When Do You Replace Shifter Cables?
#76
Quoted: 249 Post(s)
Liked 473 Times
Where did the cable break?
In the shifter? At the "pinch bolt" where it is secured to the front derailleur?
Where it breaks may tell the tale of what may have happened.
I see some bikes that come into the shop for service that the pinch bolt was far too tight and has crushed the wires. Over time and movement...shifting and braking...the wires continue to break and the cable fail. It doesn't happen often but possibly with a harder than normal shift and fraying wires a break will occur.
I ride around 10K plus a year and was on 105 11 speed for a bit, now Ultegra R8000 and have never broken a cable.
I had my last bike, Merlin/Campy Record, for 22 years and never broke a cable.
It may be possible that you are applying more force than you think. You do state you are a relatively new rider and often newer riders make mistakes that more seasoned riders do not. Learning how to shift is often not as easy as it may appear especially shifting under load...shifting under high pressure applied while pedaling. That can cause all sorts of interesting things to happen to a bike's drive train.
Just a couple of things to think about.
I usually change my cables every couple of years during the winter months...now with Zwift there is no such thing as winter time off lol.
Regarding age and respect...I know a few elderly people that are flaming a holes and deserve no respect...age doesn't give wisdom nor requires automatic respect...it does, at least, mean you have survived...and I'm 66.
Likes For Kai Winters:
#77
Quoted: 3631 Post(s)
Liked 3,057 Times
I run Dura Ace 7700 downtube shifters. Never had a shifter or brake cable break. Glad I never went STI.
#78
Klaatu..Verata..Necktie?
Quoted: 10601 Post(s)
Liked 12,207 Times
$3? What kinda cheap-ass cables you run? Galvanized?
#79
Quoted: 20810 Post(s)
Liked 9,456 Times
#80
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
#81
Liked 3,057 Times
I’m equally sure you’ve heard the term ‘a-hole...’
Likes For smd4:
#82
Bikes: lots
Liked 2,932 Times
Hey bud, referring to you as a luddite is not necessarily a bad thing...calling me an a-hole? C'mon, lighten up.
#83
Liked 3,057 Times
#84
It was a good opportunity to invest in fancy new cables (but not too badly priced, at least compared to the Canadian prices) that I'd likely not have bought if I were just replacing worn-out cables. With worn-out cables, I'd have just replaced them with my normal ones, but the failure made me experiment a bit and I've never braked or shifted so smoothly.
#85
Quoted: 430 Post(s)
Liked 274 Times
3 different liv's ( gravel bikes ) around 2k cables broke ( have 3 friends that all bought the same gravel bike )
giant revolt adv 2 ( gravel bike ) around 3k cable broke
topstone alloy shimano 105 ( gravel bike ) shifter cable broke around 2k
system six road bike sold with almost 4k miles on it. still shifted like new. zero issues. road like new
Seems like my road bike could have easily gone to 10k miles with no issues. I barely had to touch it. The gravel bikes require constant tweaking. I ride them on a lot of mtb bike trails.
#86
Bikes: Casati Laser, Colnago Tecnos, Ciöcc Exige, Black Mountain Cycles Road
Quoted: 129 Post(s)
Liked 177 Times
I have Campagnolo shifters and cables on my four bikes. I’ve had a cable come loose (once), but have never broken a cable. I do change them, but not often — maybe around 10,000 miles.
#87
I just replaced the Shimano Altus rear derailleur shifter cable on my 4 year old Trek Marlin 7 which has about 2000 miles on it and has been my all-weather, all terrain bike so things have been wearing more quickly. I noticed that the housing was fraying and showing rust at the upper insertion point in the downtube. When I pulled the cable I didn't see any fraying but decided to put in a new cable just to be safe.
#88
I'm riding DA and have to replace the RD cable around every 9 months. The cable eventually starts fraying at the shifter.
#90
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
