Adapting to getting older
Version 7.0
This is what I rode at the track tonight - age 74. I have been riding this set up for years.
If you need to raise the bars...raise them.
Likes For Hermes:
Thoughts:
1) We could make better suggestions if you elaborate on the challenges you are having now.
2) Raising the bars is quite possible, but I recommend thinking about how you want to change your torso angle/shoulder position and then think of the optimal hand positions that go with that.
3) Consider both the height and reach. Keeping the arm angled down reduces the tendency for you to pull yourself forward off the saddle on the occasions when you have to pedal hard.
4) Consider getting a tall quill stem adapter like the Nitto. That allows you to shop all the modern stems rather than being limited to tall vintage stems.
5) If you move away from drop bars, don’t overlook the touring bar option. These have a sweep angle that many prefer over a straight bar and offer a wide range of front to back hand positions that suit different riding work.
6) Also worth considering is raising the bar with a tall stem adapter and switching to a modern drop bar with shorter reach and drop.
Lots of ways to keep this great bike working. 😊
Otto
Otto
climber has-been
Liked 4,059 Times
I don't understand this statement. When pedaling hard, the tendency is for your butt to slide off the back of the saddle. This effect is more pronounced when pedaling up a steep grade. Pulling forward on the bars counteracts the force pushing your butt off the back.
Likes For terrymorse:
just another gosling
Liked 2,098 Times
Thoughts:
Otto
Otto
Results matter
Results matter
About 20 years ago I bought a new road bike and it came with the combo brake and gear shifters. That did a great deal for my riding comfort in not having to lean down and use the levers on the downtube of the bike. I started making shifts a lot more often as it was easy to do without interrupting my cadence. It is the best bike tech advance in the past 60 years.
Consider also a taller stem to raise the bars on the bike. A bike shop can help to determine how much you can raise them. I have swapped out the factory stem on most of my bikes to get the bars where they would be most comfortable for me.
Me too. I find straight bars to be less comfortable than properly adjusted drop bars.
Likes For Camilo:
Klaatu..Verata..Necktie?
Liked 13,203 Times
I have gotten older, near 70, and can no longer handle the drop down bars on my roadbike. It is a bridgestone rb2 from around 1992 and i would hate to get rid of it if i could find a way to keep it. I would have to adapt it to straight mountain/rec bars to continue riding it but dont know if it possible or worth it. Any thoughts?
As far as saddle-bar drop, I found that just reducing the reach to the bar by a cm made such a difference I didn't need to raise the bars. But you can get a taller stem, or a riser stem, and keep the drop bars.
The other thing about flat bars is your wrists. Riding on the hoods or in the drops, your wrists will generally be in a neutral position, not pronated as they would be with a straight bar, AND you have a number of other positions.
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Liked 400 Times
I'm certainly not opposed to people configuring their bikes any way they want, but I do wonder about the connection between giving up the drop bars and aging. I'm 73 and own two bikes, both with drop bars, and I'm down on the drops the majority of the time on my rides. At the moment, I don't see any reason why, as I get older, I might want to give up the drop bars... but who knows what Father Time will bring? Right now, I'm very comfortable on the drops.
Likes For Random11:
Mother Nature's Son
Liked 1,556 Times
Just struck me, I have another reason, prostate bladder issues, no need for details.
Angle makes bars look higher than they actually are.
Likes For delbiker1:
I can state the reasons for me to stop riding traditionally shaped drop bars are physical: chronic spinal and shoulder issues. I can ride those types of handlebars, but not for long, or without a combination of pain in neck and shoulders; and numbness in hands and fingers. Going to shallow drop, short reach and flare allows me to ride in comfort for long rides. I have never been a fan of the aesthetics of really long steer tubes and/or steep rising stems, but I have gotten over that bias. My Lemond Tourmalet is the most drastic of those. I recently installed a new fork with a longer steer tube and clearance for bigger 700c tires. I love riding this bike but was not using it much. Yesterday, I put 30 comfortable miles on it, no neck pain and no numbness, it's like connecting with an old friend that you are immediately comfortable with. IMO, the less than sporting look is a small sacrifice for comfort.
Mother Nature's Son
Liked 1,556 Times
It is an aluminum steer tube, the drop outs have fender/rack eyelets, room for 32 mm tires, all reasons for the purchase. It also eliminates the toe overlap the bike had with the previous fork. I am going to be taking another a .5 to full inch off the tube. Also, the crown race is 27 mm, which limits headset availability. I’d like to have it resized to 26.4 to allow the use of a better quality than the cheap one that is now there.
Drop bars and swept touring bars are much better. I have two bikes, one with each type and enjoy the variety.
I tried drop bars on the old MTB, but it didn’t handle well. The head tube angle doesn’t lend itself to that. Plus it’s fun to have the touring bars. You can easily get your weight way back when you need to. And the forward bends are a good grip when standing. Also, on the trails, being more upright means I can work hard and still be going an appropriate speed around other folks on the trail.
Otto
Liked 2,277 Times
The nice thing about a 1” (22.2mm) quill stem extension adapter to 1-1/8” threadless stem is it allows you to do anything you want to try.
If you can mount the bike on a trainer, you can try and do a rough mock-up of about where you want the bars.
There is merit in just raising your drop bars, or using a higher compact and/or flared bars.
John
John
Bikes: 1999 Giant ATX MTB, 2002 Lemond Zurich, 2018 Fuji Transonic 2.3, 2019 Specialized Tarmac Disc Expert
Liked 421 Times
I just refuse to get old! When I'm on my bike I feel like I'm just 37. I guess I'll just stay at that age for a few more years as the past 7-8 have been pretty good!
Liked 400 Times
I thought about this when I bought my Caledonia at age 71. How many more years would I want to ride a bike like that? So far, so good, and the vast majority of my riding is on the drops.
Edited to add: I'll also mention that I pay close attention to the posts of riders older than I am to get some indication of what my future on the bike might be like.
Likes For Random11:
Likes For Camilo:
Grupetto Bob
Bikes: Bikey McBike Face
Liked 6,608 Times
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
I quickly found the advantage of drop bars for pedaling up hills as a teenager. Half a century later I still want the ability to use my back and torso muscles when pedaling up grades and the only way to achieve this is with drop bars.
I have always needed to stand up at times to unbunch my neck and shoulder muscles. I have to consciously loosen those muscles or I will end up in pain. I have at times also made use of the services of a professional masseuse who would do active pressure release.
climber has-been
Liked 4,059 Times
I do most of my climbing in the tops, or the hoods when out of the saddle. I don’t use the drops at all uphill.
I stand up in the saddle only to stretch out my neck and shoulders and the rest of the time I sit down and put more energy into pedaling. In the saddle I can maintain a faster cadence than if standing on the pedals. When standing on the pedals and out of the saddle the rider needs to try to offset the lower cadence by using a much taller gear.
Standing in the pedals also increases the frontal area and increase the effect of any head wind. There was a very steep grade on Hwy 101 in California that faced directly into the wind coming off the ocean. Even big rigs had difficulty getting over the grade. On a bike I knew if I stood up in the saddle it was all over as I could not overcome the wind. At that point I would be walking up the remainder of the hill. The Division of Highways (now CALTRANS) cut down hundreds of redwoods to re-route the highway to the east so the truckers would not need to slow down.
Same here. The only top pro rider I’ve noticed who regularly uses his drops while climbing is Roglic. Obviously works well for him, but the rest are on the hoods or tops.
Likes For SpedFast:
Liked 10,164 Times
I only use the drops when climbing if there is headwind.
As for standing, some people can stand on the pedals for much longer than others. I climbed a 9 mile canyon with a friend and he stood the entire way.
Likes For big john:
