Time to rescue a stuck, jungle junker. The 1986 Jim Merz Allez!
#101
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Liked 700 Times
Another tip from dddd in an earlier thread about one of my stuck seatposts - you can use a bent, sharpened spoke as a probe to make sure the cut is going all the way through the aluminum at the bottom of the seatpost. The cutting leverage is much less at the bottom, so when it seems like the saw blade is all the way through, it probably isn't. It is surprising how helpful it is to be able to grok what is going on down in the tube using the spoke-probe.
Likes For albrt:
#103
Ride, Wrench, Swap, Race
Liked 1,327 Times
I've used a dremel wafer disc to carefully sharpen those few teeth out at the tip of the (usually long) blade, it's where the cutting action is (still won't cut into the steel seat tube).
#104
Bikes: A few too many
Liked 2,193 Times
Really interested in this project, any updates? ![Big Grin](images/smilies/biggrin.gif)
Best, Ben
Best, Ben
Voltaire
Voltaire
#105
The Huffmeister
Bikes: 1965 dept store special, 1972 basket case, 1978 garden ornament, 1980 garbage heap, 1987 mutt, 1996 frankenstein
Liked 3,820 Times
#106
www.theheadbadge.com
Liked 4,519 Times
#107
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Liked 97 Times
#108
The Huffmeister
Liked 3,820 Times
Likes For AdventureManCO:
#109
The Huffmeister
Liked 3,820 Times
#111
Liked 2,003 Times
Ah Yes! Trees are a wonderful thing when working with block and tackle set ups. I have seen many a race car frame bent back into shape with the same method. I am partial to the multiple pulley set ups as the amount of pull will be exponentially higher with about 200 feet of rope. And with that much rope we can use Cuda's "more door" to put a significant amount of pull on the seat post. Har! Smiles, MH
#112
The Huffmeister
Liked 3,820 Times
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/5306fa7e_736e_45bb_94bd_5f7e0f1ad4d4_70f4138c9f5db7b8380bd7a064134f6c09556c61.jpeg)
There were 135 Confentes, but only one...Huffente!
![](image.php?u=133054&type=sigpic&dateline=1681526263)
#113
Edumacator
Liked 3,374 Times
Is it good news or bad news that we are not seeing the frame...?
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
#115
I see slash at the bottom, but not at the top. I'm not sure that's a good sign.
#116
The Huffmeister
Liked 3,820 Times
Okay, morning update! Sorry had to 'cliffhanger' it for a moment there![Big Grin](images/smilies/biggrin.gif)
Post is out! But not without slight consequences!
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/9aa9a905_38b0_4ca5_8719_ddbe798ab9f0_d42aab9fb4ab168130ae06cf61b3023e0342170e.jpeg)
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/11829ba2_e934_4cc9_84f9_016ce72323e8_47271e3035b9a5c2b759a9f2d4442c0ad2394178.jpeg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/b0b6911c_703a_4da3_b82e_6932f3ec5140_9d9dba07be8578f62b90f81bafa3c11243ecf019.jpeg)
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/03f49047_dcdf_4d5e_ba37_34540f02a1ac_7af33645459dc8363525f2ed225436612863a9bc.jpeg)
The bad news is that this process (ahem...me) scored the inside of the seat tube. Good news is that the bike is fine, and I'm not sure one could really be successful at this process without at least some scoring of the tube?
![](https://cimg0.ibsrv.net/gimg/bikeforums.net-vbulletin/1710x1934/667cef35_85e0_4dc2_a57b_ed26a2fb1b9c_bbe318a1c4e51a660095667a37adc806aa246d0f.jpeg)
Now, before any of you jump up and down w/ thinking it was a 'rush job', this one was about technique and not attitude. But! In thinking about how I went about it, I'm struggling with coming up with how I would have done it differently, at least using the same technique.
I did this over several days, so it wasn't rush. I didn't use power tools. In fact, I took the thin blade out of my hacksaw and held it by hand, and made the cut all with human power - which was not a fast process, because if you pushed too hard, the blade would just bend and twist, so I figured that would give me a bit of a buffer. I also took the suggestions of others in this thread - I decided to cut the bottom part of the post (the stuck part), and angle it ever so slighly away from the top of seat tube opening, so that the cutting action was focused around the stuck part, and utilizing just the very front tip and teeth of the blade as the cutting action (more of a 'gnawing' at this speed). Wasn't rushed...took me hours. Used penetrant oil. I even made the tool folks suggested out of a sharpened and bent down spoke as a 'feeler' to tell when I'd gotten through the alloy. I felt the difference between the aluminum and the steel, and moved up to a new section when I first started feeling it.
But still it left a little groove there in the steel. Now its not much, mind you, but the diameter of this steel is not much, either!
So, pretty happy the post is out, and also pretty disappointed I somehow didn't stop in time, given all the indicators I had working w/ me. Maybe this is just par for the course? I showed it to Jeff (DD) and he seemed to think it wasn't a big deal. I think in time I'll agree w/ him, but sort of had that cloud hanging over me when I saw (sawed?) it. In any case I cleaned it up and threw just a tiny bit of JB Weld in that spot and w/ sand flush. Again, hoping it's just cosmetic and since it isn't a real high stress spot, I'll just make sure the next seatpost that lives there goes a bit past it. In time, perhaps I will also grow, and learn to more quickly count my blessings - it could have sawed all the way through and didn't! I'll take it.
I don't think I will use this exact technique again. Pretty sure I'm just going to jump to lye. But! If I did decide to use the sawing method, I would create a tool that was round, with a slot to hold the blade and make it w/ some recessed grub screws, so that you could take a measurement of the seatpost thickness, then replicate that thickness w/ the amount of blade sticking out of the tool, verifiable by calipers. That way, when you reached the end of cutting the seatpost, the blade would be prevented from cutting further. That's the only way would want to use the cutting method again.
I'm just glad this happened first on the Merz Allez and not one of my beloved Huffys![lol](images/smilies/lol.gif)
ALSO! I started playing around w/ the stuck, frozen stem. Much to your not-knowledge (?), I had been soaking the stem for a long time, and thought I'd give it a go to break loose.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/83a813d2_0a6f_45a9_adb6_d83c2a3c8564_ec02a2641fe973546a8fc84402b579da557524c3.jpeg)
The technique I wanted to use, the one that helped me free my stuck stem in the PX-10, would not work this time, because it requries access to the bottom of the stem, up from the steerer tube. I couldn't get the wedge out of this one - there was some kind of goofy stuff in the steerer tube (it almost looked like the remnants of some other stuck stem that was welded to the side of the ID of the tube (really weird)...in any case, it wasn't coming out the bottom for me to gain access to.
So, I'm glad that cudak888 posted up his prying method using the handlebar clamp of the stem. I had this giantic 30+ lb prybar, and though it would do swimmingly. I clamped the fork crown in a vise (using rags and wood blocks of course), and went to town!
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/d72e64ac_3c0d_457e_ad59_49b9f59d1536_72b447162c1bcd052096c833017b4c72f69f7c5d.jpeg)
Good news is, I think I moved it a hair. I had quite a bit of leverage w/ this bar, and I did get it to clock about 3-5 degrees.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/7a93163b_45ef_46ba_a6d3_c6d1e5a2959b_3ad9f0ac963070a282a7c7dda3de0ace3c816fe9.jpeg)
So I put more penetrating juice down that and will let it sit a few more days and see if that assists with the process.
So far, its been quite the adventure. If you don't end up almost destroying your bike, multiple times, when you are rebuilding your project, you're not really living.
#117
Edumacator
Liked 3,374 Times
'Tis but a flesh wound.
#118
The Huffmeister
Liked 3,820 Times
#119
Liked 700 Times
I'm pretty shocked to see the cut into the seat tube. I saw no hint of that on the two quality bikes that I used a vertical hacksaw cut to get the seatpost out. I was applying very little pressure to the blade and was only leaning the blade slightly inward, away from the top of the tube, so our techniques were a little different in that respect. My seatposts were also inserted much deeper, so the angle was necessarily shallower.
When I did it, the blade was cutting along more or less the whole length of the post, and the bottom was the last part to go all the way through. The aluminum is soft enough that the teeth can do the work without much pressure. I think the small amount that I was leaning the blade away from the top of the tube was not quite enough to counter the leverage effect that reduced the force at the bottom of the post, so the bottom part took the longest even though the blade was leaning the other way.
#120
Liked 2,193 Times
Ok, Now back the the Porsche back story.............![Innocent](images/smilies/innocent.gif)
Best, Ben
Best, Ben
Voltaire
Voltaire
#121
The Huffmeister
Liked 3,820 Times
It's all good
![Thumbs Up](images/smilies/thumb.gif)
After trying both, and seeing what potential this method holds, I still like the idea of the lye method better, at least for lunkheads like me, since it is absolutely foolproof for not damaging the steel frame, 100% everytime.
But the important thing here is...the Allez will live.
Now, just gotta get that stem out.
#122
The Huffmeister
Liked 3,820 Times
#123
Liked 4,519 Times
-Kurt
Likes For cudak888:
#124
The Huffmeister
Liked 3,820 Times
You dodged a near bullet and got away with it. Have a beer, congratulate yourself on a job well done, and forget that it is there.
Don't wait for the penetrant. If it moved once, it'll move again; just alternate your direction and push/pull like it owes you all you spent on the Huffy. It'll pop again. Alternate back. Continue. You can do this. This isn't the bike shop anymore, this is the gym.
-Kurt
-Kurt
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/aca53f8a_ccd4_4e16_9cf5_ce7de39c269c_f7630b79147840bf3356f55037d3eea5fe8aa0f6.jpeg)
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/726bec4b_3269_49e8_ba30_28a3cd712f12_e126ca6cb1f0a1b559de97b55f90975e9e30a79e.jpeg)
