700 x 38c tires on a vintage bike?
#51
Reading through these posts, I'm thinking that 35c might be an upper limit on most vintage bikes with generous tire clearance (typically 70s era bikes that came stock with center pull brakes). Even most touring bikes back in the day tended to top out at 32c with fenders.
I have a Sekine SHS 271 (full tange frame set I believe) that I was thinking of converting to 700c wheels. It is currently running michelin protek 27 x 1 and 1/4 tires that measure out to 35c on my rims. There is no room for larger 27inch tire but I suspect it could take 38c tire. Whether there is enough room for a 700 by 38c when the rim thrown out of true by bad roads or for road debris is another question. You may well be right which is why a 650b conversion may be the way to go.
700x35 is a limit for easy to find 700 bikes. Approximately normal for older bikes.
One of the main reasons conversions to 650x38 has been popular is the available tires in that size were all really good tires. When your choices were Pacenti, Compass, or Grand Bois it was not possible to buy a slow tire.
If the possible switch is to 650x38 rather than 650x42 there is no reason not to remain with 700x35. The volume of air in a 700x35 is just about the same as volume of air in a 650x38. Then you have the simple fact that rolling resistance is inversely proportional to wheel diameter. The big wheel is faster. Jan Heine says that is not true but every cycling engineer from Archibald Sharp to David Gordon Wilson is on the other side and so is common sense.
It is a total mystery to me why people will spend real money and endless hours converting bikes to something they aren't rather than make a simple purchase of good tires.
#52
Quoted: 5924 Post(s)
Liked 3,595 Times
If you have been running Michelin Protek switching to Compass or Almanzo will be a total revelation. The Challenge Almanzo is labeled as 700x33 but stretches enormously.
I run the Michelin Protek tires on the Sekine as it is a commuter. I wanted a stout tire with a reflective stripe. I use different tires for bikes I ride long distances. If modding a bike to take 650b x 42c with cantilevers, you are opening up roads to travel on that you might not wish to ride on 700 x 35c tires. But I agree with your bottom line which is why make the switch to 650b if you can run a sufficiently large volume 700c tire which is why I was looking for a frame or bike that can take a 700 x 38c tire.
#54
Liked 3,595 Times
Yes, that's the point, I'd like to set up a vintage bike for gravel riding. I can get by on 32c. Heck I've ridden gravel on tubulars by letting some air out of the tires but there are all these nice high quality large volume tires coming out and I was thinking of setting up a vintage bike with 38c tires.
#55
Quoted: 76 Post(s)
Liked 19 Times
They just held the 1st Fountain Roubiax yesterday and it runs near where I live. One of the categories is vintage which requires downtube shifters and one piece of wool clothing.
#56
Señor Member
Quoted: 1517 Post(s)
Liked 1,140 Times
#58
Liked 3,595 Times
Right a 27 inch to 700c wheel conversion is pretty straightforward which is why I'm thinking a 70s era bike originally set up for 27 inch wheels with decent clearance might take a 700 x 38c tire. But maybe not because 38c might be pushing the envelope for a lot of frames.
#59
Señor Member
Liked 1,140 Times
That depends on the width of the tires. Here's the concern though.
The original rims' BSD is 630mm 650Bs are 584. 1/2 of 630 is 315mm 1/2 of 584 is 292mm 315 - 292 = 23mm difference in brake pad position from where the brakes were initially set. You may be able to find brakes with sufficient reach, but that would be something to determine before making a leap to 650B.
Many bicycles that have space for 38mm tires are designed for that, and have their brake bridges positioned so that there is also space for mudguards. Many of these bicycles come with long reach brakes, and while there's often room to adjust for 700c wheels (622mm BSD - 311mm radius), it is rare that there will be another 19 mm of reach. You might find something that works, but I think it is more likely to find a frame that fits 700c x 38mm tires.
Alternatives for 650B would be disc brakes (which poses even greater challenges, and I would not recommend), using a dropper bolt arrangement, or adding cantilever brake posts. I have no experience using dropper bolts, and have no idea if they also present challenges.
#60
Quoted: 7401 Post(s)
Liked 2,582 Times
You're right, Tom. And a higher pressure does improve the handling, but takes away some of the comfort. I've been experimenting with 35mm Paselas on our tandem, but there too, I'm inclined to go to 28mm, as I find the 35mm's somewhat sluggish, even at higher pressures.
I have a 1976 Raleigh Competition that will "technically" clear 38's, just barely. It does much better with 35's though (they give me about 1/8th" clearance in the tightest spots) and I don't notice much difference between the two, except that the 35's are lighter and perform better on the road.
Pic shows the Raleigh with 38's. I'm totally sold on the Reynolds 531 Raleighs, BTW. Fine fine ride, excellent geometry, generous tire clearance, can't say enough good things about them..
You have an accident waiting to happen. Your chain is too short, and you will accidentally shift into the big-big combination, causing some kind of breakage.
Not in my view. Long reach dual pivot brakes work well, even the no-name kind.
#61
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,059 Times
#62
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
So if you orignally had short reach brakes with 700c tires you will be hindered. If the originals were 27" "usually" no issue. It the originals had long reach or medium reach brakes or had fenders with 700C it will probably work, especially without the fenders.
My wifes bike it challenged with 28mm mainly due to how far the sidepulls can open when the QR is used due to the narrow rim width. She can run Compass 28s but not Conti 4000S II as they run closer to 30mm and also hit the crown and bridges or brakes.
#63
Polymultiplié
Bikes: Yes, please.
Quoted: 2223 Post(s)
Liked 4,836 Times
Speed is not my main concern, but I do care how a bike feels. I like to feel how a bike responds to road conditions, and experience the difference between bikes. It's also one of the reasons I like cotton bar tape.
But it's that inertia that is keeping me away from
#64
Virgo
@bikemig, you mentioned earlier you like old Fujis - I had (have) a '73 Special Road Racer that would fit a 700 x 38 tire under fenders. The SRR is a low end frame but you may be able to find a Fuji Finest or something similar that will have identical geometry/clearances. I only rode it that way once to test the fit/clearances and have no pictures of the bike with those wheels on it. The pads were already at the bottom of the slots on the 27" factory wheels so I'd have had to source some long reach sidepulls or the 750 centerpulls, but those are easy to find. I never converted the bike to 700c, I put the 27s back on it until I "retired" it.
#65
I sort of see your point, but the difference is likely in weight and increased wind resistance from a larger profile. Speaking for myself, the first factor isn’t big enough to trump the ride quality benefits of a wider tire, and I don’t ride nearly fast enough for the second factor to come into play. Ymmv.
#66
Liked 3,595 Times
#67
Liked 2,582 Times
This is the exact reason why I'm reluctant to post photos here, because some genius spots a toilet paper roll in the background that's hung the wrong way, a quick-release that's open (or a chain that's too short). The pic was for demonstration purposes only, I wasn't planning on entering any local races that way. Thanks for the warning.
#68
Quoted: 755 Post(s)
Liked 741 Times
While borderline to the C+V definition I am dialing in a 90's Koga Miyata CityLiner with big tires.
It looks like I will be able to get 38's and fenders but its tight. I had to bend the chain-stay fender mounting tab and now I have 4 mm clearance all around. The tires are Schwable Marathon plus HEAVY Duty tires that I all ready had and the rims are HEAVY Duty Velocity NoBS. I never got a chance to ride the bike before stripping it to a frame.
Taking it out now the frame is very flexible and feels overpowered by the wheel weight. I can grab the handle bars and shake the bike into an impressive shimmy. This is probably influenced by the quill stem adapter, and I'm going to try and snug up the headset.
Other issues are the raising of an already high bottom bracket and lets say "Sporty" steering. The steering is likely amplified by using a short stem, which I'm swapping out for a longer one, but I think there is an increase in trail caused by the taller tires.
Point being, I'm not sure that bigger is always better, at least with light frames and 700/27 wheels.
#69
Bikes: Yes
Quoted: 3291 Post(s)
Liked 4,069 Times
There are some center pull brakes with more reach than the R559 -- MAFAC RAIDs and Weinmann 750 come to mind. I tried the 750s and found them to weak with the pads all the way down. I hear the RAIDs are better.
My Bikes
My Bikes
#71
Virgo
And also I measure 66mm center of brake bolt hole to center of rim brake track front, 62mm rear. I hope this info is helpful, but if not it was a fun exercise.
#72
Liked 3,595 Times
#73
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
The widest tire I have on a vintage bike is a 27 x 1 1/4 which works out to 32mm wide, that's the widest I can get on that bike with fenders, remove the fenders and I could probably put on 36 or maybe a 38, but the rims I currently have on it wouldn't handle a 38 right.
#74
Liked 635 Times
#75
Not lost wanderer.
Quoted: 901 Post(s)
Liked 1,046 Times
I am running a bunch of larger tires on a bunch of frames.
I have a number of 27" bikes with 1 3/8 tires that are Vietnamese tires that run 40+mm; 2 Raleigh Grand prix and a 80s brit market Raleigh Road Ace.
I am running 700Cx42 Schwalbe Marathon Plus Tours on my 81 Centurion Pro Tour and 37mm Marathon Plus on my 83 Pro Tour.
I am running 700Cx35mm Panaracer Tours on my 78 Raleigh Super course and 700Cx37mm on my 74 Grand Prix.
I like big tires. I also have a 32mm on the front of my Zunow with a 28mm on the back.
Did I say I like big tires.
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
