Anyone try out the CarBack?
#76
Thread Killer
Quoted: 3234 Post(s)
Liked 1,789 Times
We have all sorts of standards for all types of products and applications, so the USB-C thing is nothing new, and while it may constrain widespread adoption of a new plug type and require legislative action to get replaced, it doesn’t preclude that, and the potential upsides of the standards are very high compared to the “wild West” scenario we have going on now wherein proprietary plugs and protocols are employed primarily to constrain consumer options and control retailer behavior.
#77
ignominious poltroon
Quoted: 2301 Post(s)
Liked 3,535 Times
USB cables (like RS232 cables) were designed primarily for data transfer, and using them for charging and powering devices has always been a secondary application.
Wireless data transfer is the default on my Edge 530. Over 90% of the time that I use a USB cable, it is to charge the device, rather than transfer data (and I probably do that more than many users). The upgrade on the 540 (and others in the current generation) to USB-C is because it is a better standard for powering and charging devices. The fact that it is vastly better for wired data transfer (which is why Apple was an early adopter) is a secondary concern for most users, but the fact that the same cable could charge all of your devices, transfer data to your hard drive, power and drive your computer monitors, etc. is a huge plus. The physical dimensions of the USB-C cable ends might make them stick around awhile. Presumably the EU forcing Apple and others to make it the standard charger for all devices is based on such arguments.
At least if it is changed in the next 5, 10 or 20 years, it is less likely to be on a whim.
I think the only reason it hasn't replaced HDMI (which would be a vast improvement) in AV applications is that the digital copyright police don't want to lose control.
#78
Quoted: 7142 Post(s)
Liked 11,319 Times
Apple Watches use wireless charging, which is super convenient since they need charging every day or two. I wish my Garmin watch had that feature, but it's not a big deal since I only need to charge it every 2-3 weeks for an hour or two.
#79
Thread Killer
Liked 1,789 Times
https://ec.europa.eu/commission/pres.../en/IP_21_4613
https://www.europarl.europa.eu/news/...eality-in-2024
#80
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 168 Post(s)
Liked 153 Times
Anyone order one of these on-line? I just looked, seems TREK wants you to pick yours up in one of their stores. I'll try asking tomorrow if one of the four local-to-me stores (within 200 miles) will ship one; otherwise the closest is about a two-hour, one-way drive for me.
#81
Liked 11,319 Times
#82
Liked 3,535 Times
Garmin will ship theirs to your door. Bike tires direct has it on sale for $30 off today and will also ship it free. It is proven technology.
#83
Quoted: 168 Post(s)
Liked 153 Times
True enough, and that's made clear on their webstore pages.
Still, for me to drive four hours to save maybe $15 in added shipping (there's a local service called Speedee here in the Midwest that's vastly cheaper than UPS, reliable enough and faster than USPS) isn't an enticement to purchase.
Today's not yesterday! BTD's search doesn't reveal where they're hiding theirs today, sadly. Lot's of Garmin stuff, more brands. (Thanks for pointing out a new-to-me vendor though, I'd not heard of them before reading your post!)
I've used Garmin stuff before, would rather this time instead give another brand a tryout.
#84
Liked 3,130 Times
#85
Quoted: 4605 Post(s)
Liked 5,145 Times
#86
Liked 3,130 Times
#87
Liked 5,145 Times
Good point, but it's nowhere near as bad as it sounds ie. it reconnects instantly, so you just get a pop up warning, maybe once or twice on a century ride. Some of my other sensors momentarily lose connection, but they don't give a warning because they are not safety critical like the radar/light.
My main issue with Garmin is their UI. I use an Edge 530 and once they solved the mid-ride freezing issue (a major issue) on its release it has actually been very reliable for 3 years. But I just don't like the UI embedded menus as they are not very intuitive if you need to change anything. But on a daily basis it is fine and I like the route navigation.
#88
Liked 11,319 Times
Well, you didn't mention being four hours from the nearest Trek dealer.
Varia works fine, as Polaris OBark explained.
#89
Quoted: 168 Post(s)
Liked 153 Times
Yep, my major complaint with stuff of theirs I've used before.
Found a 'chain' of bike shops since seeing the post that piqued my interest yesterday. They have a 'deliver to address' option prominently featured on their web store page.
I may go that route if not an unreasonable amount of money to avail myself of that option.
Thanks all for your comments.
#90
I'm happy to recommend the Gardia 300L as an alternative. Is it, perfect? No, but it's pretty darn good. I also think it looks better, sleeker, better designed and cheaper. I use a Wahoo so I am not married to Garmin (except for golf).
Likes For howaboutme:
#91
Liked 5,145 Times
#92
Liked 11,319 Times
Just to be clear, UI is not a problem with the Garmin Varia as the default display is fine and there is very little setup involved - mainly just choosing flash modes on the light, which is fairly easy. It's one of their best products for sure. I have the 515RTL, which is 3rd gen and well sorted
After trying an Edge 530 computer, I did hate Garmin's UI. Just getting it configured took about two weeks and involved pushing countless buttons in order to drill down into menus, sub-menus, and sub-sub-menus. It was awful. And then when I got it all set up, the BT went all wonky. But all that is a non-issue with the 1040 Edge, as the touchscreen makes setup a breeze and allows me to modify it quickly -- even while riding. Ditto with my Garmin Fenix 7 watch. I don't think I'll ever buy another of these products that doesn't have a touchscreen.
#93
Liked 3,130 Times
garmin radars will need to go wireless charging to make it have one over the rest now.
-Oh Hey!
-Oh Hey!
#94
Liked 11,319 Times
#95
Liked 5,145 Times
#96
Liked 5,145 Times
Yep, Varia is simple and works nicely.
Likes For PeteHski:
#97
Liked 3,130 Times
#98
Quoted: 168 Post(s)
Liked 153 Times
I'm 're-treaded' (my compromise with being 'retired' since I'm 75 & still work three days a week) so 'disposable' dollars are watched carefully month by month.
Garmin's Varia products range from $99.99 (RVR315) through the same $199.99 (RTL515) price point as the TREK @ $199.99 on up to significantly higher top end RCT715 @ $349.99.
So as this for me is a foray into a newish realm, I'm willing to go with a mid-range competitor, see whether it offers anything worthwhile to my admittedly recreational biking pursuits.
Roads where I ride I might be sharing with anything from a horse-drawn wagon up through 18-wheelers from time to time. What might widen my perception of what's coming up behind me (I've used a smallish handlebar-mounted mirror for maybe two decades) ought to be worth the expense.
Got an e-mail mid-morning that the TREK device I've ordered has shipped already. So — weather permitting — I might be able to provide a user review soon: Wheelandsprocket.com, shipped USPS Priority for no extra charge over retail + sales tax.
Random thought: might these things show up as an active radar transmitter on radar detectors used by drivers?
#99
Liked 3,130 Times
S'truth!
-Oh Hey!
-Oh Hey!
#100
Clark W. Griswold
Quoted: 4504 Post(s)
Liked 4,190 Times
I do love my Garmin Varia eRTL615. I was initially looking at it for just the radar and add another rear light but the light on it is so excellent I don't think I will. I will admit currently for most of my riding in the city the actual radar beeping is a little less useful but the light pattern at the back which changes when a car comes near really is quite nice.
