Tern Verge X11 the King of Folders
#127
That's it Jipe educate these ignorant people. That X30 is like a rocket if you are young and fit. It will run down a road bike easily. Over shorter distances small wheel performance bikes are superior to large wheel bikes. A Moulton 17 inched wheel bike is the fastest bike of ALLTIME. On an in door track. And that record has stood for 38 YEARS.
#129
Schwinnasaur
You would not know it from the picture, but the record was set with a full fairing. Neither the picture nor the bike is right. This is a disingenuous post at best. The record was set with a modified Moulton and super low fairing. But that is not what the picture shows or suggests.
Here are the pics of what set that record
Now, maybe the poster knows this or maybe not. The fact that he calls us ignorant makes me think he does.
Now, I am not saying Moultons are a bad bikes. They are interesting. Moultons place in bike history is set but more for his influence in small wheels. I owned two of them for years but sold both of mine. Suspension is double-edged at best, but they were nice bikes but not as good as I have now.
In one of the post above, the Moulton Speed was mentioned. Perhaps in the context of price, $10,000 +. If you want to see a fair review of that bike, check out Bike Quarterly Review of it. I copied and posted that review in part in an older post a few years ago.
#130
#131
Just want to add a little detail. People who know what makes a fast bike know about riding geometry. The X11 with 37-451 tires has a bottom bracket height of 32cm. That is certainly not near of anywhere fast. In my opinion, it is not even outside the trashcan, sorry for that, too much "believe me bro i'm serious", and too little proof here...
EDIT: Ah, if Tern uses the same frame for 406 and 451, that would explain the higher BB.
If you're only talking about 3cm higher rider so less optimum aerodynamics, I think matters on a time-trial bike, but on a rec bike, that's fly specks in pepper. But again, do tell, thanks.
#132
BB height: In what way? (not challenging your statement, just asking). If I recall, a generally low BB means a bit more stable, but a higher BB allows better pedal clearance if powering through turns. In terms of power, I would think the most important thing is relationship of the BB to the seat, both vertical, and fore/aft, the latter of which may be more limited based on the particular frame geometry. IIRC, 32cm BB height sounds high. Do tell, thanks.
And the premium Tern verges
X10
X11
X18
X20
X30
Are all capable of breaking 25mph on the flat. The X11 and X30 can break 30mph. If the rider is fit and strong.
#133
(above) Not challenging you either. It's just always good to know reasons and rationale for things. If there's a reason why that BB height is not fast, good to listen and evaluate.
EDIT: Verge X30 (I was hoping to see a road triple, but not), is a SRAM 3x10 Dual Drive; In middle gear on the IGH, direct drive, no loss in efficiency. In low or high on the IGH, reduction and overdrive respectively, with resulting gear friction losses in efficiency, most critical in the high range because that is the speed range. The hub is also heavy. I'd expect it to be blown away by an X11 in top gear, UNLESS, the X30 has a lot taller top gear (I think it does) and the rider is capable of using it fully. But it will still be slower than a non-IGH race bike, if only for no other reason than the IGH. This is a fundamental problem on small wheelers, you need a pie-plate chainring or tiny cogs for race-high gears without an IGH or Schlumpf drive.
#134
I have a Tern Verge X18. The front wheel SPINS for like 13 minutes. Basically frictionless. You get a cheap bike and spin the front wheel. You will be lucky to get 2 minutes.
Quality bearings hubs. Rotational weight. And the overall weight and fitness of the rider determine speed. Not how high the bottom bracket is off the ground. What is this guy smoking?
#135
But it has no bearing (no pun intended) of the speed of the bike. The wattage expended from the rider is the biggest factor. Then the efficiency of the machine he is sitting on. And the next factor is the rotational weight of the wheels.
I have a Tern Verge X18. The front wheel SPINS for like 13 minutes. Basically frictionless. You get a cheap bike ans spin the front wheel. You will be lucky to get 2 minutes.
Please see my edit above about the X30, which has no bearing on the other Xs.
#136
So enter stage two. They now have to try and rubbish anyone who praises BIG BIKE. It will either be my customised £100 bike overhere is better than yours. Or some nonsense about the frame is no good or its not as good as a purist road bike like a Specialized or Pinarello.
Anything to try and score browny points. And make people who shelled out on a premium priced folder look stupid and not as smart as their mean assed self's. I'm too old and wise to fall for their nonsense. But there's those that will. And will be influenced by their nonsense too.
#137
They are not gonna. These people are ANTI BIG BIKE. They get off on antagonising people who buy premium level bikes. Because they either couldnt afford to do so. Or are so tight they didn't want to part with the money.
From wiki on Ferdinand Waldo Demara, infamous con-man:
(When accused of fraud he) worked on two cardinal rules: The burden of proof is on the accuser and When in danger, attack.
Sound like any USA politician in the news?
Don't be that.
Likes For Duragrouch:
#138
Quoted: 513 Post(s)
Liked 623 Times
Getting educated by J!pe, that's a scary thought.
Lesson Plan
1. The Smug European male's guide to the Birdy
2. Exorbitantly priced folders designed and manufactured by the White Man.
(This advanced seminar involves a field trip to an Apartheid era bicycle maker plant in South Africa)
3. FnTrash. Don't get bamboozled by Asiatic bikes
Lesson Plan
#139
Well... his part of the world, most notably countries to his north, actually ARE functioning better and the population as a whole much better educated than MY country, especially comparing the least educated. There's just no escaping that fact, I'm sorry to say. Socialized medicine. Housing. Dedicated bike paths. But versus us, it's a pretty low bar to cross.
#140
Lesson Plan
Lesson Plan
#141
BB height is a trade off between pedal clearance and center of gravity height. The higher the CG, the slower you corner, because you have to move the CG a longer distance between cornering positions. And since cornering ist part of being fast, it is very important. 99.9% of RR bikes have a BB height between 26 and 28cm, because it's one main parameter of being fast. Roll rate gets slower the higher it is.
#142
With roll rate i mean the movement of the bike around the length axis, which is at the contact point between tarmac and tires. The more far from there the CG is, the more energy you lose moving around that axis. You even lose a lot while pedaling standing compared to bikes closer to the sweet spot.
So not just cornering, also power transfer is unnecessarily impacted, when a bike designed for skinny 406 tires was equipped with mid-size 451 wheels/tires
#143
#144
Quoted: 824 Post(s)
Liked 254 Times
Lesson Plan
Lesson Plan
BTW, you can add a number 4 very expensive bike in your list, designed, build and mainly bought by the Yellow Man: Tyrell XF 14990€
#145
Administrator
Quoted: 12014 Post(s)
Liked 6,781 Times
This thread has turned ugly and strayed off topic. Before I start handing out infractions let's close it, shall we?
Closed.
Closed.
Likes For BillyD:
