Longest distance ridden on a flat tire
Likes For njkayaker:
#52
Quoted: 2741 Post(s)
Liked 492 Times
you know, lots of people ride back tires until they start killing tubes. Looks can be deceiving. Some people even think that tire manufacturers deliberately design tires to start showing noticeable wear and splits in the treads long before the structural areas are damaged, so people replace them more often.
#53
Quoted: 4018 Post(s)
Liked 7,528 Times
#54
Liked 492 Times
relatable.
I don’t like longer than the 60s cause I’m paranoid they will break off and I think they look kinda silly, but I keep getting burned by unexpected deeper wheels. I’ve been thinking of getting the 80s instead as my go-to but I can’t help but think that they will get broken off on normal wheels, so much exposed. Some bs on the road will get it.
#55
Quoted: 4317 Post(s)
Liked 1,394 Times
The tire in your picture was obviously bad.
#56
Klaatu..Verata..Necktie?
Quoted: 10589 Post(s)
Liked 12,195 Times
relatable.
I run only 60s now, because I have ONE (1) saddle bag that I move from bike to bike for all 10 bikes.
Likes For genejockey:
#57
Liked 12,195 Times
#58
Liked 1,394 Times
relatable.
The drugs go far to explain this stupidity.
#59
Quoted: 18560 Post(s)
Liked 15,975 Times
I’m having a “Forest Gump” moment, if you know what I mean.
Likes For indyfabz:
#61
Expired Member
Quoted: 3784 Post(s)
Liked 5,773 Times
Larry's long troll here on BF can give us a laugh, a cringe or just annoy us but it highlights an uneasy reality. Nearly half the population has intelligence below average. Ponder that with the usual percentages of true derangement and it's amazing we can function as a society. So thanks Larry (and a few others) for reducing these universal issues into the nutshell of BF.
#62
My back tube popped (tire is worn out so not going to try and replace tube) right as I was leaving work, I have to ride 6.5 miles home and then another 6.5 miles back to work before I can realistically fix it. I don’t think I have a narrow enough tire at home. It feels like a bucking bronco but it’s nothing unmanageable if I keep the speed down, luckily it’s just the back tire.
#63
Quoted: 9678 Post(s)
Liked 6,394 Times
1. The Earth is flat
2. Neil Armstrong and Buzz Aldrin did not land on the moon
3. There are alien remains at Area 51
4. Elections are rigged
5. "I am not a crook"
6. The rapture is coming
7. Princess Diana was assinated by the Royal Family
8. Birds are not real
9. The Denver airport is the headquarters for the Illuminati (which is led by Beyonce)
10. Zombies are real
11. The Holocaust did not happen
12. Aliens built the pyramids
13. 9/11 was an inside job
14. There is a secret chamber filled with government secrets behind Mount Rushmore
and
15. Steven King killed John Lennon
#64
Sunshine
Quoted: 11063 Post(s)
Liked 7,624 Times
I absolutely love that Larry apparently took pictures of this disaster and decided to log onto BikeForums and start a thread, in the middle of this struggle, and asked others how far they have ridden as if this is just a normal conversation topic.
Also, based on the first couple posts...
- Larry rode 3 miles on a totally deflated tire 16 minutes. Averaging over 11mph on a popped and completed deflated rear tire seems pretty impressive...or incorrect.
- Larry popped his tire right as he left work. He then says he couldnt repair the flat until he got home and then rode back to work. So apparently work is the only place he can repair the flat...and he got the flat right when he left work. Why not walk the bike back to work and fix it?
This place has become 90% entertainment and 10% value.
#65
Sunshine
Liked 7,624 Times
Likes For mstateglfr:
#66
Quoted: 407 Post(s)
Liked 599 Times
Some people even think that -
and
and
Likes For Steel Charlie:
#67
Liked 6,394 Times
Yeah, but the killing of Lennon is the most serious.
#68
Liked 12,195 Times
#69
Liked 12,195 Times
#70
Quoted: 7115 Post(s)
Liked 11,275 Times
#71
Liked 11,275 Times
Likes For Koyote:
#72
Liked 12,195 Times
#73
Liked 15,975 Times
#74
Liked 15,975 Times
#75
Anyway, beautiful day, I was doing an out and back . . and right as I turned around - rear tire was flat. I had a pump (of course!!) but no patch kit. I took my tube out - tried to patch it with a decal sticker I peeled off my frame - no luck.
A couple years earlier, I was out with my brother when HE got a flat. No patch kit, no problem! He chewed his tube in half at the puncture, Tied knots in either end of the tube, STRETCHED it back into the tire and inflated. A bit lumpy but it worked - for him! I tried the same trick, but my puncture was too close to the valve, I couldn't get the knot to seal on that end.
So I was stuck - this was central MN, middle of nowhere, and I was a poor college student. I couldn't afford to trash my rim, but knew I couldn't walk home. Rode the whole way on the gravel shoulder. When I'd cross a paved driveway, I'd shift all my weight to the front wheel. Took me at least a couple of hours to get home, but I made it. And my rear rim survived as well. In fact, it is probably still going - I gave that old Trek 412 to my niece.
Never made the mistake again of riding without a patch kit. 15 years later, I learned that an unmaintained pump will have you walking home as well - but that's another story!
