ISO and for trade thread part 5
#1776
aka: Dr. Cannondale
Quoted: 2168 Post(s)
Liked 3,500 Times
Pretty sure I have a 27.0 in The Lab. Yours for the price of postage.
Shoot me an e-mail at rccardr@cox.net
#1777
Bikes: Numerous
Quoted: 1679 Post(s)
Liked 3,151 Times
ISO Camp Record/Super Record brakes/levers/post
Trying to finish off my Eroica build in a non hodge-podge fashion.
Looking for fluted 27.2 post, drilled Super Record brake levers, Record/Super Record brakes with recessed nuts
I have all kinds of later Campy parts (C-Record era but not C Record), stems in the 110-130 range, hubs. Campy 10 speed parts include brakes, cranks, 12-23 cassette. Also have a set of Record nutted brakes. Right now I’m eyeballing a donor bike to get these parts, so keep me from going down that rabbit hole!
#1778
Bikes: Numerous
Liked 3,151 Times
https://www.ebay.com/itm/Rear-derail...72.m2749.l2649
They look to be solidly made. The bushing and center flange (where the bushing sits in the wheel) were too wide, but a couple of minutes with a file fixed that. They spin nicely once filed and installed. Haven’t ridden them yet as I’m waiting on parts to finish the build.
#1779
PM me your cotters
Quoted: 1141 Post(s)
Liked 590 Times
Just as an FYI, I bought a couple of sets of these recently
https://www.ebay.com/itm/Rear-derailleur-jockey-wheels-to-fit-Campagnolo-Super-Nuovo-Victory-derailleurs/123885550418?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I hafta say though, it looked like the Chasertech models @Mad Honk brought up are $15/pr, ball bearing. Remind me a lot of the Bullseye pulleys.
#1780
Always grease your post!
Likes For TXsailor:
#1782
Bikes: Numerous
Liked 3,151 Times
Thanks! That seller is really awesome, btw.
Duct tape should work on that. Ream out the seat tube a little to account for the tape.
#1783
PM me your cotters
Liked 590 Times
#1784
aka: Dr. Cannondale
Liked 3,500 Times
Plain old 10 tooth Shimano pulley wheels also work well on SR/NR RD's.
Likes For rccardr:
#1785
Quoted: 237 Post(s)
Liked 83 Times
#1787
tantum vehi
Quoted: 1169 Post(s)
Liked 994 Times
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
#1788
Quoted: 1323 Post(s)
Liked 1,960 Times
Yes Dave,
They are The Chaser Tech. I stumbled across these guys about a year ago when looking for Bullseye pulleys. They are very helpful and even sent multiple e-mails back and forth to be sure I got what I wanted. The sealed bearing inside diameter is 7 mm instead of the 6 mm on the Bullseye. That dimension was for the Shimano attaching bolt. When doing the retrofit for Campy, it takes a 5 mm spacer to be inserted in the bearing race to shim to the correct size. That is the gold colored part next to the bearing in the pulley.The shims are bit thick for a good solid fit so I grind the inside of the shim down about 1 mm in insertion depth the shims are aluminum so it only take a second on the abrasive disk. The Chaser tech folks will provide them along with 1 mm spacer washers to center the pulleys, if you ask for them. When I first ordered from them they had multiple colors, gold, purple, green, red, blue, and black. The outer diameter of the pulley is slightly larger than the original nylon ones from Campy, But they seem to work fine. Be sure when shopping that you specify the number of teeth on the pulley, they have multiple selections and it is easy to overlook the 10/11 tooth product description. The original Campy and Bullseye were all 10 tooth (which is the size I use on these). Last time I looked at the site they only had red and black available in 10t. HTH, MH
#1789
Liked 1,960 Times
Francophile,
Package went out today, you should see it in a few days. Now if you would be so kind; please commence to back flipping and beer chugging! And the video of that would be nice as well! Smiles, MH
Likes For Mad Honk:
#1790
Quoted: 378 Post(s)
Liked 1,413 Times
ISO:
-50cm Trek Y-Foil frame/fork. Not for me.
-zero-setback polished seat post (at least not black) 27.2
-Black Campy calipers
-Soma Hwy One in 40cm
-9sp DA 7700 GS (med cage) RD
#1791
Quoted: 887 Post(s)
Liked 335 Times
I went looking for MKS/Specialized pedal dustcaps and certain Shimano or Weinmann brake levers (no dice) but found a pair of SunTour friction thumbies. Hoping the pic I
took can be posted, let's see. @dweenk Is this what you are looking for?
#1792
www.theheadbadge.com
Quoted: 2433 Post(s)
Liked 4,449 Times
Thought about getting some spokes on eBay, then started to question why I'm supporting that business model to give both eBay and PayPal 20% of that seller's profits out of my own pocket.
As such, I'm ISO the following stainless spokes:
-Kurt
- 270mm (x32)
- 277mm (x16)
- 252mm (x16)
-Kurt
#1793
Bikes: many
Quoted: 1461 Post(s)
Liked 1,421 Times
-Kurt
- 270mm (x32)
- 277mm (x16)
- 252mm (x16)
-Kurt
#1794
PM me your cotters
Liked 590 Times
Let me check when I get home today. I've got at least 4-5 boxes, I think they're all complete boxes, all stainless, all are DT Swiss I think?
#1795
Liked 4,449 Times
FYI, I have the following spokes to trade, all straight gauge and used:
Thanks, will look into it.
That would be perfect if you do have them. Just de-laced the hubs now (though I'm debating re-using my 1946 GH6 Dynohub - someone scraped up the finish on it).
-Kurt
- 256 / 16
- 265 / 36
- 283 / 16
- 287 / 32
If you don't find any suitable trades, I would just contact Marcus Moore @ Yojimbo's Garage directly. While he sells on eBay (yojimbos_garage), he's also available via email at yojimbo.chicago@gmail.com.
-Kurt
#1796
PM me your cotters
Liked 590 Times
Womp womp. This is all I've got as far as boxed goes, if I'm trusting the labels
Of course if you have a spoke threader, you could cut your own, but I think you could do that with some you have already too!
I also have several bundles of used/loose ones, of which I doubt anyone would want and only maybe 75-100 are stainless, probably also DT, but maybe Wheelsmith or whatever the "W" stamped spokes are, I can never remember these days... but they're 1.6 IIRC, which are super skinny.
Edit: These are all DT Swiss Champion series spokes if the box isn't recognizable.
#1797
Stop reading my posts!
Quoted: 1457 Post(s)
Liked 1,088 Times
Wheelsmith "W" stamped on spokeheads were said to have been made by Asahi in Japan. Don't know if true but they are/were fine quality spokes in my book.
#1798
Liked 4,449 Times
#1799
PM me your cotters
Liked 590 Times
I need to dig up some stems and some Campy bits tomorrow, when I get into unburying that stuff, I'll try to source a metric measuring implement or yoink one from work. Then I can measure everything. But might be a stretch, a lot of those showing in the pic up there are galvanized. I think I may have two or three wheels worth that are stainless.
#1800
Liked 4,449 Times
Hence the womp-womp. I needed my metric tape measure earlier to re-measure the Razesa SLX I'm trying to move and can't find for the life of me. I have three metal rules I once used pretty heavily when I did more fab work (they bend nicely to draw perfect curves), one had metric on the side, just so happens to be the one I can't seem to find. My digital caliper only goes out to 130ish.
No worries though. I'll pay the piper if need be
-Kurt
