Is it common to give Primes to a chase group?
#52
Quoted: 14 Post(s)
Not sure you got it? The gatekeeping tactic means pull off the front but then basically ride next to the next guy (the target) so he can't pull off. He then has to work even harder at the end of his pull to get ahead of you so he can pull off. Or he can softpedal to try to get behind you and everybody yells.
In my case this guy was in front of me in the rotation and just wouldn't push at all when it was his turn at the front or get out of the way. Almost like he was trying to hold up the chase group to let the break get away.
#53
Cat 2
If I understand this you have to be behind the guy in the rotation, then do your pull - stay out front during his pull and then some? It seems like this would only work if you are a much stronger rider than him? What's to stop him from pulling off to the right? Or just slowing down?
What you experienced was someone blocking, albeit in an inexperienced manner. The best way to block (in my experience) is literally to just roll off. It doesn't make people angry but it still disrupts the flow just so. If you are in a crit and don't mind some angry people, hit the front, give 3-5 hard pedal strokes then settle in at an easy pace. People will think you are working hard when in reality they just closed this little gap and you're riding easy. In a rotating paceline, you don't rotate at all. Just sit at the back forever and let the others in front of you make their little circles.
#54
Quoted: 14 Post(s)
You've got it backwards. If you want to tire out the guy behind you in a rotating pace line, when you pull off the front of the line (when its clear to your left) rather than letting up to let the guy come through really easy, you just hold the pace a bit higher than you should. Force him to work for an extra 15 seconds to get past your wheel. Works extremly well when you've got a rolling paceline going up hill and you're the better climber.
#55
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
I meant to say 'in front of' and thanks for clearing the rest up. Any strategies for dealing with someone who won't take his pull or blocking? I will be doing mostly crits and while I try to maximize my fitness chances are I will not be one of the stronger guys out there. I'm going to have to race smart to have any chance of doing well.
Also, yell at him. Every ****ing time. Nobody likes being yelled at and a lot of people will relent if they think they are making enemies.
#56
Ninny
Quoted: 686 Post(s)
Yelling, or other verbal communication, can be surprisingly effective in many situations. A personal favorite of mine is not to yell so much as to just express withering disappointment. "At least pull through Dave." "I hope you're not going to contest the sprint after all of this." Etc.
#57
¯\_(ツ)_/¯
Quoted: 967 Post(s)
#58
Quoted: 14 Post(s)
yeah - most people care more about being liked than winning races. This is both why @mattm s teammate owns me - he gives no ****s, and contributes to why I'm always 3rd/4th - I care too much.
It seems like any time the race splits into multiple groups if you don't do your share you reduce the chance of success for your group. IE - The break you are in is more likely to get caught or the chase group you are in won't catch the break. Either way you reduce your chances of winning.
At a weekly race series do guys try to team up with strong riders willing to do their share when they want to make a break/ bridge up to a break?
Obviously in a race with formal teams everything changes...
