What tool do you use that is worth spending more money on?
Bikes: Swobo Sanchez 3x1
Quoted: 137 Post(s)
honestly i think chain tool is kinda the #1 thing. allen wrenches fail, there's always something to be found in the drawer or the neighbors. chain tool you HAVE to rely on.
i thought the one from my crank bros multi tool was gonna last me a while - nope. i guess it's just intended for a few emergencies, which is frankly really frustrating considering the level of quality i'd usually expect from crank bros.
Quoted: 4513 Post(s)
Liked 6,389 Times
Ok, sorry, I didn't realize you already had most of that stuff and you are correct these are not impressive but usually do just fine for people starting out and are cheap enough to justify replacing most of them with good stuff that gets used a lot more. Pin spanners will come in handy when you need one, many old BB's need them, any cassette removal requires a chain whip so some of those things in a set like this are ok to use infrequently and upgrade as needed. Never say never, you'll be glad you have it if and when you need it.
sheesh. pin spanners and chain whips? i never ever use those. i already have higher quality cone wrenches than are in that box, a 9-13mm shank socket set, a 14/15mm box wrench made in germany, 1-11mm allen wrenches that are way longer with the ball end, splined bb tool, cassette tool, much nicer looking park tools crank puller, a monkey wrench (kinda my favorite tbh) and much much more. even my sub 8$ shipped allen set and shank socket set from ebay look better quality than that stuff. not impressed with your recommendation.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Not just for bikes, but you never know when your block and tackle will be facing off against 500+lbs of recklessly-applied rope tension, so find or buy good-quality tools for use on your your "barn fresh" bike finds.
Bike Galpal, this one's for you!
Quoted: 137 Post(s)
the reason i don't use pin spanners is because i usually have slant nose jewelers pliers which work fine, i never find myself needing to put much torque on it because it's the lockring that needs torque.... (although i have in fact disassembled freewheels with slant nose jewelers pliers) chain whip i would certainly like to own but i think i'll make one, and i have pulled multiple cassettes with a chain and some cranks installed on a bike.
this is why i say chain tool is more important. its used super often and there's just no way to "fudge".
Quoted: 5224 Post(s)
Liked 3,585 Times
Quoted: 137 Post(s)
that reminds me of my recent somewhat different experience of pulling a seatpost that was just chilling at the bottom of the seat tube, poking its head into the BB shell some ropy hooky things might have helped a bit over paracord and random nuts and bolts
Liked 6,389 Times
Totally agree with the chain tool, I am working on getting a good one as we speak, the basic ones I have are testing my patience every time I use them and I need a good one for several projects that are coming up. The lockring thing is spot on as well and I am sure the Park works just fine but my Sugino works so good I have never used my Park that I have as a backup. You will need a good pin spanner, at some point you will encounter a stubborn one and a spanner will help keep from gacking the paint from slipping out of the holes.
its ok. i'm not the thread starter haha.
the reason i don't use pin spanners is because i usually have slant nose jewelers pliers which work fine, i never find myself needing to put much torque on it because it's the lockring that needs torque.... chain whip i would certainly like to own but i think i'll make one, and i have pulled multiple cassettes with a chain and some cranks installed on a bike.
Liked 6,389 Times
That's what I'm talkin about! Macgyver award of the year.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
There was a similar thread on facebook earlier this year, except the seat post was anchored in a very large bench vise and they used a fork lift for the mode of force. You just have to be careful not to pull the frame joints apart.
Bikes: Indeed!
Quoted: 1508 Post(s)
Liked 3,480 Times
elcraft
Cable cutters. I am only slightly satisfied with my Park set. I have been told that Knipex makes a diamond patter cable cutter that is the best. Anyone able to,confirm this?
I'll agree with the cable cutters. I still need to get a good pair since mine just ain't cuttin' it.
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
I haven't cut housing with them, I prefer to use a dremel for that.
I also have a set of Knipex pliers and a flat wrench, both are also high quality and work great. Not cheap, but good tools never are.
Dale, NL4T
Dale, NL4T
I use the regular Knipex diagonal cutters (see post #10) for cable cutting. They work fine. It was the usual first choice when I worked in bike shops. Yeah it's just a straight cutter, but they cut so well that at most you might get a singe strand out place. Easily put back. Works for cutting spokes too.
Knipex does make a couple actual "wire rope" ie cable cutters also. I'm sure those would be excellent, but the quality of the regular dikes is such that they aren't really necessary. I have no idea what a diamond cutter is. They also make a bowden cable (housing) cutter IIRC. I prefer a Dremel for SIS housing.
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Torque wrench and digital calipers.
And I'll take a nice vintage Foredom flex shaft grinder over a Dremel any day.
The first time I used a torch wrench to tighten a crank bolt, I realized I've been under tightening crank bolts for years
Liked 6,389 Times
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
Ding! Ding! Ding! We have a winner.
Cable cutter, no question. Good ones work well, bad ones make a mess that you have to clean up with a good one.
Real cyclists use toe clips.
jimmuller
jimmuller
Uh oh. Looks like you’re out of lubricant.
[QUOTE=dddd;19986902]Not just for bikes, but you never know when your block and tackle will be facing off against 500+lbs of recklessly-applied rope tension, so find or buy good-quality tools for use on your your "barn fresh" bike finds.
Liked 645 Times
Ooh, that reminds me. How could we miss the obvious?
Beer. Life is too short for cheap beer, especially when you are working on a bike.
jimmuller
jimmuller
Quoted: 294 Post(s)
Liked 137 Times
Knipex, in my experience, are very high quality tools that you will only need to buy once. I carried a set of Knipex tools on my motorcycle when I rode the Trans-America trail. No room for errors or lousy tools on that trip.
Dale, NL4T
Dale, NL4T
:thumbup: on the cable cutter.
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
One that hasn't been mentioned is a good 4-sided spoke wrench. When building I'll still use the 3-sided park wrench for the first couple rounds of tensioning as it's quicker, but the ~full engagement of the 4-sided can be really nice for final tweaks.
Mine's also saved a few spoke nips and headaches on coworker's wheels I've touched up that hadn't seen so much as a quick wipe down since new. Which reminds, T9 Boeshield is also a great tool.
