chain tool idiocy....
Old 08-07-07, 01:39 PM
  #51
TurdFerguson2
Originally Posted by LUCAS
My coat hanger wire home-made tool has lasted me the better part of two years thus far. If it ever breaks, I am sure I can always find another wire hanger. It is just not about spending the money, but about recycling too.
Also, an old spoke works well. Bend a loop into it (where the circle part is on the pictured tool) and you get some extra springiness.
For whoever asked what those do, it holds the chain together so you can re-assemble a chain on the bike more easily. You stick the end hooks into some links in the chain.
TurdFerguson2 is offline
Old 08-07-07, 03:03 PM
  #52
Jed19
Jed19's Avatar
Liked 6 Times in 6 Posts
Yep. In my experience, any springy piece of wire with a decent size gauge, ductility and length will do.
Regards,
Jed19 is offline
Old 08-07-07, 03:21 PM
  #53
DannoXYZ
DannoXYZ's Avatar
Quoted: 109 Post(s)
Liked 9 Times in 6 Posts
Originally Posted by bfromcolo
OK this has been entertaining, but lest we lose track of the original question let me try again. I am having a problem rejoining links with my chain tool. Specifically sometimes I don't get everything aligned just right and damage the outer plate when trying to push the pin through. Perhaps the chain in question is not designed to be broken and rejoined. Perhaps I don't spend enough time cleaning my guns. Maybe I don't ride my oldest bike enough. Or fondle my brass parts too much. But assuming this was not the case here, how do you make sure everything is in alignment before you try to push the pin through?
The trick to this is to bend the chain-tool laterally to line up the pin with the opposite plate. Make sure the pin is PERFECTLY centered on the hole before tightening the chain-tool. I find that having the pin pushed up and barely touching the opposite hole allows it to almost self-centre. Then bending the chain-tool laterally will centre the pin. Then GENTLY spin the driver without moving anything.
Having good hand-coordination makes repairs a lot easier. Practice flipping quarters over and under all your fingers without dropping them. Then move on to rolling them.
https://www.youtube.com/watch?v=2cEa35Qib9U
https://www.youtube.com/watch?v=stzD0w8cefE
DannoXYZ is offline
Old 08-07-07, 07:58 PM
  #54
TurdFerguson2
Just to point out something that may not be obvious to some, when you break the chain, if you leave a little bit of the pin not pushed through the plate, you have something for the chain to 'hook' onto when you reassemble the chain.
Old 08-07-07, 08:06 PM
  #55
Bob Dopolina
Mr. Dopolina
Bob Dopolina's Avatar
Bikes: KUUPAS, Simpson VR
Quoted: 149 Post(s)
Liked 117 Times in 41 Posts
This was the prescribed method for 8-spd chains back in the day when you could pop the same pin back in the chain. It doesn't really help for chains that require replacement pins or links, though.
Bob Dopolina is offline
Old 08-07-07, 08:29 PM
  #56
mactheknife68
Always find my way home
Bikes: Madone, 8500
Why in the world do you need a spoke or hanger to hold the ends of a chain to rejoin them when all that is necc. to get the slack to ease the job is to lift the chain off the chainrings? All of the prev. mentioned solutions are for a problem that doesn't exist.
mactheknife68 is offline
Old 08-07-07, 10:01 PM
  #57
OneTinSloth
(Grouchy)
because sometimes, taking the chain off the rings doesn't give you enough slack, and you need something to hold the chain while you try to use the chain tool.
OneTinSloth is offline
Old 08-08-07, 07:07 PM
  #58
cadillacmike68
Campy NR / SR forever
cadillacmike68's Avatar
Bikes: 1977-78 Raleigh Professional - bought new, 1987 Shogun 400 (for the lady)
Quoted: 32 Post(s)
Liked 7 Times in 5 Posts
I've been using an old Cyclo chain tool same one for 30+ years, never broke a chain. turdfergusun's idea of leaving a little bit of the pin always helps. Granted these methods and the old cyclo chain tools may not work for new style 10 speed chains, but isn't this the C&V forum??
cadillacmike68 is offline
Old 08-08-07, 09:02 PM
  #59
mactheknife68
Bikes: Madone, 8500
It does if it's properly sized and run thru the small cog. Try it.
Old 08-08-07, 09:18 PM
  #60
robtown
Muscle bike design spec
robtown's Avatar
Bikes: 70 Atala Record Proffesional, 00 Lemond, 08 Kestrel Evoke, 96 Colnago Master Olympic, 01 Colnago Ovalmaster, 76 Raleigh Gran Sport, 03 Fuji World, 86 Paramount, 90 Miyata CF, 09 Ritchey Breakaway CX, Bianchi Trofeo, 12 OutRiderUSA HyperLite
Liked 3 Times in 3 Posts
I guess I have to take my dura-ace chain back for a refund - the box didn't have a master link or extra pins so I used a chain tool. I hate master links - for some reason I cannot get them to work. The first one I tried took an hour.
Korval is Ships
See my Hyperlite 411 it's the photo model on OutRiderUSA web page
robtown is offline
Old 08-09-07, 07:55 AM
  #61
DMF
Elitist Troglodyte
DMF's Avatar
Bikes: 03 Raleigh Professional (steel)
Originally Posted by cadillacmike68
... isn't this the C&V forum??
UMmm. No. It isn't. Just classic and vintage mechanics here.
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
DMF is offline
Old 08-09-07, 09:16 AM
  #62
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
New Shimano chains have a pin partially inserted in one end that is used to join the chain initially. You have to be very careful not to shorten the chain from that end when sizing it.
They also come with an extra replacement pin in the box, at least they used to, and it was easy to discard accidentally if you weren't careful.
HillRider is offline
Old 08-09-07, 10:53 AM
  #63
OneTinSloth
(Grouchy)
i install several hundred chains per month at the shop where i work, guy. i know how to do it properly, note that i said it is SOMETIMES necessary, and not OMFG I NEED TO USE IT ALL THE TIME LIFESAVER!!11! reading comprehension is not for everyone, i guess.
it doesn't if you have extra long chainstays (18inches), a road triple, and a long cage MTB RD for your 11-32 cassette on your touring bike, because chains only come stock with so many links, and i am sure as hell not going to add links to my 9-speed chains. also, some full suspension bicycle designs make it difficult to derail the chain from the small ring for installation, due to pivot and linkage locations, and bikes with chain retention devices often make it impossible to remove the chain without breaking it, so yes, the tool is necessary SOMETIMES. broaden your scope of experience outside of your own bikes and maybe you'd understand that. i'd rather spend an extra 10 seconds using the tool, than have to spend 10 minutes explaining to a customer why their $4,000 "all mountain" bike has scratches all over the main pivot. i seldom use that tool, but occasionally it comes in handy.
Old 08-09-07, 01:47 PM
  #64
HillRider
The "tool" takes maybe one minute to make, costs nothing and is very handy as it frees your hands to align the chain ends to insert the pin or master link with no difficulty. There is no downside to it and no reason not to use one.
Old 08-09-07, 10:38 PM
  #65
mactheknife68
Bikes: Madone, 8500
Touchy, touchy, touche'... And the name's not "guy", and yer not the only one with the wealth of knowledge based on expiriences youve had. I work with the same designs you do and have never been so careless as to be in the position to have to explain damage I'm careful enuf to avoid. It's been my personal expirience having wrenched for 10 years that it is an unnecc. step in what is a simple task. Having also dealt with the above situations (on my customer's bikes ), I respectfully submit that it is NEVER necc., based on technique. Is it useful? I think maybe. Is it necc.? I think not. I probly should have been more clear in my original post on this side-topic to the OP's original question, but I was in a hurry and dida driveby reply. Talk to the kids you work with like that but Ive been around awhile, too. I'll go back to my whisky now... I'll share
Old 08-20-07, 02:20 PM
  #66
mr.tool
remember, if you buy a new freewheel, you must buy a new chain,these parts ware in together.,never use an old chain on a new freewheel or a new chain on a old freewheelor you will have problems.
mr.tool is offline
Old 08-20-07, 05:27 PM
  #67
OneTinSloth
(Grouchy)
since the thread has been briefly revived, i thought i'd chime in...
the other day i had a cannondale synapse with an integrated BB, oversized carbon BB shell, and i definitely had to use that tool to hold the chain slack enough so that i could get the shimano pin through. i could've added a link to the chain, but since it was a compact crankset, i knew the guy would be cross-chaining small/small, and the chain would catch the RD pulley cage if it was any longer. i could've probably gotten by without it, but since the customer was bringing the bike in because he was having "skipping issues," which i confirmed was due to a connector pin that hadn't been pushed all the way through, i wanted to make sure there was no room for error.
Old 08-21-07, 01:37 PM
  #68
bfromcolo
bfromcolo's Avatar
I don't think this is correct. I agree that if you are replacing the freewheel it might make sense to replace the chain at the same time. But I think the goal is to replace the chain before the freewheel gets excessively worn so you don't have to replace both.
bfromcolo is offline
Old 06-16-16, 12:46 PM
  #69
KD5NRH
KD5NRH's Avatar
Bikes: 2010 Trek 7100
Quoted: 697 Post(s)
Originally Posted by DMF
According to Shimano, you should never remove the chain for cleaning.
According to the guy down on the corner, it's fine to drive while totally baked on the weed he sells.
Of course they don't want you taking the chain off to clean it; they sell replacement chains.
KD5NRH is offline
Old 06-16-16, 01:22 PM
  #70
DMF
Elitist Troglodyte
DMF's Avatar
[You really had to search to find a NINE YEAR OLD thread to spew in.]
I'll bet you ignore the recommendation for oil changes in your car, too. After all, the manufacturers SELL CARS!
Whatever happened to critical thinking?
- Will Rogers
DMF is offline
Old 06-16-16, 01:33 PM
  #71
KD5NRH
KD5NRH's Avatar
Quoted: 697 Post(s)
Have you looked at car manufacturer recommendations lately? 7,500, even on up to 15,000 miles for BMW. Of course I'd ignore those and stick with the 3,000-5,000 that has served me well for decades.
Critical thinking requires that even "expert opinions" like manufacturer recommendations be examined in light of common sense. Not properly cleaning a chain will cause it (and the rest of the drivetrain) to wear more quickly. A company that sells all the drivetrain components telling you not to clean your chain properly isn't looking out for your best interests.
KD5NRH is offline
Old 06-16-16, 01:49 PM
  #72
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
Pretty much all modern chains are not meant to be broken and pressed together again.
the modern chain is Only made to be shortened , then Joined By a Quick Link . Or a high end chain tool that expands the rivet Head again
to Be tight into the link plate hole (Rohloff, Campagnolo tools )
the hole in the side plate was stretched to get it off, the Chain making machine expanded rivet head, pin ends ,
It can never be more secure than if left alone, as it came out of the Box.
Chains back in the 5&6 speed era had pins that stuck out wider than the outside links , now(except for 1 speeds) they have to not stick out at all .
fietsbob is offline
Old 06-16-16, 05:30 PM
  #73
DMF
Elitist Troglodyte
DMF's Avatar
Critical thinking requires that even "expert opinions" like manufacturer recommendations be examined in light of common sense. ... A company that sells all the drivetrain components telling you not to clean your chain properly isn't looking out for your best interests.
Critical thinking also involves understanding the opposing positions. Shimano is not telling you "not to clean your chain properly". Instead, you are trying to introduce the axiom that one can only clean a chain properly by removing it. Obviously, others disagree.
So let's address that matter directly. How does one clean a chain properly?
- Will Rogers
DMF is offline
Old 06-16-16, 05:39 PM
  #74
KD5NRH
KD5NRH's Avatar
Quoted: 697 Post(s)
The first step would be getting it away from things that a good solvent will damage, so unless you're planning to remove the saddle, tires, RD, cable housings, paint, etc., from your bike, you take the chain off. Even if you've got a stainless bike with all chemical resistant components, trying to degrease it on the bike means all the degreaser, along with any gunk that was suspended in the chain, is going through your RD and dripping on everything else.
Anything else is like trying to wash your underwear without even taking your pants off first.
KD5NRH is offline
Old 06-16-16, 05:49 PM
  #75
DMF
Elitist Troglodyte
DMF's Avatar
Yeah, see, that's the thing. There is one school of thought that unless you are very thorough - like ultrasound and recirculating filtered solvent thorough - solvent merely moves a goodly portion of the dirt into the rollers, where it does far more damage than it did outside the rollers.
I know it's only a small data point, but I stopped deep solvent cleaning (except when changing out the drivetrain, where you want to keep the chain and cassette together) entirely, and my chains showed increased life. Over time I've learned to trust the engineers at Shimano, and I'll accept their recommendation since it seems to be supported by my (and others') experience.
- Will Rogers
DMF is offline
