Hot deals - post 'em if you got 'em.
#1076
Quoted: 686 Post(s)
Liked 5 Times
As far as I know, the shifters are just buttons and can be interchanged...the derailleurs are a bit different.
Art's Cyclery Blog » Ask a Mechanic | Upgrading 10-speed Di2 to 11-speed
How to Convert Shimano 6770 Ultegra Di2 to 11 Speed | Fit Werx
#1078
#1080
The 6770 shifters work with the 9070 and 6870 11 speed components but you must have 11 speed front and rear derailleurs. At one time you could even get away with using a 10 speed front derailleur but the latest firmware updates removed that option.
#1081
Nice, are you picking up spares or putting together a new system? If your putting together a new system, wait for Performance to have another $50 off $199 or more sale like the one they just had. You can get the 6870 11 speed derailleurs for $149ea and the internal battery with charger/interface for $165 then you just need the junction boxes and a few wires to make it work. If done right and at the right time you can get a full Ultegra Di2 group for around $650-$700 and once you ride electronic you'll never want to go back.
#1082
#1083
Thanks for the info. I have a function Ultegra 6800 on my primary road bike. I would love to put DI2 on it but don't want to spend more than 500 bucks (in no hurry either). Now that I have the shifters for 50 bucks, I am left with 450 bucks to spend on the rest. Besides the 6870 derailleurs what else will I need?
Front Derailleur
Rear Derailleur
Battery
Charger
Front Junction Box
Down Tube Junction Box
E-tube wires as follows;
L shifter to junction A
R shifter to junction A
Junction A to lower junction
Lower junction to battery
Lower junction to front derailleur
Lower junction to rear derailleur
#1084
Quoted: 276 Post(s)
Liked 6 Times
You can get 6870 upgrade for $774 shipped from Merlin
Shimano Ultegra 6870 Di2 Gear Kit | Road Bike Electronic Components | Merlin Cycles
#1085
It may be doable at $450 but you'll have to be patient. Here's a list of the other stuff needed and although you'll more than likely use Ultegra 6870 components you can also use the 9070 Dura Ace components too.
Front Derailleur
Rear Derailleur
Battery
Charger
Front Junction Box
Front Derailleur
Rear Derailleur
Battery
Charger
Front Junction Box
#1086
Nice Find! Double check that the external batteries are compatible with 11 speed, I'm not 100% sure on that?
#1087
Will definitely look into it. However, in case its not compatible, I doubt the frame I have is compatible with an internal battery (I dont want to drill holes for cable routing). Will I be able to mount an internal battery externally?
#1088
wears long socks
I know someone who mounted one in his steerer tube.
Only problem was he had to recess the star nut waaaaay down and had to use a threaded rod to re-tension his stem/headset whenever he needed to take off the stem.
He ran the cables just like external ones from there.
#1089
Here's a link to a guy who knows everything about di2 - CarltonBale.com » Shimano Ultegra and Dura-Ace Di2 Electronic Shifting ? Everything You Need to Know
#1090
Interocitor Command
EDIT: Deal is over. Ended at midnight. Back up to $11.
Nashbar has Boeshield-T9 for half off. I've never seen Boeshield this low. Four ounces for $5.49. Buy 9 bottles to get free shipping.
Boeshield T-9 Drip Lube 4oz.
#1091
Nice little vest with three rear pockets on sale. I know it being Cannondale may be a deal breaker for some but thought I would post anyway.
Cannondale LE Vest
Cannondale LE Vest
#1092
Bikes: Canyon Endurace
Quoted: 1047 Post(s)
Liked 934 Times
Boyd Cycling has some sweet deals with some closeout prices on the 2015 models.
2015 Closeouts!! - Boyd Cycling
#1093
nashbar has 25% off any single item including bikes. It puts the carbon 105 bike at $915 shipped. Does it get any cheaper than that?
#1094
Quoted: 38 Post(s)
Nashbar has 25% off any single item currently. Which isn't that unusual. Typically when they do this they raise the price of the item so really it costs the about same amount. However when I looked at the website this morning they had not yet raised the price up to acommadate the 25% off. Or at least not on the CR-5 road bike. Currently the site shows it for 1750 plus 25% discount. When I put it in the cart it wanted to show the price at 2,000 minus a 25% discount. Called them and explained and she honored what the site showed. I got a full Ultegra carbon 11spd road bike for 1,327.48 shipped. That's unheard of for a full Ultegra 11sp carbon. If you are interested I suggest acting fast because I suspect they will change the price back to 2,000 pretty fast. Be warned though some of the sizing on their bikes can be a little screwy.
#1096
Bikes: Lynskey R230
Quoted: 14 Post(s)
I got the same price but it's not a carbon model, but other than those cheap brakes it looks to be a great deal. I'm seeing $1665 shipped on carbon/Ultegra model.
#1097
Shimano Ultegra 11 Spd 6800 Brake Set, Brakes, BRAKES ROAD
#1098
Quoted: 38 Post(s)
My order was definitely a carbon road bike. CR-5= Carbon Road 5. I agree the brakes are not the best but, the rest is all Ultegra. I could replace with Ultegra brakes for not too much. $1,327.48 shipped to the house
#1100
Are the frames and wheels together worth ~ $1000? (This is a serious question. I am not very well aware of nashbar branded products).
