Help Me Pick a Future Proof Road Frame
Quoted: 2406 Post(s)
Liked 2,996 Times
I don't know that you can future proof for technology changes at 100%
the technical problem for future proofing is whether parts you use now will be around and whether standards will change
over all I took a different view on future proofing when I got a custom a year ago
my view was less technology and more future fit issues
I kept my technology simple....r8000 11 speed mechanical (knowing I could go sram wireless were I ever to want to
I stuck with dual pivot rim brakes as that would give me a better ride as the fork would not have to be built as heavy and my use case does not really require disc
i went with 1 inch threaded stem as in my mind it will give a bigger range for fits in the future as I age (more) and I think threadless stems by and large have minimal design soul
68mm british BB because with phil woods and others I will always be able to get a BB
I asked the framemaker to make the frame as small as possible for a good fit to allow for shrinking with age
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
Quoted: 700 Post(s)
Liked 474 Times
Will 12sp Di2 or Sram even fit on a 130 spaced frame? And does it need special wheels or freehubs? I just haven't kept up on this as I'm getting too old to even need such an upgrade. That shifting difference isn't going to get me around the park any faster, but riding the trainer all winter might.
Normal wheels.
Same freehub as 10/11 speed.
I’m hoping the shifting difference (going from 36:28 to 36:34) will make a difference on our annual Leith Hill Octopus :-)
Normal wheels.
Likes For zacster:
With a mighty wind
Quoted: 1133 Post(s)
Liked 926 Times
A couple years ago I sent in the right ergo for a rebuild. Can’t remember the price but it was extremely reasonable.
I’ve replaced the pulleys once.
It shifts amazingly.
Maybe 5 years ago I swapped the square taper 53/39 chorus crank for a 50/34 carbon 11sp Chorus crank. I have a 12-30 Veloce cassette and 12-25 Chorus I swap out depending on the day. It was plenty of gearing to ride the Triple Bypass.
It’s still one of the absolute best shifting systems ever in my opinion. For future proof, it does suffer from Campy’s tendency towards proprietary systems. A small stockpile of cassettes, chains, and shifter rebuild kits, and this thing will outlast us all.
I did the same with the crank. I don't think I knew about the 12-30 Veloce, but I'm now looking at theoretically kluging a wide Ultegra 10sp cassette onto an 11sp Shimano wheel. An 11sp wheel has enough extra room to make it Campy compatible, where the older 10sp just didn't, in spite of there being cassettes made like that. In fact I've done this on my trainer which is 11sp freehub but Shimano only. It shifts just fine with my Chorus. It just takes .2mm spacers between all the loose cogs. The connected cogs don't matter enough to make a difference. The one issue though is that the short cage Chorus derailleur may not work with a 32 tooth cog.
But yea, I'm not planning on replacing the system. It's lasted this long and still shifts like new when I put a new chain on and keep it lubed.
Edit: I guess the widest 10sp Ultegra was only 30t anyway, so it wouldn't make much difference. A 12-30 Veloce would work much better.
