Suntour versus Campy
#101
Quoted: 3261 Post(s)
Liked 2,582 Times
Mmmmm, hmmmm...... next thing you'll be telling us is that Delta brakes work.
But seriously, I have to admit I've never ridden the high end Campagnolo stuff from the same period as when Suntour was the best. I really should find something equipped with it and give it a try. If it truly does feel better to use than my beloved Superbe stuff that will make for one orgasmic ride. Dang it, I don't need another bike, but now I'm curious.....
#102
Quoted: 1630 Post(s)
Liked 2,254 Times
@Drillium Dude - Jeff, were those Superbe Pro parts?
#103
Quoted: 2350 Post(s)
Liked 5,307 Times
Speaking of Delta brakes, beauty is definitely in the eye of the beholder. To me they look like a dude in overalls(from about mid spine) laying pipe to the mounting hole on the fork. Maybe that was the design intent. What do I know though, I think a Campy NR RD resembles a marine invertebrate.
Everyone should have at least one bike with Delta's on it.
Oh crap, wait..... I'm supposed to be playing the Suntour fanboy in this thread. Please ignore the above....
Steel is real...and comfy.
#104
Liked 2,582 Times
I can hear the dualing banjos now...........and the "Squeal like a pig." Or, "Spider caught a couple of flies."
Likes For seypat:
#105
Quoted: 2588 Post(s)
Liked 4,827 Times
And, just to pile on with the fun, I suggest an alternate title to this thread: "Tell Me You Can't Afford Campy Without Telling Me You Can't Afford Campy".
DD
#106
Liked 4,827 Times
DD
#107
Quoted: 1846 Post(s)
Liked 3,484 Times
Steve in Peoria
#108
Liked 5,307 Times
Curious about the brakes too though. I'm running the CB-4700 on my Team USA "gravel" rider and the brakes seem plenty strong with the old Fulcrum Racing 1 rims on there. I was worried about the original pads at first but they're doing just fine. Maybe I have low standards? Although the old Modolo's and the sidepulls on the Peugeot I recently worked on were scary bad.
Likes For jamesdak:
#109
Quoted: 1977 Post(s)
Liked 2,097 Times
I never read about broken Campagnolo tension springs.
Likes For Classtime:
#110
Liked 3,484 Times
Having had two lower pivot springs break on SunTour Cyclones (and on one SunTour canti brake), I now look at them with a bit of concern. I've also got a few bikes with Campy NR or SR derailleurs, and no problems there. The SunTours have a ton more miles on them, and in all conditions, so I'm not sure it's a fair comparison.
Steve in Peoria
Steve in Peoria
#111
Liked 2,254 Times
I found the BA-SB00-S, Superbe Pro calipers to be nearly equivalent to DP brakes on the Trek 760. In fact, I believe they are better than the Chourus Monoplanar
#112
Phyllo-buster
Quoted: 2300 Post(s)
Liked 2,067 Times
I think there's a lot of BS, brand snobbery, etc out there in the C & V world. For instance, most of my bikes have friction bar end shifters. I've got them in Simplex, Campy, Suntour and Shimano. The overwhelming favorite in the C & V community is Suntour. I wonder how many of these Suntour bar end fan boys despise Campy RD shifting? They both have the same type of feel. The Campy RDs are described as "heavy, clunky and slow," but the Suntour bar ends are great because of the dependability and "positive feedback." That's BS! Put them together and you have a bicycle that shifts like an 18 wheeler.
I apologize for the rant.
I also love my NR/SR rear derailleurs. Consistent, solid, dependable so they deserved their place at the top of the racing food chain, imo.
My fave frankenbuild was a 90's C-dale R500 with Suntour bar cons and an SR rear, Record front. Fast as a scared cat and the light weight meant you didn't have to shift as much. Like the hard men of the past peletons.
Likes For clubman:
#113
Quoted: 3467 Post(s)
Liked 2,843 Times
My first road bike way back 50 years ago had Campagnolo bar end shifters.
shifting was vague.
I went to down tube shifters a year later.
today I might try index shift cable housing and different cables. I would expect improvement.
the ratcheting pawl of the Suntour really reduced the friction in the system.
many sprinters really liked them.
Shimano had a counter sprung lever that some liked.
shifting was vague.
#114
Liked 4,827 Times
For me, what I was able to detect in direct comparison was that the calipers seemed to flex more compared with the Campy Record calipers. Even when I originally ran the Suntour calipers with a pair of Campy Record levers, I felt it. The feeling was much the same with Superbe brake levers. Also, the pads! Hard as rocks, sounded like a banshee wail when I applied any modicum of pressure - even after I sanded them down and chamfered the trailing edges. I purchased a second replacement pair; same thing. They really were the squealiest brakes I've ever encountered; who knows, perhaps a modern set of pads would've helped, but I took the easy way out and moved them along instead!
DD
#115
Quoted: 196 Post(s)
Liked 586 Times
On my daily riders it's either Shimano or Suntour, but mostly Shimano. That's not by design, but more of coincidence.
That being said, on certain bikes, Campy rules. I have one full Campy fitted bike and it just oozes soul and artristy. I don't ride it very often, but it's my Shwag Wagon, without a doubt. It's my shameless indugence to embracing my inner "OCP".
The one thing I will give Campy over any other componenet is the ability to rebuild it. I have an early set of Ergo brifters that are 8 speed. I've always known I can rebuild them if needed, but I just found out I convert them to 9 sp for a mere $15 more in parts. It may even be possible to go to 10 sp, but I need some confirmation on that.
The 8 to 10 conversion is *possible* but requires much more extensive surgery. The center bolt is of a different diameter, so that needs to be replaced with a 10 speed unit, and of course everything that goes on it ( that is everything inside the unit). Jan Ullrich and Mario Cipollini were famous in the ten speed era for preferring the old pointy lever shape and had old levers hot Rodded to ten speed by the team mechanics.
#116
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1035 Post(s)
Liked 716 Times
The Suntour derailleurs seem to shift fine -- will they hold up for 50 years like a NR derailleur? At my age... I'll never know.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
#117
Liked 4,827 Times
Personally, I think the original 'pointy' Ergopower shape is the most iconic, and not just because that's what's on my Davidson - I chose them for that bike because I felt that way from the start. Plus, they are the last with the forged alloy bodies.
Wonder if I might be able to hotrod an 8-speed pair into 10-speed? Something to think about, maybe. Hmmm...
DD
#118
Quoted: 477 Post(s)
Liked 1,107 Times
I’ve also had two break, at the same point. Fixed both and both are still in service. Others have too. Search around. I submit the key is to not seek a 90° bend on the new tab. A few degrees less works just as well and less metal stress. I have 3 Cyclones in the fleet and they all serve me well.
