Why the war between drivers and cyclists?
#76
This was a pretty minor incident to be making such a big deal of. I think Hallux was just trying to make the point that cyclist are part of the equation when it comes to sharing the road; and without input from the two cyclists in question we're only speculating regarding their actions and reactions.
I see guys in groups hogging the road unnecessarily every once in while, and that's the kind of thing that promotes negative feelings towards cyclists with some drivers. I believe that the point the initial post was trying to make, but thanks for all the education on motor vehicle statutes in NYS.
#77
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Out of curiosity, how much have you ridden on roads since you started up again? No offense intended, but some of your opinions and ideas about the laws regarding cycling are typical of inexperienced riders or non-cycling motorists.
#78
Bikes: Trice Q; Volae Century; TT 3.4
In many years and thousands of miles I've not found any war between drivers and cyclists. I know war and this is not it. Not even close. I sincerely hope cyclists who are using the "war" and "battle" language never experience the real thing.
#79
And yet I'd put money on the fact that a cop would more likely caution the cyclists to ride single file on the wide shoulder while being overtaken (I consider "overtaking" the approach to the pass as well as the pass) than warn a motorist not to use their horn to warn 2-abreast cyclists that a vehicle is approaching if they were to see this unfold.
I said it before, SHARE THE ROAD goes both ways. Motorists should be aware of cyclists (I was as evidenced by my intent to alert but not alarm them). Cyclists should be aware of, and move right for, motorists when possible (and it was in this case, they just chose to be a$$holes).
BTW, I consider a cyclist in the travel lane to be a "collision imminent" situation, no matter the speed or attentiveness of the driver. I also was not directly behind the cyclists when honking, I gave them a good distance to fall in line together.
What if (and this wasn't the case, but what if it was) I was a volunteer fireman approaching on my way to the firehouse down the road to respond to a call? A honk on the horn would be warranted (firefighter responding to a call is an emergency situation, no? though I DO understand they can't speed excessively), and their choice to obstruct the lane would delay arrival to the house.
#80
Cycle Year Round
You are a lost cause.
It is also not legal for volunteer fireman to go around blasting their horn. If they do not have lights and siren, they cannot run around as an emergency vehicle.
Land of the Free, Because of the Brave.
#81
Yes, that's exactly what the law says. His judgement has to be reasonable, and he may possibly be called to justify it to a law enforcement official or court, but it depends on the cyclist's judgement. His, not your's.
The motorist has the obligation to slow down and avoid striking the cyclist(s). Yes, if that means they follow at 20 MPH they should. However, the cyclist(s) should be on the shoulder, if it's suitable. In the street view posted, there's a 20 foot section that may not have been suitable but the rest should have been perfectly safe and wide enough to utilize rather than blocking the lane.
#82
Cycle Year Round
Another MUP cyclist telling long time cycle commuters how they should ride in todays world.
#83
I didn't say they'd be blasting their horn, but volunteer firefighters around here have blue lights in the front window. It's an option to yield to them as another motorist but I'm sure they'd appreciate it and the same would apply to cyclists.
Maybe my definition of "blast" is different from yours. This was a tap with the side of the fist to chirp the horn, not a full-palm press on the horn button for 1-5 seconds.
I can understand the need to make yourself as visible as possible, but at what point is it going too far? On that road, even for a vehicle going the 45 MPH limit, if cyclists were 2 abreast in the wrong spot of that curve as the car is coming it can spell disaster.
#84
Bikes: Nashbar Road
Liked 341 Times
I'm a relative newby at 6,000-7,000 miles per year, only about 5 years. Honestly, the experience has altered my perspective. Sure I'd still be annoyed with a group hogging the road, but as far as safety goes, and smoothly integrating with traffic, you get a totally different understanding when you put some miles in as an adult. Any driver should realize though that almost no one is out there daring you to run over them. Kids or racer types running reds maybe, but mostly we're maximizing our safety even though a non-cyclist (non-road cyclist) might see the same practice as dangerous.
#85
Cycle Year Round
It would actually be better if you stopped motoring on the roads.
#87
Bikes: Sun EZ-Speedster SX, Volae Expedition
I've had two instances of run-ins with cyclists (with me as a driver). I'm now the cyclist and still don't see where they were in the right. In both cases it was multiple riders, in both cases the road was approaching a curve that was difficult to see around. In both cases the cyclists were riding side by side with one in the travel lane. As I approached I gave a quick tap on the horn to alert to my approach, expecting they would fall into a line (they didn't), and several more quick taps when they didn't. In one case, the cyclist in the road actually moved FURTHER left, in both instances there was a sufficiently wide shoulder for a cyclist to be on safely (and I alerted a local LEO to their unsafe actions a short way down the road in one of them). In both cases, the approaching curve was bad enough that moving into the other lane as a motorist is unsafe as you can't see cars coming the other way. Yes, motorists should share the road with cyclists, but sharing involves multiple parties.
If the curve was difficult to see around, there is no reason for the cyclists to single up on the shoulder. It's not a safe place for you to pass even if they were on the shoulder and you were in the travel lane. Where are you going to go when someone comes around the curve edging over the double yellow because they took the turn too fast? You would have to move right and hit the cyclists.
Moreover, cyclists are never required to use the shoulder in NY. Even if you wanted them to single up in response to your horn they could have singled up in the travel lane. Two cyclists one in front of the other are more difficult to pass than two cyclists side by side.
One of these resulted in a hand signal involving one finger from one of the cyclists, the other resulted in a verbal altercation resulting from a hand signal by the cyclist inviting me to stop (I shouldn't have but there was nobody approaching from behind). I did what I could to alert them to approaching motorized traffic and in both cases they exhibited the same "I own the road" attitude that cyclists complain about from motorists.
From https://www.safeny.ny.gov/bike-vt.htm
Anything else to question the New York bicycle laws? OK, the law doesn't say possible, it says they SHOULD ride single-file when being overtaken by a vehicle.
I believe this is the intersection? The shoulder looks a little narrow to me, but maybe wide enough. If you follow the road up a little further though there is a side road entering from the right. Traffic turning from there would have a much more difficult time seeing cyclists on the shoulder through the metal guardrail as compared to cyclists in the lane. That would be sufficient reason to ride in the lane as opposed to on the shoulder - to be seen by traffic entering from the side roads whose view would otherwise be impeded by the guardrail.
FWIW, this Clifton Park blind corner on a road with a 40 mph speed limit and a narrow shoulder is the bane of my existence.
#88
Quoted: 5792 Post(s)
Liked 2,581 Times
IMO, there was wrong on both sides. Based on the aerial photo, the bend isn't sharp enough for the cyclists to justify taking the lane to prevent an unsafe pass. OTOH they were nearing an intersection, and passing there would be illegal. I suspect that this was simply a case of two cyclists riding abreast and resenting being honked at by a passing motorist.
But, that doesn't make you right.
In NYS the right of way is with the passed, not the passing vehicle, and it was incumbent on you to wait until an opportunity to pass safely, ie. not on a bend, or approaching an intersection. Also the same argument that says the riders were wrong about the blind curve issue applies to you. If the curve had decent enough sight lines for the cyclists not to worry about protecting their rears, so did you, and the argument that you or another motorist were endangered if you had to slow to 20mph doesn't hold water.
Nobody likes to be held up or delayed by cyclists, who maybe could be more courteous and move over, but this is a fact of life to be born along with all the other frustrations. Picture how you'd handle the exactly same situation, if instead of cyclists, the land ahead had a farmer moving along at 20mph on his tractor.
Traffic law is only a foundation, it's up to drivers to muddle through the various conflicts of rights and responsibilities using common sense and courtesy. The easiest way to have an accident is insist on your rights in muddy situations, even if you're 100% in the right.
FB
Chain-L site
FB
Chain-L site
#89
#90
Fellow Clifton Park cyclist and motorist checking in!
That is not an 'own the road' attitude. It is a 'I can occupy the road' attitude that you are perceiving as an 'I own the road' attitude. They were no more owning the road by traveling in the traffic lane than cars are when driving. A car ahead of me that is traveling slower than I might like them to is not owning the road; neither is a cyclist.
True, but there was no safe or legal overtaking there.
Apparently there are several interpretations of how that law reads, I interpret "Persons riding bicycles or skating or gliding on in-line skates upon a shoulder, bicycle or in-line skates lane, or bicycle or in-line skates path, intended for the use of bicycles or in-line skates may ride two or more abreast if sufficient space is available, except that when passing a vehicle, bicycle or person on in-line skates, or pedestrian, standing or proceeding along such shoulder, lane or path, persons riding bicycles or skating or gliding on in-line skates shall ride, skate, or glide single file. Persons riding bicycles or skating or gliding on in-line skates upon a roadway shall ride, skate, or glide single file when being overtaken by a vehicle." as "ride the shoulder single file if possible when a vehicle wishes to pass but you can double-up in the travel lane if safe to do so." In this case, they didn't and if they wished to turn left, they should have used an appropriate hand signal (they didn't).
Hi fellow CP-er, right now I'm riding the Zim Smith (the paved portions) and the MHB along the river, which may become my primary route once the Rte. 5 bridge construction is done.
#91
This is what happens when you raise a possible "cyclists were in the wrong" issue on a forum populated by "cyclists are victims folks.
Otherwise, I somewhat agree with you. It's up to each individual to interpret the rules of the road within the letter of the law, though proper education of ALL parties (cyclists too) could clear up "skirmishes" such as this. A prime example of this happened recently while driving. A cement truck and I were next to each other at a light with two left turn lanes, he in the left, me in the right. We get the green, proceed into the turn and he takes the right lane during the turn, his interpretation was that because of the lane closure 1/2 mile up he had to move to the right even though you're supposed to maintain your lane during the turn when there are 2 turn lanes. I honked to warn him that I was in the area he was trying to occupy. He stared me down after the construction and upon rolling down my window he asked me why I honked.
#92
Bikes: 90's Campione,90's trek multitrack,2005 trek 3700
Ive had people throw things at me, pass far to close and yes hit me. I also notice no one pays attention to the road when I'm at a stop light. Texters are everywhere.
You may not be entering a war when you get on your bike, but you are damn sure going into a minefield.
#93
Liked 2,581 Times
I have mixed feelings about drivers behind me using their horns. On the one hand I resent those who honk as if to say " Get the f*ck out of my way" . But I appreciate those who give me a quick tap from 50 yards back as if to say "just letting you know there's a car approaching?
Sometimes it's hard to tell the difference. On a narrow, twisty, hilly section of my daily commute with bad pavement, I often have to move left and block traffic, sometimes because of the pavement, other times to prevent passing in blind situations. Most drivers are very courteous and patient for the 5-10 seconds involved but far and away the best are the professionals, inc. Fedex, UPS, Con Ed, and amazingly the cops.
As for the ones that aren't, nothing I say or do will change their attitudes, so I don't let them spoil my day.
FB
Chain-L site
FB
Chain-L site
#94
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Look, I'm aware of what's going on around me while driving, I know what vehicles are where and even monitor my mirrors while stopped. Just as I don't expect another driver should dictate what is or isn't safe for me to do while driving (a whole other situation but my intent was 100% legal, the other guy felt I shouldn't do it), why should a cyclist intentionally occupy a lane when there's a perfectly good shoulder to ride on, just because the cyclist doesn't feel it's safe?
It should be the overtaking vehicle operator's discretion to decide if it's safe to pass or not, that decision shouldn't be made by a cyclist occupying the lane because he wants to be an a$$hole. If a cyclist doesn't feel safe riding on a 4 foot wide shoulder, maybe they need to find another road to ride on.
As for door lock and horn chirp. I can think of a few vehicles (I think my parents have 3 actually) that use the horn for the doors locking with the remote, and those are actually MORE of a honk than I gave. BTW, isn't the intent of a horn to alert to an unsafe situation?
Here's the statute. https://www.safeny.ny.gov/bike-vt.htm#sec1146
Considering the cyclists were 2 abreast when they shouldn't have been, it could be considered that sounding the horn was necessary. Keep arguing, I'll dig through the traffic law some more. I had no intent to hit those cyclists, in fact, they caused me to come to a complete stop in the traffic lane, which is more unsafe than just moving to the side and OBEYING THE LAW.
Don in Austin
#95
Liked 2,581 Times
Hallux, you're clearly in the wrong about the use of the horn. Sounding a warning is legal when necessary, but necessity implies that the other options are limited and the risk of collision is high. There was no dangerous situation here, as you had the simple and safe option to wait for a safer time to pass.
You keep mentioning the shoulder, but in NYS the road is defined by the white stripe at the right edge (if any) and the shoulder is not considered the roadway.
I know you feel the cyclists were rude, and you're probably right, but there was no danger involved until or unless you created some by passing in an unsafe manner.
As I said earlier, you would probably not have been at all upset or discomfitted by a farmer on a tractor, but because you feel these cyclists unnecessarily robbed you of 5-10 seconds of precious time, you're now here trying to sell this to a crowd not well disposed to hear it.
Put this in perspective, it's a non-event among bigger non-events, and if these were the worst thing that happened that day, then you had a very good day.
FB
Chain-L site
FB
Chain-L site
#96
Bikes: Schwinn Tourist (2010), Trek 6000 (1999)
3 years of commuting by bike, and I've yet to encounter this motorist who is at war with cyclists. Two instances of ignorant drivers, but they impacted the other cars on the road at the time, and not just me.
Not saying there's no moron drivers. I've seen them on the highways and while driving. None openly hostile to cyclists, however. But, I'm sure there are some, I just doubt it's very widespread. Either that, or I just lucked out with where I'm living.
#97
Even if the law says I can take the full lane, and cyclists can ride two abreast. I just consider it a courtesy, and it keeps me from looking like a jackass.
#98
Sometimes, the cyclists are in the wrong. And, yes, while laws are laws, it's better to be alive than technically right and dead.
#99
Bikes: Nashbar Road
Liked 341 Times
Possibly, but I can see his point as well. As a road user, I also see fit to move AFRAP, and ride as close to the right as possible. Yes, I take the turn lanes when needed. Yes, I move to the travel lane as needed (To clear the turn only lanes). And, yes, I move to the should when I note vehicles approaching behind me, if practical.
#100
genec
Quoted: 13658 Post(s)
Liked 4,532 Times
Did it ever occur to you that they are speaking metaphorically... just as sports announcers use war terms to describe the play on the field?
