#2376
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
Would beating a frame with a wrench qualify for this thread...?
Likes For jdawginsc:
#2377
Quoted: 5888 Post(s)
Liked 3,471 Times
It's time to get my 1988 Stumjumper Comp roadworthy again. I had it built up with drops and 3 x 8 gearing but I've decided to rob the wheels for a different build. The wheels currently on the bike can be used with disc brakes and I'll use them on a surly 1 x 1 that I'm building up.
So I'm going 3 x 6 with the Stumpjumper as this will let me use the original wheels (130 mm 6 speed uniglide Deore XT hubs and specialized rims). They're a bit beat up and have some rust issues so I'll deal with that. Plus I plan on putting on a set of continental winter contact tires since the weather is starting to get colder in central Iowa. It has been a great commuter but 3 x 8 was overkill (heck 3 x 6 will be overkill).
Likes For bikemig:
#2378
Quoted: 57 Post(s)
Liked 41 Times
This afternoon's wrenching was installing my new Selle Italia saddle on the 1983 Bridgestone Spica, and fine tuning the fit. Still tweaking the fit, and it's better than the original medieval torture device aka saddle the bike left the factory with.
#2380
Edumacator
Liked 3,136 Times
#2381
Quoted: 741 Post(s)
Liked 818 Times
I swapped saddles on my '07 Roubaix (not vintage, I know) from the original Specialized Avatar, which is gel topped with a center cut out. It's been bugging me for awhile, and being a big Brooks fan, decided to give the Cambium C17 a try. I've got 3 B17s and two Pros on my vintage bikes, but wanted something a little more modern and all weather, but, with Brooks quality, fit and comfort. I must have got the placement about right, because on an 11 mile ride later, I kind of forgot it was there. I do scoot around on the saddle a lot when I ride, and was concerned that the cloth cover might be too grippy, but it felt fine. So far so good. There is a 40 mile club ride tomorrow, but with big time winds predicted for SoCal, not sure if I'll ride. I posted this here because some of you vintage riders might want a modernish, "vegan" Brooks alternative.
Thev "rivets" look huge, but seem fine on the ride.
I like the die cast base.
#2382
Worked on getting rest of paint off ss frame. Weather to cold to paint, so I get to admire the fillet brazing over the winter.
Likes For Kdogbikes:
#2383
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Quoted: 246 Post(s)
Liked 338 Times
#2384
Quoted: 7351 Post(s)
Liked 2,479 Times
Video, or it didn't happen.
Likes For 2cam16:
#2386
Quoted: 796 Post(s)
Liked 522 Times
The vintage 700c wheelset I got from @brian3069 arrived, extremely well packed I might add, They are the exact spec that the Allez frame I got from @tricky would have come with, 700c wobler rims and SunTour GPX hubs. I put some Panaracer RibMo's I had laying around on them to see if the 700x28c would fit on the frame. I am still waiting on a 7 speed FW for this bike and then I will give it a ride. The red treads tires on the red frame bike weren't as garish as I feared...
#2387
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
@ryansu.....
those wheels look right sharp! not too garish at all. imo, what makes it all work is the vintage wheelset. no standout modern graphics or rim profile. tasteful, modest embellishment! hope you post the finished project
#2388
Quoted: 1088 Post(s)
Liked 1,205 Times
Picked up a couple of Suntour VGT Luxe mechs at the coop, one of them branded “Vista,” and I started tearing that one down. The crustier the better, I say.
#2389
Eccentric Old Man
Quoted: 248 Post(s)
Liked 173 Times
Cleaning up the drivetrain after my gravel event.
The GF says " Did you know you left the oven on? Oh I forgot you have a cassette in there."
#2390
Quoted: 634 Post(s)
Liked 444 Times
@ryansu did the 28s fit both front and rear? My Sirrus would only accept 25s
#2391
Quoted: 796 Post(s)
Liked 522 Times
I am loving seeing this come together.
for down the road
Likes For ryansu:
#2392
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
Trying to finish an '80s Bertoni and running into a problem using a Sunrace 7-speed freewheel with the Nuovo Record rear mech. On another bike, this freewheel works so well with a Super Record RD that I wanted to use it again here. Plus, the chromed 7-speeds are the nicest looking freewheels Sunrace offers.
After many struggles, turns out the main issue is using a 9-speed chain. It was making a racket with its pins randomly catching on the bottom of the cage (at the lower pulley) while on the two biggest cogs. An 8-speed chain was quiet.
Weird. I had used narrower chains before with 7-speed freewheels... Hmm. But maybe not with NR derailleurs.?.
Anyhoo ... the Miyata now has the chromed 7-speed fw, and its NR rear derailleur likes it. The Bertoni and its short chainstays gets a 6-speed fw and a fat chain.
This is for the best. I can go back to having 5mm of axle in the Bertoni's drops. Earlier, it was down to 2-3mm on each side. Probably enough, but now, no worries. Less wheel dish should help a bit, too.
Now to find a use for this 9-speed chain. Maybe I'll flog myself...
#2393
Liked 2,479 Times
Build a new bike around it. Is that sufficient flogging?
Likes For noglider:
#2394
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...if you look at your pulley widths in your NR rear derailleur, I think you'll find that if you compare them to other makers pulleys they're a little wider (along the bushing, not the diameter of the pulley.) I've never tried them with a chain narrower than an 8 speed, but that might be a reason.
Likes For 3alarmer:
#2395
Barred @ Velocipedesalon
Hercules roadster front wheel rebuild
Missing spokes, surface rust on rim and "out of whack". Removed front wheel, stripped down, cleaned and repacked hub (Hercules HR PATTERN), hammer and wood block "trued", and cleaned rim inside and out (Dunlop 26 x 1 3/8), replaced spokes (stainless 285mm), replaced nipples. Laced my first wheel ever. Still need to true it up and remount next week at the bike co-op.
Likes For HPL:
#2396
Liked 2,479 Times
A few weeks ago, the rim on my Raleigh broke. Those Pacenti PL23 rims are no good, and apparently, this happens to a lot of people. Today I rebuild the wheel with an H+Son rim. I could have just done a rim transfer, but I took all the spokes out and re-laced the wheel only because I had forgotten to put my trademark on the wheel before: a rubber band around the hub.
Before:
After:
Before:
After:
Likes For noglider:
#2397
Just call me Carrie
I've been making my husband strip down a Miami Vice Ironman before it goes to its new home. I just did maintenance on my bike and kept him company.
Likes For thinktubes:
#2399
Quoted: 293 Post(s)
Liked 218 Times
Installed the BB, crank, stem, bars and applied decals on the SS/fixed ‘71ish Gitane Super Corsa build.
#2400
señor miembro
Liked 6,491 Times
Likes For SurferRosa:
