What's the best protection from punctures?
#76
Quoted: 4591 Post(s)
Liked 5,131 Times
If biking fast in a triathlon is the intention, I don't think fat tires are the way. Tri bike frames seem to max out at 28 mm, which seems to be an optimum (at least the manufacturers think so).
Unless you're riding really rough roads, you will be giving up watts with fat tires at low pressure.
#77
climber has-been
Quoted: 3558 Post(s)
Liked 3,726 Times
But for those TT and Tri competitors who have figured out the "not crashing" part, running fat tires would be a marginal loss.
#78
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 480 Post(s)
Liked 566 Times
My experience over the last few years is that while the folks I ride with are split 50/50 for tubeless or clinchers with tubes, almost all the flats are tubes. And the time to get back on the road for tubes is greater.
Yes, it is going to cost money to go tubeless. For about $850 Jen can get a set of Light Bicycle carbon rims on DT Swiss 350 hubs setup without any through holes so there will be no tape to futz with. Add another $80 and get a pair of Vittoria inserts. Finally, add $120 that I just paid for a pair of Goodyear Eagle/R tires and you have a top of the line tire. So for just over $1,050 there will be no flats, and even if there is a puncture that doesn't seal she should not loose control.
Triathlon is not a cheap sport, but that is not very much money for a performance and safety improvement. Or run some garden hose tires with tubes and hope they don't puncture or get a sidewall cut.
#79
Maybe you do, maybe you don't, but I would assume that even having a chance to finish a triathlon before the organizers pack it up and go home (i.e., what you do) would require more planning than just going for a ride after finishing work ahead of time (i.e.. what I do)?
I am considering the tubeless option. Need to resolve some debt issues first. Nothing major, should be good by end of the year. Maybe start shopping then.
#80
Liked 5,131 Times
Frame clearance will set a practical limit anyway. But 30 or 32 mm tyres offer a useful further drop in pressure, which makes sealant more effective and less pressure drop with a puncture. 28 mm might be fractionally faster on the smoothest roads, but it’s only going to be significant if you are winning or losing races by a handful of seconds. The focus for Jen appears to be more avoiding flats and potential crashes.
#81
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
It's a good investment whenever you're not riding on perfect / new pavement.
#82
Liked 5,131 Times
Same for me. Flats are a rarity on tubeless. I've had one in 3 years and it was a deep cut by a piece of sharp metal debris. It was on a fast descent and the sealant slowed down the air leak enough that I could brake safely before it went flat. It was actually the hissing noise that alerted me to the puncture.
#83
Bikes: two blacks, a blue and a white.
Quoted: 446 Post(s)
Liked 849 Times
Yikes, methinx. This has really gone hyperbolic. Get the Gatorskins or the Schwalbe's and get on with it. Don't overcomplicate it. And the "harshest ride ever" of the Gatorskins is a bit exaggerated. I have them GP5000 on the A-bike and Gators on the B-bike. The difference in the tires doesn't really change my day. Riding just under 70psi versus 90psi really does change my day - that's much more important to the ride quality than the compound (in my view). And I do have to "top up" the pressure in both bikes pretty much every other ride.
Likes For blacknbluebikes:
#84
Quoted: 5 Post(s)
Is "puncture resistant" an industry-wide term -- or is it defined acc. to the desires/whims of each particular brand?
#85
well hello there
Quoted: 503 Post(s)
Liked 339 Times
I've had a high speed, down hill, front tire, blow out that resulted in a crash. So I can relate.
I ride gatorskins and check my tires often for cracks, frays, shards of glass, etc. Safety first!
#87
Liked 5,131 Times
#88
Method to My Madness
Quoted: 2053 Post(s)
Liked 1,548 Times
Goes without saying that you have to hang them up. The more pertinent questions are what to season the tires with (Slime? Stan? Orange Seal? Dirt from Paris-Roubaix?), and whether to dry age (just hang) or wet age (wrap, then hang) them.
Likes For SoSmellyAir:
#89
Not as much as most here, probably somewhere around 50 or 60. Cycling is just one of several things I do, including swimming, skating, running and weight training.
#90
Liked 595 Times
Best - ultimate - super duper effective - puncture protection is to not ride. I confirm that you will NEVER get any. 100% guaranteed or you get your money back.
#91
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
I'd recommend tubeless for various reasons but flat protection is a big one. I only have one bike that has tubes. I rarely use it outside but I did the other day. I would have been fine normally and even with tubes but the county had closed that long bike path on the way back home. So it detoured me and I had to ride by some construction areas where the tractors/backhoes had churned up the dirt onto the other path and I eventually ran over some goatheads...instant flats on both tires. Good lesson. That weekend I converted that last bike to tubeless since it also has tubeless-ready alloy rims. I have been tubeless on the road for a few years but gravel for many years and MTB since 2004! Once you pick up the nuances of tubeless, it is foolproof.
One caveat- I only use water tires that lend themselves better to tubeless. I use nothing on the road below a stated 30 and usually 32 is it....the 32s measure 34. I run lower PSI on my primary road bike (55-60) and that is good for tubeless. A 25 at 90 PSI will not work as well. I have had it work but the pressure will drop significantly and you may have to spin the hole to the bottomed bounce the wheel on the ground if you hear the hiss of escaping air. It is the only time I actually heard my road tubeless losing air. It dropped from around 80 PSI to around 50 PSI and sealed up. It was a fragile (Schwalbe) tire around 200 grams. Still, it was fine form then on.
#92
As long as this thread is still alive, can someone please explain to me where these mysterious "airless" tires are? Manufacturers (at least auto tire manufacturers, e.g. Goodyear, Bridgestone, Yokahama, etc.) have been teasing people with flat proof "airless" tires for at least 30+ years. Seems like bicycles would be a very easy and cheap market to do some real-world testing.
#93
climber has-been
Liked 3,726 Times
#94
Quoted: 3261 Post(s)
Liked 2,577 Times
If one rides at night/in the darkness, a cross and a garlic necklace are good defenses against certain types of punctures.
#95
Quoted: 480 Post(s)
Liked 566 Times
Case in point: last Sunday morning I was riding along at about 25 MPH riding on a sweeping curve minding my own business when I heard the distinct sound of air and sealant rushing out of my tire. I knew that this had to be a large cut. Much more than just a staple or a screw in the tire. The issue at hand now is to decelerate from 25 to 0 in a controlled and non-destructive manner...
It did turn out that I had a slice that was too large to plug with a single bacon strip. My experience with tubes (even with sealant) is that a large slice at speed while turning is not a good situation. While it is not the best way to end a ride with tubeless, my tire did not unseat from the rim and I didn't wind up hitting the deck. I am aware that tubular tires also offer this benefit, and I suppose that tubeless tubulars might be the best solution, but I find the gluing process to be more of a phaff than tubeless clincher tires.
#96
So it happened again today. Another *%$^@$ goathead thorn got me. Realized about 20 miles into my ride, which also happened to be exactly half way between my house and where I parked my vehicle.
Then I had to do something I've never done before. I accepted help from a passer by. A lady stopped and asked if I needed help. Since the patch on my spare tube failed, I really had no other option so we loaded my bike in the back of her SUV and she drove me back to my truck. When I got home I checked both tubes and found the holes. I just bought some new rubber cement because I was concerned my old can had started to deteriorate. We shall see if my new repairs take.
#97
Liked 5,131 Times
#98
Quoted: 682 Post(s)
Liked 456 Times
#99
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 606 Post(s)
Liked 877 Times
They may be a bit slower - but Armadillo Elite tires are fairly bomb proof. The rubber compounds they use have improved over the years, so they are not as "rubber hose" as they were before - but these tires just resist punctures.
I've had two flats this year with my GP5000's, had multiple flats over the years with my Turbo Pro's - zero flats with the Armadillos. They are slower - but for training purposes, speed doesn't really matter.
Edit:
I've been reading up on riding Mt Lemmon in Tucson - the local bike rental shop mentions goat heads, talks about not using race type tires, and equips all of their rental bikes with Armadillos.
#100
Liked 1,548 Times
