How many BF posters have cracked a bike frame?
Quoted: 8439 Post(s)
Liked 9,382 Times
None of the frames I broke were crashed. The first one did suffer a hard landing but the other 3 had no abuse. Most of the people I know who have cracked frames did not crash those frames.
Likes For big john:
astro
Bikes: Raleigh Sports, '72, Bianchi Volpe, '97 (no more, it died), Greenspeed GTVS6, '05, Trek 520, '13
Quoted: 44 Post(s)
Liked 51 Times
I have a 72 Raleigh Sports (3 speed). I don't ride it all that much (hard to do hills on a 3 speed) and the frame is fine. I had a 97 or 98 Bianchi Volpe. In 2011 or 2012 I was riding it, and making a right turn, I heard a "sproing" and then the handling became squirrelly. I thought I had broken a spoke. With only a half mile to get home, I kept going. Closer inspection showed the right chain stay had broken just in front of the dropout. So I got a 2012 Trek 520. I was run off the road, hit a curb straight on and did a face plant. The only damage was to the fork which was bent so the front wheel overlapped the down tube. A new fork fixed that one and I still have it. (It took some work by a plastic surgeon to fix my nose.) I also bought another 520 (in 2020), kind of as a reward for surviving the crash. While it was still under warranty, the little piece of the seat tube that's above the top tube and has the clamp for the seat post broke completely off (so you could just lift the seat off the bike). The bike had never been crashed or abused in any way. Since it was still under warranty, Trek replaced the frame and the bike shop where I bought it transferred all the components.
ignominious poltroon
Quoted: 2305 Post(s)
Liked 3,544 Times
Some frames have defects. They warrantied it (replaced it with an SLX), so I guess that means it was one of them.
Quoted: 675 Post(s)
Liked 753 Times
Took a car to crack my frame.... and the bike frame too.
Pretty sure neither is designed for that kind of stress.
Never broke on the trails tho.
(cursed statement if I ever saw one)
Sr Member on Sr bikes
Does the steer tube count? I guess that’s not technically part of the frame. Last year I hit a bump and cracked the aluminum steer tube on my vintage Vitus.
Dan
Dan
Quoted: 4888 Post(s)
Liked 4,053 Times
Let's see:
Lambert fork - yup, that fork.
Peugeot UO-8 - chainstay broke behind the bridge at mile 22,000 and after dozens of crashes. Bike was bent and re-bent many times and just tired out. (Rode it home.)
Fuji Pro - BB shell at the seatstay. A known defect in that run of bikes. Fuji gave me a hand built replacement! (In a race. Rode it to the finish.)
Cheap hi-ten Sekine - fork blade midway, just above the LowRider U-bolt clamp. No clue why. I rode it home.
TiCycles ti fix gear (my avatar photo) - fork blades (both) cracked at the crown. (A combination of decisions adding up to a metallurgy no-no. A minimal, very light fork crown with no scalloping - my call. Nickle plating a Columbus SL fork and not heat treating it after. (Dave Levy happened on the SL and used it without a cost upgrade. I was thinking 531 but hardly complained! Plater knew you HAD to heat treat nickle plated hi-strength steels and said nothing. It would have been an additional $60 which I would have coughed up with no hesitation. Cracks showed up at 8000 miles. I had an angel that day.)
Sport Reynolds 501 Peugeot - had been hit hard by a car. Week 3 I saw cracks in both chainstays behind the bridge. Did a CF wrap that stiffened the BB beyond anything Peugeot ever made. Retired the bike at 8000 miles because I don't know what other damage it might have.
I am potato.
Quoted: 1838 Post(s)
Liked 1,712 Times
Thanks all. In reading here, it seems that the unfortunate end of a frame (and other components) is a lot more common than I thought!
I don't feel so bad now. On the bright side, I now have room in my stable for fancy new rides
Car dependency is a tax.
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4440 Post(s)
Liked 3,064 Times
Quoted: 1164 Post(s)
Liked 1,272 Times
I have neither the strength nor the crash probability to break a frame. Yes crash could happen, but I avoid them at all costs. So I've never damaged a bike frame in over 60 years of riding.
I did bend the front wheel of my first bike when I let my older brother ride it to school when I was in 2nd or 3rd grade with me on the front handlebars (remember that?) My foot went into the wheel and it got bent. My dad, as punishment (we weren't supposed to do that), made me ride the bike with the bent wheel for as long as I remember.
I think I might have broken a trike when I was 5. I remember my dad taking it with us to my grandparents' house one weekend and my grandpa brazing something to fix it. I put out a lot of wattage on that trike! Or, more likely, playing "bumper tag" with my brother on his trike.
Crashes aren’t really a cause of frame breakage. I do have the crash probability as I crash with frightening regularity. I even crashed a bicycle into the side of a car long ago. That didn’t break the frame…bent the hell out of it but it didn’t break. I wouldn’t expect any bike to not be bent by running it into the side of a car but I really doubt that any frame would actually break during such an event.
1974 Raleigh Grand Sports, 531 double butted main tubes. Down tube fatigue crack originating in the brazed joint between the down tube and head tube. There was an area of the interface between the lug and tubes which was not filled fully with braze metal, it looked like the crack originated there. Cracked in 1990 after quite a few miles; safe, slow failure mode with creaking sound and slow growing crack long before it got near wanting to fail fully.
Liked 9,382 Times
Bikes: 2017 Co-op ADV 1.1; ~1991 Novara Arriba; 1990 Fuji Palisade; mid-90's Moots Tandem; 1985 Performance Superbe
Quoted: 390 Post(s)
Liked 574 Times
I had an aluminum Trek 7.3FX in daily commuter service for about 12 years that developed a crack in the seat tube near the bottom bracket. The way I found it was my rear rim brake was rubbing but only when I was applying higher power. I spent a couple of sessions straightening the rim but the rub-on-power wouldn’t go away. Careful inspection of the frame revealed the crack.
Bikes: I have a few
Quoted: 350 Post(s)
Liked 238 Times
I have a Mercier Formule in 971 that has cracked at the top/seat tube junction. I still have it and cannot bring myself to part with it. The only other bike that has cracked was a chopper in the late 70's I used to take over jumps. Not bad considering I have had 50+ bikes in 45 years of riding.
Quoted: 140 Post(s)
Liked 81 Times
1984 Bottecchia, down tube below lug. They were known to fail because of poor chroming methods. Bike Friday “dropout” at the seatstay cluster. So manufacturers and design defects. When I had my shop I saw some heinous failures mostly from abuse.
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
1979 Schwinn Super LeTour - seat tube cracked about 1984. This was a hi ten steel frame that had taken me on self supported Atlanta to New Hampshire to Milwaukee trip with spouse in 1981. Schwinn gave me a double butted cro mo frame.
2007 RANS titanium V3 long wheelbase recumbent. I had ridden it since 2016 when I bought the the frame from a fellow who had got it from RANS as NOS not long before. In 2020 noticed both ‘seat stays’ cracked near where they connected to main tube. Not fixable. The frame became wall art.
Super Modest
Quoted: 11034 Post(s)
Liked 4,767 Times
Likes For Trsnrtr:
In the wind
My first Miyata 1000 (1987 I think?) had to be retired due to a cracked chainstay. It was a great bike and had served me well, but I think my decision to ride it through the winter was the cause of its doom.
It has since been replaced by a 1985 model, and my winter bike is now aluminium. Live and learn I guess.
Liked 9,382 Times
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
I've never broken a frame myself, but I've fixed a few that others have broken.
Trek Domane. Not a crash. Operator error. I failed to properly seat it on a turbo. I mounted up, clipped in, and put power down. Right chain stay snapped just before the dropout. As I toppled over it also snapped the left chain stay. It was a negative experience.
Mike
Mike
Quoted: 2639 Post(s)
Liked 3,193 Times
Did exactly the same thing to a carbon frame bike, the first time I used my new smart trainer. Right seat stay cracked just above the dropout. The bike still works on the trainer, but it's unusable on the road.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2740 Post(s)
Liked 6,079 Times
Which goes to show that steel is real, but aluminum is a close second!
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For daviddavieboy:
Quoted: 4621 Post(s)
Liked 5,162 Times
