Proof that a QR compresses the axle?
#176
Quoted: 947 Post(s)
https://www.com-ten.com/images/super/ST1-vert.gif
#177
When I was a young automotive machinist, my mentor performed a demonstration of the flexibility of metal, in this case, cast iron. He set an inside micrometer with just the right tension that it would barely "hang" inside the top of a cylinder bore. Then he squeezed the cylinder with his hand or both hands perpendicular to micrometer and the micrometer would drop to the bottom of the cylinder to be caught by a rag.
#179
Quoted: 981 Post(s)
Liked 584 Times
1) Use the same set-up to measure the apparent decrease in axle length in the vise.
2) Place cylinders over the axle stub ends to limit the compressive loading to the locknut/cone assemblies and the axle between them and measure the apparent decrease in length.
Prediction: The length change will be slightly less when load is applied to the locknuts, reflecting the shorter length of axle being compressed. This may be too small a change to measure.
Problems: The big one is tightening the vise the same amount both times; I suppose I could put a torque wrench on it. It might be possible to get the dial gauge closer to the axle and certainly more parallel!
The other issues (plate "flex", vise friction, etc.) would pretty much cancel out. There is no significant "slop" in the arrangement because the axle is under *slight* compression to start.
Anyway, that would be the best I could do.
Steve
#180
Quoted: 947 Post(s)
I looked into load cells for the heck of it... way too expensive. But I think I could make an improvement on my previous try. Here's the idea:
FIFY
Steve
FIFY
Steve
If your bench vice is anything like the two I have, I wouldn't trust them for accurate anything. Good for clamping and holding things and that's it. Slop in the screw and where the vice jaws slide causes intermittent binding that would make it impossible to be sure I could duplicate pressures from one clamping session to the next. Even if you could ensure a "reasonable" duplication of pressure, without knowing how much pressure you are actually applying and if that pressure is equal or close to what a QR would apply. It would give us erroneous results. Unfortunately I think we hit a dead end unless someone has access to the kind of equipment we need.
I have a pretty good hydraulic press, If I can think of a way of measuring pressure on the cheap, it might be of use to us.
#181
You can easily test it yourself. Pluck the top spokes. Load the wheel and pluck them again. Does the sound change? Neither does the tension.
It's good to always question things, but one must also consider a possibility of being wrong themselves, usually by missing an important factor that plays a part. I was also certain the wheel hangs from the top spokes, it was "only logical!" "PERIOD", as you put it.
#182
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Yup... the change in tension of the upper spokes is <4% of that undergone by the lower spokes. So, you are right: we could say--e.g., the axle hangs 'hangs' because it seems logical since the tension increases but that would be an erroneous conclusion given the far greater change in the tension on the lower spokes, which become shorter due to compression but are still rigid enough to support the weight of the bike like a column because they're still under tension.
#184
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 741 Times
Tire is pressed at ground contact point. It's force pulling the wheel outwards is diminished at contact point, while it's inward pushing force (from pressure) remains the same all around. The reduced pulling force causes less spoke tension in the down spoke or two. The spokes next to the lowest one/two get a little bit of extra tension, but not as much as it is lost due to tyre's lowered "pull". It is explained, tested and confirmed.
In the previous post I provided the name of the book that explains it, as well as a link to a PDF on-line file that experiments with it.
#185
Liked 741 Times
I like the way you think
and bench vise jaws move all over when imparting load.... rather crude, but effective tools, bench vises... i have four of them, presently.
#186
Quoted: 947 Post(s)
I do not think sophisticated equipment is required. A nut that is screwed down with enough force to prevent the axle from dropping out of the dropouts is pretty easily accomplished without having to deform the axle in the process (just like locking a nut in place by backing it up with another nut doesn't take so much force as to deform the threads). A Quick Release is nothing more than adding a lever and a cam to a nut (resulting in an action which has been compared to putting a chock behind a wheel to keep the truck from moving).
#190
Lets do this the other way. When you tighten a bolt it stretches. In the refinery we had vey high flanges with 3and 1/2" bolts holding them together. We had a device that allowed us to stretch 4 bolts at a time with 12500 pounds of hydraulic pressure that allowed us to rotate the bolt by hand. When the pressure was released the bolts were tight and unmovable and held back over 2500 pounds of product pressure.
If we could stretch them a like pressure would compress them.
#191
Mostly harmless ™
Liked 216 Times
try a better "ear"... like a seiko quartz guitar tuner... the top spokes change tension, but the change is not to just one spoke, it is spread in a diminishing pattern, working outward from the topmost spoke.... and the more horizontal spokes will bend slightly, since the tension induced friction at the j bend is usually higher than the force required to swing the spoke at the hub.
#192
#193
Liked 741 Times
you assume much, but know little.
hub shifts, tension shifts.
QR forces everything to shift on axis of pressure...
the threads( both inner and outer)are the weak link.
the threads bend, or FLEX... the inner threads are part of the axle... the cones and jam nuts are part of the axle ASSEMBLY....... to simplify for public consumption, "The Axle FLEXS".
#195
Mostly harmless ™
Liked 216 Times
Provided one experiment (a measured one), one you can do at home (that you disputed by my bad hearing) and one book that has been accepted as correct and good one - but you still don't seem convinced. It is possible we could all be wrong, but your arguments are not convincing enough to convince me, just like mine aren't convincing you obviously.
#196
Liked 741 Times
no? i did.
done.
#197
Mostly harmless ™
Liked 216 Times
Also note the number of spokes on that side of the rim. The total increase in tension will not be close to the decrease in tension of the bottom spoke(s). Using the same load, of course, and making sure it is vertical, not sideways applied. Also, either use the same spoke, turning the wheel, or first check whether all the spokes on that side have uniform enough tension. Plucking each (position) 3 times, to eliminate any measuring mistakes.
Absolute tension (change) can then be calculated if spokes are of known material (steel?), length and thickness.
#198
You're definitely onto the flaw in the logic of the 'hang' theory. If we imagine a single piece of rope perpendicular to the ground instead of spokes above and below a hub we'd really have the intuition of 'hangers' fuming when we don't agree with their logic. Nevertheless, if we draw the rope taut, and attach a weight in the middle, if the change in tension on the portion of the rope below the weight is greater than the portion above the weight, the logical conclusion is that the portion below the weight is supporting the most of the weight just as we would conclude that a solid column -- like a wood spoke on a wagon wheel -- was supporting all of the weight.
#199
Liked 741 Times
Don't have refined equipment. Can you measure spoke frequency of a single spoke on a statically loaded wheel as you position it at 12, 1.5, 3, 4.5 and 6 o' clock and let me know? The frequency change at 6 o'clock should be by far larger than any other position frequency change.
