Must I keep welding these?
No help to anybody here but fun - My Peugeot UO-8 that started my journey on road bikes in 1967 died on a car door 25 years later. The plain steel seatpin got tossed in a box. Then I realized I was getting tired of fussing with my Campy bolt which 1) was lousy with the brake cable hanger I used for my Mooney's cantis and 2) over time broke because of the poor fit with that hanger. "Duh! I've the right pin! Pulled it out, cut it to size and used it for the next 30 years. Now honorably retired.
Quoted: 2652 Post(s)
Liked 3,206 Times
Then you'd have to remember that you had turned the bolt around or else you'd strip the right side, too, the next time you had to tighten or loosen the bolt.
I remember encountering my first keyless binder bolt and thinking they should all have been keyless all along.
Quoted: 442 Post(s)
Liked 1,038 Times
I’ve seen many frames that are notched on both sides, usually low end road bikes and 3 speeds. And quite often one side has already been carved out from someone turning the wrench on the wrong side.
