Trike Questions
Any thoughts/experience with the comparison of the suspension system between the Cat Road AR/ Dumont and ICE Sprint 26? Is the Cat adjustable air shock with 50 mm of travel superior for handling the bigger shock from potholes, big cracked, dropped pavement, large bumps than the ICE non-adjustable isomer system re: the rear wheel? I'm guessing the ICE front suspension with 40 mm of travel is smoother than the Cat with only 12 mm of travel? I also assume rear suspension is more important than front suspension? Would the ICE provide a smoother ride on chipped seal but the Cat handle the "big wacks" better? I will test ride if and when I can-got to see if Easy Street will cut a boom for short legged demos for the Cats. But a large old shopping strip isn't the same as a long ride on the road.
Quoted: 18430 Post(s)
Liked 4,548 Times
Whew, one can spend quite a bit on those trikes!!!
I just bought a used trike built at our local co-op, and have been enjoying taking it out a bit. What I will say is that it changes the way pressure is applied to the back, so it may or may not be better than an standard upright bike.
I have no suspension. 20x1.75, I think. Anyway, I haven't been paying attention, but haven't noticed a lot of jarring, except on rare occasions when I run over something or hit a big hole (sometimes it is hard to avoid with 3 tires on the ground). But the suspension is something you'll have to try out. Chipseal doesn't seem to be a major problem.
Hopefully your bike shop will allow you to go for an extended test ride. 10+ miles? A day? Demo model? My trike uses the DualDrive, so with a long cage derailleur, I get some boom adjustment.
One thing I discovered with my trike is that I'm 100% self supporting, and my trike has absolutely no storage, and a backpack isn't convenient. I'm going to try to build a custom rack for it, but that would certainly be something to look at.
Quoted: 523 Post(s)
Liked 231 Times
You are comparing a home-built trike with one that has been designed and manufactured by one of the best trike companies on the planet (Catrike, ICE, Greenspeed, and HP Velotechnic) and there likely is no comparison between them. My Catrike 700 seat has underseat storage sufficient for me to carry a pump, two spare tubes of each size, a multitool, tire irons, and a separate storage area for identification and emergency money. It's a well thought out seat. I can also carry a lock by hanging a small handlebar bag off the frame behind the seat. It's enough for anything shy of groceries which can also be carried without a rack by simply hanging a cloth bag off the frame behind the seat as well. I made a DIY attachment for a standard rack but decided it wasn't needed for ordinary riding and removed it.
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 137 Times
I use this bag on my trike. https://www.radicaldesign.com/recumb...sal-racer.html
I also use it on my recumbent bikes - it's very adaptable and works with almost any recumbent type with any type of seat.
There are bigger versions available but this size works well for almost all of my rides.
Liked 4,548 Times
Co-op doesn't always mean a bad thing. Burley was a local co-op that made some great trailers recumbents, and tandems, at least for the era.
Perhaps I'll try to get a little more history as to when/why my trike was built.
I was considering making a storage compartment for next to the seat on my trike. I'm glad to hear the under the seat compartments on some of the above models. The seats do look a bit more advanced than I have too. Anyway, for my type of utility riding, a rear rack and panniers would be a must, and will be built soon (no place to simply bolt it on at the moment.
Nonetheless, I would still advise that if the OP is able to test-ride a couple of trikes, that he should be more concerned with how the trike feels on the road than the paper specs.
This afternoon I sat in a Road AR, Dumont and ICE Sprint with mesh seat. Hopped back and forth and played with seat angle. In two weeks the doc will let me do some light riding so I will test ride these in a large strip shopping mall. Road is a bit rough with speed bumps and opportunity to do a lot of turning. Not like a long road ride but it's the best I will get for test rides. I will be able to ride the ICE with the hardshell seat as well as mesh. It looks to me the rear suspension on the Catrike should be superior to the ICE and the FS on the ICE superior to the Cat. Test ride will be interesting.
Liked 4,548 Times
I took the trike out again today. It is still a bit new to me. Anyway, I don't have suspension and tried to pay attention to bumps.
I didn't hardly notice chipseal. So, I think the larger tires (20x1.75) are probably adequate to minimize the effects of chipseal.
However, I could definitely feel any larger bumps, but it gave me a feeling of connection to the road. A short rough gravel section definitely was bumpy.
I'm still not sure I'd be concerned about suspension. HOWEVER, in your case, it is quite possible that ordinary jarring from riding could be painful or bad for the back. So, with that in mind, perhaps the best suspension you could get would be of benefit. Independent front + rear? Shocks?
I don't think the chipped seal is a significant issue and neither are the potholes-not that many of them on most of the roads. The problem is the unstable soil and the lack of proper maintance by the counties on these roads. There are frequent sections where the right side car tire rides that are broken up or dropped down and poorly repair or not repair at all. Sometimes just one lane and other places in both lanes. These sections run for feet and some cases for yards. I think most of this will be missed by the rear wheel but hit by the right front wheel unless I can move to the center of the two lane, no shoulder road. Theses roads have very little traffic and general a good line of sight so as long as I'm sure no one is behind me I can move to the center. Avoiding the really rough spots on a one track bike is easy. With a three track trike it will be more of a challenge. I really need to find a way to ride these roads with a rigid trike and a suspended one to determine if suspension is that big of a deal. It cost $1000 or more and adds a lot of weight.
Quoted: 3352 Post(s)
Liked 1,056 Times
I posted this somewhere before. IMO, and checked out with my doctor, I have a theory that the bumps and vibration of an unsuspended trike is good for you. All the bumps and vibration causes all your internal membranes that holds all your internal parts in place to basically get stronger like weight lifting.
Liked 4,548 Times
One thing I've noticed about the trike is that it is a lot harder to look back than on the regular road bike. A bad back might make it even worse, so a mirror would definitely be handy if you're doing some avoidance maneuvers.
It is tricky to avoid a pothole with all three wheels, and sometimes one has to just accept the bumps. One can get small ones like those water covers in the city to go between the wheels.
I like rydabent's theory. I'll have to consider that some, but I do believe in a "use it or loose it" theory, especially with aging. At least, the more I ride (upright bike), the better the knees, and perhaps the better the back too. Too much jogging would be bad, but I should probably consider incorporating a little more jogging in my routine.
I am a little surprised that quadricycles aren't more popular. There might be several advantages including avoiding bumps and debris with the rear wheels. Better rear wheel traction and braking by moving the wheel forward?
Quadricycles might require changes to laws to make them road-legal. The federal definition of bicycle is up to 3 wheels. 4 wheeled vehicles may automatically fall into the ATV category if there is no specific law which applies to them.
I have an opinion about mesh seats. I ride a 2-wheeled tandem recumbent which uses RANS seat (mesh back and foam seat) and an ELF (entirely mesh seat). My behind gets hot and very sweaty on the RANS seat. I feel better on the entirely mesh seat. Note that neither of those 2 bikes have highly reclined rider positions.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
The Dumont is a very nice, well engineered trike. I'm sure that you'll be happy with your decision. What color did you buy?
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
But red is faster!
Have fun.
Have fun.
