Thread for Specialized Sirrus
#1551
Hello!
Thank you for such a quick reply.
I have upgraded pads and breaks work fine. But yesterday I rode in rain and the breaks did not perform as well as the disks on my new Liv bike.
I guess I am trying to decide whether I should upgrade my bike now (while I can sell it easily), or wait. But then next year, once situation at bike shops improves, I won't be able to get much for my very well-maintained bike.
#1552
Bikes: Specialized Sirrus Sport
Hi!
Hello, everyone! I’m new here...have read through about half the thread so far, so forgive me if this has been asked. Does anyone know what cranksets will/won’t work with our bikes? I have been to 3 different bike shops (with my bike) and gotten 3 different answers as to what I can run. It seems there are several different versions of the sirrus. Mine is a sirrus sport with 3x9 gearing. I ordered new wheels to accept an 11speed cassette and would like to keep the triple crankset, but upgrade it and go to a 165mm crank
#1553
Can anyone give me feedback on the 5.0 X 2021?
It got a 3.7 on the Specialized site - people said great frame - ***** components? Hub and wheels especially?
How’s the build quality ?
Would you consider this a gravel bike ?
#1554
I’ve got the ‘19 5.0X. Being the beta tester I am, I’ve crashed the bike multiple times and lets put it this way; it crashes well. The gearing was too short for me, so it easily accepted a 11/32t Ultegra cassette. Not doing tight trails, I actually now use all the rings. The only thing that it does infrequently is derailing the chain. I’d buy this bike again in a New York minute. It fits so well and is a very compliant. I ride more than ever, which I consider the ultimate complement for a bike. Go for it! ,BK
Likes For bobthebike:
#1556
Quoted: 28 Post(s)
Liked 13 Times
I just got one a couple of weeks ago... Haven't had a lot of time on it due to other things going on right now but it seems like it is going to be a great bike! I struggled on what to get for months and didn't even consider the x...was interested in the regular Sirrus at first but the more I read about it and talked to my LBS I changed direction. It's very comfortable and easy on the eyes..build quality seems great also. I seated in the new disc brakes as instructed and they are amazing.... Shifts are crisp , If there is any one thing , and the verdict isn't out yet, it would be some cross chaining noise when I am in the 3 lowest gears but that's the nature of the 1x front chainring.. Maybe it will quiet as things loosen up but if not, hopefully I will be stronger and not need to dig so low down the road... Just my newbie first impressions for what it is worth.
Likes For waxcrazy:
#1557
Quoted: 3032 Post(s)
Liked 1,198 Times
#1558
Hi Everyone!
I'm new to the Sirrus family here as I was lucky enough to find a Sirrus 6.0 in my area (Thornhill, ON) this week - I was actually cross shopping between this bike with a Diverge, as I did want to do some graveling at some point, but I came to a realization that if I did want to ride at all this year, I would have to pick up whatever I could get, so the Sirrus came up first.
I was wondering for anyone who has this bike, what is the widest tire/rim set that this bike will take? Seeing that the SX 5.0 comes with 38mm widths, and assuming that the fork is the same, is it safe to assume that 38mm is a good place to start?
Cheers,
L.
Cheers,
L.
#1559
Quoted: 28 Post(s)
Liked 13 Times
Thanks...that makes me feel much better knowing it's just a adjustment!
#1560
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 764 Times
Drivetrain noise can come from a variety of sources. Before I made any adjustments, I'd try to figure out what's making the noise.
When shifted to the largest cassette sprocket, is the upper pulley of the derailleur directly under the sprocket? Does it look like the chain is transitioning cleanly from the upper pulley to the largest sprocket? If so, then I don't think a twist of the barrel adjuster will quiet your drivetrain -- you may instead create shifting problems where there aren't any now. However, if the upper pulley is NOT lined up directly under the sprocket, then an indexing adjustment may help. If the derailleur is too far outboard (needs to move in towards the hub some), then unscrew the barrel adjuster a half turn at a time and ride. If the upper pulley is too far inboard towards the hub (and needs to move out to be lined up perfectly), then screw in the barrel adjuster a half turn at a time and ride. You may find it hard to get it perfect across the entire cassette. Maybe you improve the noise at the large end of the cassette but introduce shifting problems at the small end of the cassette. If this happens, there is likely other misalignment in the system.
Having said all that, depending on your specific setup, cross chaining can absolutely create more drivetrain noise. Some are more sensitive to it than others. Perhaps something as simple as fresh lube on your chain will quiet it down. I have a few 1x bikes and they are noisier at the large end of the cassette if the chain is particularly dry. With a freshly lubed chain, all runs quiet and smooth.
#1562
Liked 1,198 Times
For the Record...I have this this same bike (Sirrus X) and there are no cross chain noises on it.
#1563
Shifting chainring
Hi all,
I have just bought a Sirrus x 5 2021, 12 gear. It’s a really nice bike, however I find the gearing too low. I won’t use the three lowest gears and I miss higher gears.
Has anyone changed the chainring from 40t to 42t or 44t? Preferably I would go for the 44 but I am not sure if it can fit.
would be great to learn from your experiences. Thanks
Likes For Pallandsen:
#1564
Liked 1,198 Times
Hi all,
#1565
Quoted: 28 Post(s)
Liked 13 Times
Thank you!
Likes For waxcrazy:
#1571
I have a mid-range Diverge with an expensive seat that was 'wearing' on me. I replaced it with a Brooks C19 made
from vulcanized rubber (no maintenance. no break-in). Loving it.
#1572
I had to buy a new saddle for my Sirrus 3.0 after the Selle Royal Respiro cracked half way across the seat. It was a crack in the center that ran from the seat edge to the center channel. I noticed it when I saw a tear on the covering. The tear was the only visible part until I removed the saddle and turned it over and found the structural issue. I looked in several bike shops in the area and they had slim pickings on saddles. So I ordered the Selle SMP TRK Gel - medium - online - as that's the model the Selle site recommended when I ran their "Which Saddle for me?" app. It seems slimmer to me than the Respiro but seems like a keeper after a 20 mile maiden voyage today. I stopped once to move it back a bit and it felt a little better. The SMP has a strange curved down nose on it and I need to figure out the level I need. I "think" I need to tilt the front up a little to stop me from slipping down toward the center too often.
#1573
Hello guys & gals, newbie here & 1st post. I'm 49 y.o. & looking at purchasing a hybrid bike in order to ride with my 3 kids (15, 11, & 10 y.o.). The older 2 kids just got Trek FX hybrids with rim brakes & the youngest has a Giant XTC. I haven't ridden a bike regularly since I had a Trek hybrid in the late 00s (which I was able to get decent money for several weeks ago).
I'm looking at an X 4.0 vs 5.0. I've read through the last 30 or so pages of this thread over the last couple of days & honestly much of the thread is too technical for me! I have several friends who ride road bikes & I've had them look at the specs on both bikes. All three of them have recommended the 5.0 due to the CF frame & components. I thought I'd check in with people who have first hand knowledge of these bikes!
4.0 or 5.0? My biggest concern is the CF frame on the 5.0. How durable is the frame? Or in other words is it easily damaged? Is the 5.0 overkill for someone like myself? I plan to ride this bike for over a decade hopefully!
#1574
#1575
I bought my Sirrus X about a year ago, a 2020 11 speed model. It is a fantastic bike that handles, brakes and shifts very well. I since bought a turbo Creo Comp Carbon, which I love, but jumping on the Sirrus and going for a ride is a joy. It is lighter and feels more nimble, but of course the upright flat bar configuration makes for a very different ride. If you lived close to this area I would offer you a test ride. You will not be sorry!
