Farmer tan
Quoted: 2953 Post(s)
Liked 3,106 Times
This particular one was recommended by a friend. It was only $22 and I have low expectations. If it lasts through the end of the year, I'll feel satisfied.
Bikes: 2015 Redline Conquest Elite; 2014 Fuji Tahoe 1.1 27.5er; 2006 Scott Speedster S30 (sold); 2001 Specialized S-Works CX; 1990 Trek 750 (sold); 1999 Bianchi Volpe; 1988 Bianchi Campione D'Italia.
Quoted: 131 Post(s)
BF's Resident Dumbass
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times
The Phoenix girly bike I posted earlier:
First, the why: I needed something that would be easy to maneuver while I accompanied my wife on her tricycling (is that even a word?) around the neighborhood, and any of my adult-sized Treks are just too big and cumbersome to handle at the rather low speeds she tends to run.
I considered getting a Trek Jet 20 to replace the earlier one that we gave away to our nephew, but that thing is knee-murderously slow (about 32 gear inches,) not to mention the fact that it would've needed a very long replacement seat post (and seat) and handlebar stem for me to be able to use it, both of which are very difficult, if not impossible, to obtain locally.
This, however, fits the bill just nicely, given its design and geometry. That said, the one that I really wanted was the Feida (see the post I linked to above,) but, to my dismay, I found that they had sold it already!
Of course, given the quality (or lack thereof) of the components on this thing, there was no way that it would work well and be rideable right out of the shop. So I loaded the thing into the trunk and drove straight from the toy shop to a small bike repair shop near my house run by an Indian dude.
First order of business: Replace the tubes. I had inflated the tires hard at the toy shop where I picked it up, but by the end of the short 10-minute drive to the repair shop, they were virtually completely deflated. The original tubes were made of cheap rubber so porous that they probably would've worked better as bug traps!
After rummaging through his pile of used parts, he dug out an unsold, brand new 12-incher and took off the cast-aluminum brake levers and side pull calipers, which we replaced the stamped-sheet-metal originals with.
We also found a bad rear axle, but with the clock approaching midnight (the law says he's supposed to shut down by 11:00 pm,) it was easier and faster just replace the entire rear wheel assembly and deal with the original axle later.
We also replaced the rubber pedals, which practically disintegrated in my hands while I was wrenching them off, with plastic-framed ones of reasonable quality, along with a longer seat post that put me a$$ a little too far backwards for optimal balance. That's about to be corrected soon with a longer but straighter post.
After riding it around the neighborhood a few times, I found that the brakes still were far from being up to snuff, so I cannibalized a set of old blocks from an old 16-incher we had lying around the house, which improved things a bit, but not much. Then I figured that the thicker, wider brake calipers' arms were pressing against the fenders, so I bent the fenders in a little with a pair of pliers. Slightly better. Then I found that the brake blocks were way out of alignment on each side, so I bent the caliper arms accordingly to bring them to be as opposite each other as possible. Much better, but still not as good as I'm hoping (i.e. as good as the brakes on the aforementioned Jet 20.) It's still a work in progress.
I also removed the spring-loaded stand (the type that raises the rear wheel off the ground.) Next, I'm going to strip off the fenders and the luggage rack to expose her inner beauty!
Nice bike. It will serve you well.
Quoted: 686 Post(s)
Liked 5 Times
I kind of bought two bikes yesterday
Carbon...
2017 Cannondale Supersix Evo HiMod Frame 54cm
Red eTAP Electronic Road Group (Shifters, Front/Rear D)
Supacaz - Super Sticky Kush - Neon Pink
Cannondale SISL Crankset
KMC X11SL Chain: 11-Speed 116 Links Ti Nitride Gold
SRAM XG-1190 11sp cassette, 11-28t
ENVE Compact Road Bar 31.8 x 42cm Black Logo
SRAM Red caliper brake set, F/R - black (eTAP)
Steel...
All City Mr Pink 55cm
Carbon...
Steel...
Bikes: 2005 Bianchi L'una, 1996 Bianchi Eros Specilized Hard Rock 70' era Carnelli Graziella Folding commuter
New Felt Z4
All at Western Bike Works.
- Garmin 810
- Sensors
- Front and rear lights
After shipping and conversion about half of what all this would cost me in Canada.
- Garmin 810
- Sensors
Quoted: 792 Post(s)
Liked 1,494 Times
I spent the afternoon in Bab Makkah (literally: Makkah Gateway,) one of Jeddah Al-Balad's (Downtown Jeddah) commercial districts where the off-brand bike shops are. They pointed me towards one shop that might have had my Feida, and indeed, I bought their very last one (although I would've preferred it in yellow like the one I saw at the toy shop earlier.) I used the dact that it had a few scratches, a slightly bent fender, and a small tear in the saddle to haggle, and ended up getting it for 350 riyals (about $90) as opposed to the SAR429 price.
I also got a longer seat post for about 2.5 bucks to replace the original, which is too short.
I rode it the half-mile or so from the shop to where I parked my car, and then rode it again around the neighborhood this morning. The 20x1-3/8 tires certainly make for a harsh ride, but it feels a little smoother and more consistent than the Phoenix. The rear band-type drum brake works surprisingly well, but I haven't yet put it through an overheating test. Like the Phoenix, though, those brake levers certainly must go!
Oh, and I also learned that I probably was a little too hasty getting that Phoenix: I found a version of it in blue at the same shop!
Farmer tan
Carbon...
Steel...
Carbon...
Steel...
We stopped in Academy tonight and found some $15 long sleeve Canari Flash jerseys and a $10 Microlyte jacket in my size while wandering around waiting for the others. Hopeful thinking on my part since it is still in the 90's here.
Bikes: AristoNYC's PedalRoom
Quoted: 130 Post(s)
Liked 6 Times
https://www.biketiresdirect.com/prod...ve-mag-trainer
$330 shipped.
CycleOps THE SILENCER DIRECT DRIVE
Heres to hoping it is an upgrade to my Kinetic By Kurt Road Machine.
$330 shipped.
Bikes: Canyon Endurace
Quoted: 1047 Post(s)
Liked 934 Times
$330 shipped.
$330 shipped.
Although will need to buy another cassette for the unit. I don't see anyone else even touching that price. I may just pick one up.
Liked 934 Times
^^ Fine Print. Out of stock
Quoted: 130 Post(s)
Liked 6 Times
Bikes: Specialized Roubaix Di2, Rockhopper 29er
Power meter and New bars
I am at it again and I bought a Stages power meter, which they just replace the crank and while having that installed and went ahead and bought the new Sworks aerofly handle bars in matte black. Also new white bar tape! I should be done for awhile on my road bike!!
Quoted: 4717 Post(s)
Liked 1,882 Times
Advocatus Diaboli
Quoted: 4781 Post(s)
Liked 1,544 Times
I'm curious on the Stages PM stuff.. can you give them your own crankarm to glue their sensor to, instead of buying the whole thing? Ie. at a lesser cost?
