Is this a cracked chain?
Should Be More Popular
Quoted: 22711 Post(s)
Liked 9,070 Times
This is now ancient history, but the original 10 speed Ultegra 6700 chain (cn6700) had a major defect that caused breakage (it happened to me) and that’s why they stopped making that version and quickly changed to the cn6701. So even 10s chains can break if defective.
Method to My Madness
Quoted: 2050 Post(s)
Liked 1,542 Times
OK, what the utter hell did I do wrong here?
-I replaced the chain with the exact same model of Shimano chain.
-I sized it to match the prior chain, which was sized to match the original Shimano chain as delivered from Colnago.
-Text on the chain faces outward.
-Quick link is fully seated on both sides.
-I routed it properly through the jockey wheels; I took pictures before I removed the old chain and verified everything is routed properly through the tabs etc. near the jockey wheels. I was careful to never really touch the rear derailleur in any forceful way. Derailleur hanger is not bent and is flush to the frame as always.
-Chain runs beautifully. No hiccups, no stiff links, no nothing. Runs flawlessly forwards and backwards in any gear or combination of gears.
EXCEPT -
-As I've now been sitting here running through the gears over and over and over for almost two hours now, I can't for the ******g life of me get the goddamn chain to move off the smallest cog to the next one with a single shift. This was NOT a problem prior to replacing the chain, and I did not mess with the derailleur at all. And here's the kicker - when I first started testing it after the replacement, it wouldn't shift. Then suddenly it was shifting off the smallest cog perfectly fine. Then as I was about to make one last run through the cassette up and down, it quit moving off the small cog again and now I'm sitting here absolutely pissed this isn't working and this is turning into an all damn day chain replacement.
Ideas? Entire drivetrain is 5800 series 105 including chain and cassette, so it is NOT a compatibility issue. Only thing I can think of is this was like this before the chain replacement and/or the forces on the chain/bike/derailleur when out on the road are different than when holding the bike up by the saddle and shifting with no load on the bike such that it's creating unfavorable dynamics that don't exist when the bike is out on the road under load - I had no such issues shifting recently when out on the road just prior to this chain replacement.
EXCEPT -
Liked 1,542 Times
Mis-sizing the chain by a link (either too short or too long) should not affect shifting between the two (physically) smallest cogs in the cassette if you are on the big chain ring. Assuming that the RD cable housing(s) is/are seated properly at the RD and at all entries and exits through the frame, or at all stops on the frame if externally routed, your symptoms sound like a severely frayed RD cable that is about to snap; when was the last time you replaced the RD cable and housing?
Thanks all, looks like we are good to go now. Got pretty pissed for a while there, lol.
Likes For puma1552:
Liked 1,542 Times
Glad that a simple RD cable tension adjustment solved the problem. I hope the solution holds. Do note that a frequent need for tension adjustment for an RD cable that has been working just fine for a while may reflect fraying and the imminent demise of the cable.
EDIT: nevermind, that's the first time I've ever adjusted that cable. Was mixing up my bikes.
DOUBLE EDIT: Did a 30 mile ride and everything is perfect with both the chain and shifting. Not one single skip or bad shift.
