Quick questions and answers
#201
Car-free in the South
I'd still ride that, but then again if I were worried about performance and chain wear I wouldn't use a bottom end part. My self, I would probably return this obviously damaged part, even if only cosmetically, and put out the cash on something a little nicer.
#202
EDIT: On second thoughts, for a few quid extra I might as well get a Surly sprocket that will last a while longer.
#203
Thanks for the quick response. You're right: I'm not after high-end performance (the main limiting factor here is my fitness - or lack of), so I might as well use this part. The chain doesn't really touch any of the marks on the sprocket anyway.
#204
Morning All. I just have a quick question that I figured was best answered here. A girl I have been seeing, recently changed from drop bars to a flat bar with a little rise on her Surly Steamroller. Obviously her old top-mount brake levers won't work. She needs a 25.4 clamp and I cannot seem to find one to replace them. I see a lot of 26's but .6 is a big gap. Any suggestions? I have provided a link below to her new bars. Thanks for you time and thank you for all the help this forum has already given me.
https://www.jensonusa.com/!bAktMmFqNh...FQtgMgodJ0cAog
#205
Fixie Infamous
Bikes: 2007 CAAD Optimo Track, 2012 Cannondale CAAD10, 1996 GT Force restomod, 2015 Cannondale CAADX
Quoted: 54 Post(s)
I just googled "25.4 brake lever" and got plenty of results.
#206
Your cog is slipping.
Hello all,
New poster, though long-time lurker.
I have just received a new Miche 1/8" Track Sprocket. It has lines and scratches all over it, please see photo. Will this affect the performance, or wear my chain down quickly? Should I return it to the shop, or am I just asking too much of a botton-of-the-range sprocket?
The actual teeth are OK.
Thanks in advance for any advice!
Simon.
Simon.
They're not scratches, that's just what they look like on the underside. You can't expect jewelry quality machining of a $12 cog.
It's perfectly fine.
#207
#208
I know not to expect too much from a cheapo part, though the 17t Miche sprocket I bought a little while ago did not have these grooves. There are lots of little scratches on it as well, though I know they won't affect the workings. Anyway, it has at least made me realise not to skimp on some things.
#209
Again, they are not "scratches". Those marks occurred when the steel sheet the cogs are cut from was initially manufactured.
The machining of the teeth is what's actually important and Miche cogs are good.
#210
Quoted: 399 Post(s)
Liked 274 Times
#211
She wants her levers out by the grips, not in by by the stem, right? Unless you want to have to shim them, you should not be looking for 25.4 or 26.0 clamp levers. The ends of riser bars are generally 22.2mm. BMX or mountain bike style levers with a reach compatible to work with road calipers are what you should be after.
#213
does a piece of a scrap inner tube work well as a patch?
i just bought a big thing of vulcanizing fluid and wonder if i should buy a pack of patches too or just use cut up pieces of inner tube. i assume if i sand it down it and clean it it should work fine right?
#215
Fixie Infamous
Quoted: 54 Post(s)
Get on ebay and buy a hundred pack of patches from China for like 2 bucks.
#216
Ride more
Bikes: 2013 State Midas, 1988 Raliegh Technium
Did I just piss away 3 hours of my night?
So I got hit awhile ago, front wheel got trashed and got a new wheelset out of the ordeal. So tonight I was bored and was trying to be all mechanical and use my rear rim and spokes to lace to my front hub. I haven't fully trued up and tightened the wheel because I don't have a spoke wrench or a stand but, I checked the hub flange width and discovered the rear was narrower than the front, did I waste my time? I didn't want to use the front spokes because they are bent, but can they be reused if I'm trying to be as thrifty as possible? Both front and rear wheels were 3x.
I guess I did learn how to 3x lace though...
#218
Spoke length calculators exist for a reason.
#219
Ride more
#222
Do you grease the inner hub before you put the cartridge bearings in? (formula hubs)
#224
Quoted: 399 Post(s)
Liked 274 Times
I need a set of new, low-priced drop bar brake levers for a project I'm planning.
After a bit of shopping, it looks like Tektro is the way to go. But I've run across a buttload of different versions from them. My hands are small & the handlebar I will be using is small too, so I would like a compact lever with a short reach. Can anybody here steer me to which Tektro model is the right choice in this case?
TIA...
TIA...
#225
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
Universal Cycles -- Tektro R341 Brake Levers
