Flat Bar Gravel Bike
Old 01-10-21, 02:23 PM
  #51
merida
Quoted: 8 Post(s)
1995 is presenting the perfect gravel machine , -lightweight, wide range gearing and as aero as you like... ;-)
merida is offline
Old 01-10-21, 02:57 PM
  #52
Moisture
Drip, Drip.
Moisture's Avatar
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times in 163 Posts
Originally Posted by goatalope
Any body put a flat bar on a gravel bike? Would like to see pictures.
For context... Here in central Pennsylvania, a lot of the "gravel roads" are fire roads. The main fire roads are pretty well maintained, but its easy to branch off and it'll quickly turn into more like ATV paths (often with rocky or muddy sections). I often would like the control of flat bars, but don't typically need suspension. So I'm thinking either a flat bar gravel bike or a rigid mountain bike. But so many mountain bikes are solely 1x now, which I find limiting.
So anyways, I keep picturing a Trek Checkpoint (or something similar) with a little longer stem and 690-720 wide flat bars. Anybody have an example? Thanks!
I got flat bars on my road bike.. its definrly setup quite well for gravel.
Moisture is offline
Old 01-10-21, 05:24 PM
  #53
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times in 240 Posts
Originally Posted by badger1
Flat-bar gravel bike? Readily available at your local Specialized dealer. Stock, and ready to go, with 38mm Tracer Pro tires. Mine (below) has had a tire change, but that doesn't change the character of the bike.
model?
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
stevel610 is offline
Likes For stevel610:
Old 01-10-21, 05:27 PM
  #54
MrWasabi
MrWasabi's Avatar
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times in 36 Posts
I think that is a Specialized Diverge Comp EVO. I'm eyeballing one or an Expert Evo if I can find one in medium.
https://www.specialized.com/us/en/di...ext=96220-5602
MrWasabi is offline
Old 01-10-21, 09:50 PM
  #55
badger1
badger1's Avatar
Quoted: 1581 Post(s)
Liked 1,189 Times in 605 Posts
Originally Posted by stevel610
model?
Mine is a 2019 Specialized Sirrus X Comp Carbon. It is now called the Sirrus X 5.0 -- same bike: https://www.specialized.com/us/en/si...ext=92421-3001
Tire clearance is limited to around 38s (stock), though some have managed to squeeze 42s in there. I wouldn't, but some have. One would also have the option of dropping to 650B to get a wider tire.
badger1 is offline
Likes For badger1:
Old 01-11-21, 05:39 PM
  #56
KeatonR
Bikes: Gunnar Hyper XF, Jamis Dragon Race, Surly LHT
Quoted: 24 Post(s)
Liked 19 Times in 9 Posts
Mine's a touring frame (Surly LHT) that I mostly use as a town bike, but without the rack it would make a pretty good gravel bike. I bought this used years ago and converted it to a flat bar, and then more recently upgraded the wheels and tires (Mavic 35mm tubeless) and the gearing. The bar ends have fallen out of fashion, but I sure do like the hand position they provide for accelerating and climbing.
KeatonR is offline
Old 01-12-21, 08:30 AM
  #57
Phatman
Quoted: 129 Post(s)
Liked 97 Times in 51 Posts
I put flat bars on my Kona so that it would feel a bit more casual for "townie" type rides and pulling the trailer with my 14 month old son. To be honest though, I'm not crazy about it and haven't really been riding it much, I go back and forth between doubling down and getting some mtb discs and a riser bar, or just selling it.
Phatman is offline
Likes For Phatman:
Old 01-12-21, 09:01 AM
  #58
Moisture
Drip, Drip.
Moisture's Avatar
That is a really nice bike, but only for someone who fits well on that frame.
Moisture is offline
Old 01-12-21, 09:08 AM
  #59
Phatman
Quoted: 129 Post(s)
Is this generation of Kona known to be hard to fit onto?
Phatman is offline
Old 01-12-21, 02:47 PM
  #60
996
Quoted: 96 Post(s)
Liked 9 Times in 7 Posts
Check out Marin if you haven't already. They just released the DSX1 and DSX2 - Flat bar gravel with a great groupset.
https://www.marinbikes.com/bikes/2021-dsx-2
996 is offline
Old 01-13-21, 04:52 PM
  #61
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10965 Post(s)
Liked 7,492 Times in 4,189 Posts
He just says stuff that is obvious, pay no mind.
Of course that bike is only nice for someone if it fits them. That applies to really any bike.
mstateglfr is offline
Likes For mstateglfr:
Old 01-14-21, 12:55 AM
  #62
bwilli88
Not lost wanderer.
bwilli88's Avatar
Quoted: 886 Post(s)
Liked 999 Times in 525 Posts
My modified Hybrid, Works very well for road and gravel and most anything but mud.
Shimano Deore XT 9 speed RD and shifters.
My Centurion Pro-tour.
bwilli88 is offline
Likes For bwilli88:
Old 01-14-21, 03:50 PM
  #63
csrpenfab
Quoted: 76 Post(s)
Liked 99 Times in 57 Posts
My backup gravel bike is a flat-bar Trek FX6S. It's now got tubeless Schwalbe 38c G1's and does pretty well on the gravel. It's not quite as nimble as my main gravel bike (Niner RDO RLT9), but it rides nice and is good for less serious gravel rides or cruises with the wife.
And for the more serious gravel adventures:
csrpenfab is offline
Likes For csrpenfab:
Old 01-16-21, 07:07 AM
  #64
MrWasabi
MrWasabi's Avatar
Quoted: 124 Post(s)
Since finding new bikes lately isn't that easy, I'm going to stretch some more life out of the Fuji for now. What flat bars does everyone like that I should checkout if I make a change there? The stock bars aren't bad I just think I could do better. I have some FSA Afterburner bars (15mm rise/31.8, 9 degree sweep/685mm) in my stash I was going to put on, maybe trim 15-20mm off each side. I'm doing a grip/shifter change at the same time so this would be a good time to change bars if I do.
Link to my bike:
https://archive.fujibikes.com/2014/Fuji/traverse-132
Thanks for any input.
MrWasabi is offline
Likes For MrWasabi:
Old 01-16-21, 07:22 AM
  #65
Paul Barnard
For The Fun of It
Paul Barnard's Avatar
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times in 829 Posts
Paul Barnard is offline
Old 01-16-21, 01:28 PM
  #66
pbass
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times in 211 Posts
Link to my bike:
Depends on how much rise and sweep you like, and how you will ride. For example, on my Cross Check right now I have Salsa Moto Ace bars that have no rise and very little sweep (like 5 percent). They're really "flat". I trimmed 'em a bit narrower too. They replaced some Origin8 Space Offroad bars with significantly more backsweep, more of an "alt" bar though not as extreme as a Jones, etc. I like them both, it just changes the personality of the bike. I converted the bike from geared w/the Origin 8's, which gave the rig a very relaxed sort of touring vibe, to a singlespeed with the Salsas and it became an aggressive bomber - my "fun" bike.
pbass is offline
Likes For pbass:
Old 03-26-21, 04:11 AM
  #67
lesoudeur
Converted Giant Seek 0 to Afline 11 speed to gravel bike lol
Lots of upgrades from the original bike. Tyres are 38mm which is about the widest I can get on the frame.
lesoudeur is offline
Old 03-26-21, 09:54 AM
  #68
chaadster
Thread Killer
Quoted: 3148 Post(s)
Liked 1,713 Times in 1,034 Posts
I didn't convert mine-- I bought the Cafe+ as Breezer's flatbar variant of the dropbar Doppler; same frame-- but I did just change the type of flatbar. The stock bar was a backswept "W" shaped bar-- do those have a specific style name?-- which was really comfy and cool looking, but being an old school bro, give me flatbars and I want bar ends, but I just couldn't find any with enough angle to keep an angled-ing attitude with the amount of sweep on the Cafe+'s bars. Well, I accidentally tripped across some super-steezy State Bicycle riser flatbars (oxymoronic, no?), and after I was done being blown away by how steezy the oil slick finish would look with my Avery-Dennison Ligntning Ridge Colorflow wrapped fenders, I realized the bar paved the way for the addition of some Paul Chim Chim's, too, so I went for it! I had to lop off a whopping 2" on both ends-- and it's still wide!-- but it looks sweet! Now the big question is purple or black Chim Chims...
chaadster is offline
Likes For chaadster:
Old 03-26-21, 12:15 PM
  #69
franswa
franswa's Avatar
Quoted: 324 Post(s)
Liked 251 Times in 105 Posts
^^ that’s sick! Is that one of those locks that were part of a Kickstarter a few years back?
franswa is offline
Old 03-26-21, 01:23 PM
  #70
chaadster
Thread Killer
Thanks! And yeah, that's an original, first gen TiGr lock, the first Kickstarter I ever supported, I think! I love that thing; I have two TiGr bows, actually.
Old 05-10-21, 09:44 PM
  #71
shortnugly
shortnugly
Bikes: 2010 Cannondale CAAD9 Old Raleigh Technium Peak
Quoted: 5 Post(s)
Originally Posted by mj0
I use my rigid 29er for gravel, love it!
ehh,... not buying it. I dont think you ride the bike with the seatpost that high and the bars rotated down like that. Probably looks extreme for a photo shot but would be brutal for about a 1/2 mile or so.
just sayin
shortnugly is offline
Old 05-10-21, 10:49 PM
  #72
chaadster
Thread Killer
just sayin
I ride mine with about 11cm of saddle/bar drop, and I can’t believe I’m the only one.
Old 05-11-21, 08:15 AM
  #73
blakcloud
blakcloud's Avatar
Quoted: 608 Post(s)
Liked 352 Times in 225 Posts
These are what I call our picnic bikes and they handle gravel with aplomb. Rivendell has been making this style of bike for years long before "gravel" became a thing. Pictured with Grand Bois Hetres 42 mm tires.
Sam Hillborne
Betty Foy
blakcloud is offline
Likes For blakcloud:
Old 05-11-21, 06:13 PM
  #74
mj0
Quoted: 17 Post(s)
Liked 5 Times in 3 Posts
just sayin
I'm 6'3 and coming from a road bike the position is fine. The bar is the Ritchey Dive Bar and is meant to be upside down like that. For gravel it's great but i've actually flipped it to be like a normal bar for rougher terrain:
mj0 is offline
Likes For mj0:
Old 05-11-21, 07:01 PM
  #75
pbass
Quoted: 284 Post(s)
Here's my flat bar Surly Cross Check. Currently singlespeed, running Nanos. Used to be drop bar and geared but I have another bike that covers that, so this is now set up as my "fun" ss shredder
pbass is offline
Likes For pbass:
