What Else Did You Just Buy For Your Bike? Thread Thread Thread..... Thread
#3076
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
https://www.amazon.com/Shimano-SH-M0.../dp/B00MRH0GA8
Birthday money + REI = points. Been really happy with the fit and quality of Shimano shoes so these should be no different. I have odd shaped feet and this style of shoe really seems to fit me the best.
#3077
Bikes: Cannondale CAAD12, Specialized Rockhopper, Norco Fluid FS1
Quoted: 127 Post(s)
I don't have the new Cannondale yet, the frame doesn't ship until November, so I haven't ridden the eTap other than the test bike at the shop.
I really liked it. Everyone complains about the front shifting, but I really only change my front when I'm climbing, so I'm not that worried.
That said, the Mr. Pink came with SRAM Rival, and I give it a "meh" review. I don't mind it at all, but if I shift up the cassette in the back and then decide to shift back down right away, the front drops to the small ring. I'm not sure if it's not setup correctly, or if this is just a SRAM thing, but it's super annoying. I usually always shift to an easier gear at red lights, but then if the light turns green, I'll shift back and go to hammer, but my chain drops and all I do is spin. At first I thought it was just a misshift but now, I can replicate it every time. I need to do some googling and see if there's a fix.
I double shift front rings and cassette a lot, and that's not possible with etap so I'm not too jazzed about it. Whenever I go from big ring to small ring I drop like 2-3 cogs smaller in the cassette so the cadence change isn't that big, and the opposite when I go from small to big ring. I wasn't able to do that with etap, so I wasn't super duper impressed. I bet I'd get used to it pretty fast if I used it for more extended periods of time, but my parking lot test ride of our demo bike left me with that impression. The hoods were super comfortable though so that was cool.
#3078
Quoted: 127 Post(s)
I got a Fizik antares 00 saddle for super cheap, some white fizik tape to match, and some white s works shoes.
Also got a free pair of Bontrager RXL mtb shoes, so I bought a Trek Boone 7 so I could use those shoes.
My wallet is considerably lighter now.
#3081
Quoted: 686 Post(s)
Liked 5 Times
That doesn't sound normal for the chain to drop like that. I haven't had that issue with any of the sram I've dealt with.
With the eTap is it possible to just hold down the right so it starts shifting the back then press the left while still holding the right to drop the front? There are only a couple of short steep hills in my area where I do the double shift, and that's usually only if I'm trying to strava the **** out of them. For the most part, I'm a lazy sob and only strava with a tail wind, haha.
#3082
Quoted: 127 Post(s)
I'm going to have to mess with the derailleurs and see if I can make it better.
#3083
Quoted: 127 Post(s)
Its mostly gonna stay stock except for the cockpit so it's not going to be in the same level as the evo, but it'll definitely be a sweet bike. I don't know how good I am at cx or how much I'm gonna like it, so I'm gonna keep it relatively low key for now.
#3084
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
You shift up to a higher gear or down to a lower gear and it figures out whether to shift the front, rear or both.
Pretty sure it hasn't been released yet but it is something I'm interested in, if only to see how it works.
-Tim-
#3085
Quoted: 127 Post(s)
Probably not news to you but Shimano 9100 is supposed to have linear shifting as something the rider can enable.
Pretty sure it hasn't been released yet but it is something I'm interested in.
-Tim-
-Tim-
Also, with shimano's whacked out releases, we're prob not going to see 9170 readily available until like March or so
#3086
- Soli Deo Gloria -
Liked 736 Times
Shimano has released syncro shifting for the mtb di2 group for a while now, and I think it got some mixed reviews. It would sometimes shift the front at inopportune times, and kinda screw with the flow of the ride because front shifting usually takes a little longer than rear.
#3087
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
iirc all the electronics can be programmed to shift in a linear fashion, but ive never cared to use one so i have no real world experience
#3088
Quoted: 686 Post(s)
Liked 5 Times
Yeah, my ultegra di2 on my current Cannondale has never had the firmware updated...which I'm pretty sure means I can hack it to run 11spd, but I never cared enough to try.
The thing that I like most about the eTap is the ability to swap batteries on the road. I suck at charging things and my di2 would always die out on a ride, at least now I can just take the battery from the front and use it in the rear.
#3089
Quoted: 127 Post(s)
When you get etap, remember to charge at least one of your batteries pretty often. They're much smaller than the di2 battery and don't last as long as di2. We charge our demo unit's RD battery like once every two weeks, so it's easy to get behind on that and be stuck without a front derailleur.
#3091
Quoted: 686 Post(s)
Liked 5 Times
If you have 6770 derailleurs, you can't make it 11s without doing something that wasn't intended for it to do, but if you get some 6870 derailleurs, you can reuse your shifters, battery, and cables.
That's what it was about ultegra di2, I knew it was something, the hassle of swapping stuff for one extra gear just didn't seem worth it to me.
#3092
Quoted: 127 Post(s)
Yeah we usually suggest that as an upgrade if someone crashes and wrecks a rd or something. Relatively easy swap to 11
#3093
Quoted: 686 Post(s)
Liked 5 Times
Back on topic of buying things...
I grabbed a Castelli Gabba 2 jacket from Competitive Cyclist since they had them for half off...it came today, very nice!
Castelli Gabba 2 Convertible Jacket | Competitive Cyclist
#3094
Quoted: 1332 Post(s)
Liked 398 Times
Castelli stuff is nice. I found two of their jerseys at a Goodwill store a while back for eight bucks each. One of them doesn't fit me, so coincidentally, if anyone wants a size M Castelli jersey brand new with tags still on, hmu.
#3095
- Soli Deo Gloria -
Liked 736 Times
If you create an account at the Morvelo website it will drop the price about 15% from advertised.
Wiggle resells their stuff and has some good sales.
Let me know if you have any questions about fit. I own eight of their tops and hope to be trying their Nth series bibs this fall.
#3096
Bikes: Surly Pacer, Felt Brougham
I purchased these platform pedals for my Wabi. They are made by Motobicycle, a company in Berlin and distributed by Pedego Electric Bikes in Myrtle Beach. I also had some Armadillo All Condition tires installed.
#3099
Bikes: '17 Access Old Turnpike Gravel bike, '14 Trek 1.1, '13 Cannondale CAAD 10, '98 CAD 2, R300
Quoted: 1571 Post(s)
Liked 12 Times
I noticed yesterday one of my pedals on my daily rider wasn't clipping... it broke. I use the Wellgo WPD-823 MTB CR-MO Clipless Pedal. $25 via Amazon. New pedals should arrive tomorrow.
I road another of my bikes today. I also have other pedals I could have put on. But I really like these Wellgo pedals.
