ESI extra chunky grips less shock/vibration absorbing than expected
Is this shape any good for hook of hamate pain/sensitivity due to trauma which happened 14 months ago?
https://www.amazon.com/VELO-Kork-Len...dp/B07NZZMN8M#
https://www.mtbr.com/threads/grab-on-grips.406895/
https://www.mtbr.com/threads/grab-on-mtn-1-grips-original-formula.479775/
https://www.sjscycles.co.uk/handlebar-tape-grips/grabon-foam-mtn1-handlebar-sleeves/
https://products.mtbr.com/product/co.../foam-mtb.html
Someone said that as soon as ESI silicone foam grips came out Grip-On ones got immediately forgotten by everyone.
I have heard that excessively soft grips cause "pump," that is, your hands continually, tire loosen and re-tighten as you unconsciously seek a firm grip but cannot ever fully achieve it because of the padding. I assume that you will try some of the other excellent advice offered hear .... also consider hand exercises if there is some specific and personal situation where your hands just need a boost.
Hope you enjoy your rides and your life more each time.
I think too of a springy foam such as silicone one reacts with too much counter pressure which increases overall pressure on hands. The high density foam feels firm and then starts to collapse at certain pressure threshold without being too springy (during bigger road shocks only for example).
There are also Ritchey WCS high density foam grips. Nobody has compared them to VELO high density foam grips. Ritchey WCS seem to have bigger diameter around the pinky finger so might feel less fitting for some people.
ESI FIT SG tapered silicone grips are also not talked about much.
