Do you balance (not true) your wheels?
Would anyone happen to know how to quantify the effect of out of balance wheels? Balancing is common practice in MCs and cars, to improve steering and traction and to prevent uneven tyre wear. Several references to reduced gas mileage caused by unbalanced wheels can be found too. But no where can I find a reference actually quantifying the effects, except to assert its there. I can believe that but In light of other recent debates over the effect of a few hundred grams of wheel weight, etc, Id be interested in knowing the "size" of the "problem".
Anyone?
Anyone?
I am wondering how many riders balance (not true) their wheels, or have purchased wheels that came balanced with counterweights to offset the heavy spot.
The Aeolus Elite 35 TLR carbon wheels that came with my bike created a noticeable rear wheel vertical wobble when spinning the pedals fast on the stand, which can also be felt when holding the bike up by the seat, and the front wheel rotated quickly with the valve dropping to the bottom when lifting the front up. I would think that this is the case with most wheels out there, some more extreme than others depending on wheel material/construction, weight/size of the valve stem, and so on. Whilst the weight of a rider will not cause the rear up and down wobble to present any real issues and any 'flywheel gains' are extremely marginal, I think the oscillation in the front when rolling fast may contribute to a risk of speed wobbles. This aside, it somehow seems right to me that a contraption that is all about two wheels spinning quickly should be a balanced and smooth system.
For those interested, the procedure is quick, cheap and simple and whilst it can be argued endlessly, the additional weight won't matter in practice, and even in fine print theory the acceleration effort is offset through momentum. The following assumes a modern rim with a wide enough inner diameter and channel so that the weights can be placed on the inside, rather than any external attachments that mess with the look and aerodynamics of the wheel.
1. Determine the heavy spot on the wheel by lifting the front wheel off the ground and experimenting with where it wants to settle at the bottom by letting it go from a few orientations.
2. Mark the exact opposite of the heavy spot at the highest point of the settled wheel.
3. Stick varying amounts of blu tack or similar to the marked spot until the wheel no longer moves away from any rotation it is set to rest in.
4. Weigh the exact amount of blu tack as accurately as you can. You may need 3.4g, you may need 17.8g, who knows.
5. Purchase a few 'golf club adhesive lead weights' (not tape but the little flexible lead slabs with an adhesive side) and rim tape.
6. Determine how many lead weights and what amount of rim tape (make sure it is enough rim tape to cover the length of the required lead weights all aligned in a row) make up your target weight.
7. Remove the wheel and take the tyre/tube off and place a lead strip inside the wheel channel (where the tube lives) exactly on the marked spot and the others, if needed, evenly each side of the central weight.
8. Cover it up with the appropriate length of rim tape, but do make sure that the weight of the rim tape is considered as part of the target weight as it is significant in this case.
9. Pop tube/tyre back on, the tyre ideally in the same orientation as before (but we already know you will keep the tyre brand over the valve anyway), and test whether the trick worked by holding at the hub to see if it stays put wherever you stop it.
10. Mount the wheel and repeat on the other one, the same weight will probably work closely enough if it is the same wheel as the front. Just confirm with the same amount of blu tack as before and vary if needed.
I needed a whopping 12.85g per wheel, or 3 of the little golf lead strips with a length of rim tape that covered the strips and then some more. I just placed the lead weights on the existing rim tape and then taped over the top of it all, these things are so flat that they can be sandwiched by the rim tape and still keep a low profile. The same weight worked on both wheels with 28mm GP5000s on the rear and 25mm on the front, so tyres seem to be even enough. Now the wheels stay wherever they are set when lifting the bike up and the bounce is gone when cranking it up. This proof of improved balance aside, it also appears that the whirr from the hub engagement points now sound more even when coasting fast. Otherwise it rides as before but with a little added confidence on fast descents - yeah it's a mostly subjective undertaking.
Thoughts?
Thoughts?
Compared to what? Calculating pi to the last digit?
Likes For downhillmaster:
should be more popular
You'll get away with it!
The lead strips in that video are the ones I am talking about, just for a clincher they can easily sit inside parallel to the rim instead.
Which of the 10 steps sounds time consuming or complicated?
Happy With My Bikes
Liked 2,753 Times
40 years ago I balanced car tires. There are two areas of imbalance, static and dynamic. What you are describing is static balancing for wheel hop. Any wheel wobble would be due to dynamic imbalance which your method is not going to correct. Unless you are experiencing either on the road, I wouldn't worry about it.
Likes For Chuck M:
More specifically; purchasing adhesive lead weights, using the blu tack, weighing exact amounts down to tenths of a gram, filling your wheel with lead weights, factoring in exact weight of rim tape, etc…
" Do you balance (not true) your wheels?"
Nope. And never will. Seems like a solution in search of a problem for most riders.
Likes For Koyote:
Anyone?
Anyone?
But on a bicycle I have never experienced any such resonant vibration. So it seems like a solution looking for a problem that doesn't exist. I don't think balancing your wheels would do any harm, but it does seem like a pretty pointless exercise to me.
Likes For PeteHski:
Fax Transport Specialist
I had a wobble on a descent at around 42mph (from gps track afterwards, I wasn't looking). I was pedaling hard and went over a couple bumps which seemed to start the wobble (or just coincidence?). I understand it's a resonance thing so there are many factors at play, but I figured it wouldn't hurt to balance the wheels. It's not just the base frequency, it could be a second harmonic of the wheel that hits a third harmonic of the frame? Who knows.
My wheels are 55mm depth, so I like to use a tube with a 90mm valve stem. That's a big chunk of rotating mass. I got some lead tape and put it on the outside of the rim between the spokes, opposite the valve stem, and that did the trick. I covered the lead tape with black gaffer tape (doesn't leave residue like duct tape) and haven't had any issues with it coming loose.
I don't live near that particular hill anymore so I probably don't hit 40+ speeds, but it makes me feel better On a different bike, I probably wouldn't bother unless I had another wobble incident. My cross bike with road tires never had an issue on that same hill (probably not as fast though), I never balanced those wheels but they also have a heavy spot at the valve stem.
Uhh, 1-10 fill half a page and are the very definition of time consuming and complicated.
Here's a two step version:
1. Determine how much weight you need to offset the heavy spot on the wheel
2. Stick that weight into/onto the wheel opposite of the heavy spot
I would think that buying readily available supplies, using scales, and sticking adhesives to bits is not complicated. You could even leave the wheels on the bike to do this job. But then again I don't want to make assumptions re what kind of bike maintenance people here are comfortable with.
Many people seem to go with the outside of the wheel solution, which I don't quite understand - unless its a tubular setup - given that it will inevitably create all sorts of turbulence vs. a smooth rim. Putting the weights inside the wheel should be no issue on most carbon/alu wheels and requires no more skills than a routine tyre/tube swap.
Likes For yaw:
Perceptual Dullard
Yes, I do, but I was unhappy when I had to patch a flat because the patch threw off the balancing, so now when I get a flat I add three patches, one over the hole and two others at 120-degree intervals. I think adding just a single patch at 180-degrees would make the wheel "hop" so it makes more sense to space them out. Speaking of flats, I used to carry a CO2 cartridge but CO2 is heavier than atmospheric air so the CO2 would settle down at the bottom of the tire overnight. Worse, CO2 leaks more quickly than atmospheric air so when you have to top off the tube with a pump (and you do) then the remaining CO2 has a changed distribution. The tube is a smooth and featureless torus so there's really nothing to mix the gases more evenly, so I'd unscrew the valve and add a small BB. The BB would roll around inside the tube and mix the CO2 with the ambient air. But, in the end, I realized that it just makes more environmental sense not to use CO2 cartridges and to use a small mini-pump the size of a fat cigar. The 400 pumps it takes to bring a road tire up to acceptable pressure is just enough to keep me warm. I do miss the "shoop shoop hula hoop hoop" sound of the BB rolling around inside the tube though.
Likes For RChung:
When you say that did the trick do you mean you got it balanced out (no heavy spot, wheel stays still) or that it reliably stayed out of wobble territory since? I guess too many factors come into play to have any final answer here but likewise I do take the added confidence a balanced set of wheels provides.
pan y agua
Liked 893 Times
Speed wobbles has way more to do with the frame’s stiffness and how you fit on it. Willing to bet if you have a speed wobble problem, it’s going to stil wobble even if you chang e wheel sets
You could get lost and die.
You could hit a tree and die.
Interesting no one pointed out that your comparison shouldn't be to truing but making it round. Wheels require three things; straight, true, and round. I know this seems obvious but its surprising how much it isn't. Whenever I have had someone experience speed wobbles it came down to straight or round, true just effects tracking and braking.
If your wheel is really experiencing a vertical wobble I would toss it in the stand and spin the wheel and watch where the rim and tire meet to see if it moves up and down, a sign of either the tire not being seated right or the rim out of round, it can sometimes be hard to distinguish since you're seeing movement but not registering where. If so, slow the wheel down and make sure the tire is seated the same all the way around, being slightly off will create slight dip effect (usually the tire is too far in in a spot) that will produce a speed wobble that might be noticeable at 12-15mph but completely unstable at 30. If the tire looks fine, take a spoke wrench, brace it against the stay and hold the end against the rim and spin it, see if it moves. If so, toss it in the stand and make it round.
Less likely but not impossible, especially with cheaper tires, the tire is out of round, again toss the wheel, fully inflated, into the truing stand and check for roundness at the tire, cheap tires can be out of round enough to cause problems. Because of the handmade nature of high end tubulars it is also possible to find these aren't perfectly round, less so than in decades past, in cases where the tubular wasn't perfect on a TT or track bike, we made the wheel round to the tire and not to the rim. Wheels being perfectly balanced is a fairly unimportant thing, wheels being perfectly round, that is important.
Now that it runs so smooth even on the stand I would not trade the extra 25g to go back to the imbalance, that's for sure.
In the past, on spoked motorcycle wheels, I have wrapped some plumbing solder around the end of the spoke, near the nipple. It looks fairly inconspicuous if you don't need a bunch of weight. Plus you can melt the ends just a bit to keep it from unravelling. I would never go through the trouble of taking a tire off the rim just to hide some weights inside.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Liked 1,458 Times
Likes For Bob Ross:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Liked 1,324 Times
No. The imbalance is too small.
I have been asked this so many times it kind of naturally makes my eyes roll but to play along i will say the following: I do not have the time to do calculations but might sometime if I get bored. What people know how to do is do static/single-plane balancing. It looks better in the stand but doesn't solve dynamic or 2 or 3 plane balancing. I have had to use balancing machines in production of products in the past. Bicycle wheels don't have enough mass in comparison to the mass of the rider and bicycle system together to really do anything. Think mosquito landing on your wheel while riding and then you losing complete control of the bike. Great for a Mr. Bean bit but not so much in real life. Any slight imbalance or small effect can be made to seem large. Spin a wheel up to 50+ mph in a stand and watch it dance. Place a down feather in an air cannon and fire it out at 200+mph and maybe it would do some damage too...
Speed wobble: it can have many causes but wheel imbalance is not one of them. It is almost always a Geometry issue involving the wheelbase, trail, head tube angle, etc. If you're getting a wobble out of the wheels at high speeds then maybe take your wheels to a mechanic to fix whatever it is you did to the bearing preload or to replace your bearings.
Thanks for the link to the Calvin video. I will watch it when I have some time and probably come up with my own version to put on my channel. Yay.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
I eat carbide.
Liked 1,324 Times
Mark my words though - as I get bored or am looking for new Ideas I will come up with a wheel balancing product and find sort of internet style sound science behind it to justify it. I have the laser on the bars to align the front wheel idea long before it came out. Same thing. Also the idea of a jig to align the lever position based on the top cap... and Abbey tools has that now. *shrug*
Mother Nature's Son
Liked 1,556 Times
Never had a need to do so. As for the magnet, I always put it on the opposite of the stem. Does it make a difference? Probably not. Just a habit.
pan y agua
Liked 893 Times
Yes but this does not exclude ANY potential effect of the imbalance on the system. Fortunately I do not have a speed wobble problem, but since I am doing 70kph+ downhills multiple times a week I am taking the extra balancing on board.
It may have been unclear but I do not have a speed wobble problem so this fell under the preventative category - useful post nonetheless! The wobble on the stand was within the usual range and it's quite easy to observe the valve position causing the wobble as the wheel spins, its rotational location obviously coincides with the wobble frequency.
When I hammer down my local climbs, I prefer my wheels to be balanced to remove one source of oscillation I can easily control. This does not mean that this is compulsory to do so in order to be safe, or that it can be specifically felt.
