Bike manufacturers forcing us/riders to 1x drive trains
#101
Gear inches is a meaningless number, but for road bikes, it's usually just the gear ratio times 27. I never use it anymore. Only a 42 large sprocket is needed.
#102
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 191 Times
Well, I'm mostly concerned with my 20inch(406) mini-velo/folders. So, I'd do that with a 58t chainwheel. Thank you.
BTW, I like that gear calculator, been using Sheldon Brown's for years.
#103
Quoted: 4717 Post(s)
Liked 1,882 Times
noodle soup when you say they have it solved I would agree to a large extent but would add the caveat - "in most normal riding conditions" - to it. Really though I just wanted to tell this story.
Narrow wide helps, Jockey pulleys with narrow wide help. Clutched RD's help....but they don't SOLVE it completely.
For road use(no mud), the chain drop issue has been figured out. 1x is still stupid for road though.
#104
Quoted: 1067 Post(s)
Liked 259 Times
On the rolling terrain I ride with no huge climbs my 46 F and 11-32 R suits me fine.
The gear spacing is close enough for me.
The gear range is enough.
Overall there is less cross chaining as at cruising speeds around 20mph I am right in the middle of the cassette.
With a double I am often in the small front crossing to the smaller end of the cassette or vice versa on the large chain ring.
#105
Quoted: 7653 Post(s)
Liked 3,481 Times
We had triples. Then compact chainrings "solved" the shifting problems and weight concerns of the triple.
Then mtb went 1x. Cross carried it over to the road market. It makes perfect sense in cross racing. Less stuff to break or clean each lap and the needed gear range can be hit easily and tweaked with 1x.
Criterium racing can easily utilize 1x very effectively.
Road racing in a 1x is plenty fine but does actually start to depend on the course.
Normal enthusiasts just riding along as their singular gearing setup to be used for the entire life of the bike in all conditions and applications? I would say 1x is a bit heavy handed there. The gearing ranges can be tweaked to "hit" everything a 2x would but it's still with some jumps and gaps that just aren't acceptable for me in particular.
What I have been thinking about is this bit:
We will see this all go one direction then someone will come up with all sorts of marketing reasons to go back the other way. We have consistently done this for generations. 1x will be no different. People will start heading back to 2x at some point. Then I am almost positive we will see triples come back with electronic shifting. Super tight gear ratios. Synchro shifting, etc.
Sure, three rings are heavy ... but a 42- or 50-tooth cog is Enormously heavy.
#106
The SRAM 10-52 cassette only weighs 300 grams, since the 52 is aluminum and there are many weight reducing cutouts. The problem with this is the very large jumps. I have a 48/32 crank with a SRAM 10-36 12 speed cassette that weighs the same and gives me a greater 540% range with much better sprocket spacing.
All 12 speed cassettes are pricey, but $185 for the 10-36 is a lot better than $450 for the 10-52. That's a lot of money for a wear item.
One problem with sequential electronic shifting is not knowing when a chainring shift might be made. That can lead to chain drops, if pedaling force is too high at the time of the shift. I don't use it.
#107
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
What I have been thinking about is this bit: I can see this---with electronic shifting programmed to auto-shift so the rider doesn't have to guess ratios ... super-quick shifts, lower Q factors because of the slimmer 12-speed chains and rings, a corn-cob cassettes and tremendous efficiency.
Like with all trends "If 32 is big then let's try 34!"....36...42...48..50....52 guys these are chainring sizes. The roads haven't changed. We aren't getting faster. We were already spinning up climbs with triples and even compacts. We are to the point where 12 speed mtb groups are starting to hit obstacles when the gap isn't set right because they're hanging down too far. It's gone beyond ridiculous. We will go back it's just a matter of who does it and when.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
#108
I eat carbide.
Liked 1,306 Times
The crazy part about front shifting under load is that you can easily do it with electronic. If you're riding electronic now just go try it on your next ride. Ease into it until you feel comfortable but front shifting under load is where electronic shines. If you're dropping your chain at all that's arguably your setup or the chain itself. With all the crap we have been making chains do lately they wear out long before the actual roller wear becomes an issue. Lateral play gets to be so high that i have seen chains that aren't worn out normally do some funky stuff.
Had a Di2 DA setup the other day that had been perfect since I set it up a year or two ago. Chains were swapped, etc. Then her husband got involved. She came in one day complaining the drivetrain was super loud now. I look and her husband installed a directional Shimano chain the opposite direction. I flipped it around but the damage was done. He started buying chains online to save money (I sell mine for whatever the going online rate is usually anyway but people never want to believe that). She came back with a new KMC SL chain. I installed it. she rode a few hundred miles on it. She came back because it was super load again and it was dropping occasionally on the front when shifted from large to small. "Only way that happens is if someone touched it and moved my setup."
After checking with the one mechanic that is closer to her that she sometimes takes he bike to she swore no one had ever moved it. I was about the throw in the towel but I kept playing with it. Noticed the chain made the front shift fine but she had semi-synchro so it also dropped two cogs on the back after the front shift was complete. In dropping those two cogs I saw this sort of waveform show up in the chain. That little wave was throwing the chain off the front.
Grabbed the chain and I can flex it sideways back and forth a ton. Chain "sounds" like a worn out chain on a drivetrain. "This was a new chain, right? Did he buy some sort of factory second or something?" "Who knows Rob. He's always trying to save a buck."
I grabbed a new Shimano chain, put it on. Sound went away completely (silent drivetrain now) and front shifting issue went away completely. Grabbed the KMC and held it out and it flexed sideways into almost a full circle if I could have held it straight.
So...if the front comes off under load under electronic then it's position or the chain
#109
Liked 1,882 Times
what do you mean by "12 speed mtb groups are starting to hit obstacles when the gap isn't set right" ?
#110
I eat carbide.
Liked 1,306 Times
On a mountain bike 1x and a huge 10-51t cassette works great because you don't really need a tight spaced cassette, but that same cassette would be horrible on the road.
Regardless the derailleurs are starting to become monster truck style ridiculous and there's only so much chain you can wrap.
#112
Quoted: 4806 Post(s)
Liked 3,932 Times
I was thinking about something I heard about (didn't see) but now that I think about it they were running 26" and/or 27.5". Between the smaller wheels and the cassette choice - blamo. By gap I meant gap to the ground
#113
I eat carbide.
Liked 1,306 Times
Tubeless, I9, Rim brake - 26". let that stew for a minute.
There are riders with nice rigs that refuse to let them go.
#114
I eat carbide.
Liked 1,306 Times
#116
I eat carbide.
Liked 1,306 Times
#118
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
BTW... 650b are around.
#119
I eat carbide.
Liked 1,306 Times
27.5 for sure are available but 26.... There used to be a lot but last time I looked I could hardly find anything. Last month I had to buy up the remaining inventory (at retail) for a particular rim that finally went out of production and isn't coming back in 26. I have a benefactor that wants to use that rim specifically so - gotta keep it in house.
#120
Quoted: 18883 Post(s)
Liked 10,646 Times
Has anybody contemplated 0x?
Likes For Seattle Forrest:
#121
Non omnino gravis
Likes For DrIsotope:
#122
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
Likes For Sy Reene:
