing the tyre to come off.
#473
Quoted: 3260 Post(s)
Liked 2,572 Times
Look at the footage. To my eye, clearly it didnt. There is no indication anything was hit "hard". I looked it at it over and over. Maybe you can spot the supposed hit, I sure cant. I am however sure something was hit and the tyre blew off, but no indication that is was a "big hit". Only a picture, after the fact, showing the rim had damage. When did that happen? after the tyre and the insert, thats supposed to protect the rim in the first place, had come off?
#474
Liked 5,054 Times
Likes For PeteHski:
#475
Looking at that photo I'm just marveling at the circular logic of bikes going hookless, and then everyone putting in a green pool noodle to help retain the tire, only for the pool noodle to explode out and jam the fork, flipping the rider's face into the ground.
The world has gone upside down.
Likes For Yan:
