Using Jagwire with C&V Campy?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
BTW, just rub it with a cloth? Or is there a more involved process?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
señor miembro
Liked 6,488 Times
I've pretty much stopped using shift housing with friction components, because I've found the tiny housing cables fray through the housing end over time and the shifting gets sloppy. Maybe this is due to using regular brake housing ferrules instead of the smaller ones specific to shift housing, I dunno. Often, the cable stop in the derailleur or frame won't accept a ferrule at all. But I don't have the same problem over time using brake housing.
Quoted: 987 Post(s)
Liked 641 Times
Any caveats for cutting any of these types of housing to length? Years ago, I just used diagonal cutters and filed and jagged edges clean. Did buy a cable cutter recently but don't want to "close off" the cut end using it for housing.
señor miembro
Liked 6,488 Times
I just use my Park cable cutters, trying to snip the housing very quickly. If it gets a little mangled on the end, I use the cutters again on the exposed coiled cable to clean it up. Sometimes (but not often) a needle is used to open the liner afterwards.
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...a bench grinder wheel and an ice pick work pretty well to clean up the ends, but not everyone has room to keep a grinder set up. A file works, just works more slowly. If your cable cutter is really sharp, and you don't use it for anything else, you can often get away with just the cable cutter.
Quoted: 987 Post(s)
Liked 641 Times
Quoted: 987 Post(s)
Liked 641 Times
Also BTW, is there an ideal measurement for the height of the brake cable loop above the bars? I've always done it by eye, and what I have currently looks a little low.
señor miembro
Liked 6,488 Times
Quoted: 987 Post(s)
Liked 641 Times
After about 50 miles, impressed that I so far am not seeing the expected cable stretch. Brakes and shifting both seem firm, and smooth.
Bikes: 68 SS, 72 Fuji Finest, 72 PX-10, 77 Pana Pro 7000, 84 Pinnarello Treviso NR, 84 Trek 520, 88 Project KOM, 90 Trek 750, 91 Trek 930
Quoted: 184 Post(s)
Liked 204 Times
Cut with a piece of scrap cable in the housing so it does not collapse. I use Shimano cutters
This is another one attributable to Eddy Merckx. He always had crazy short housing. It saves weight...
Quoted: 987 Post(s)
Liked 641 Times
Actually there is an ideal for this, or there was. Make the rear brake housing as short as possible, with the possibility that the bars are able to rotate fully in both directions until they touch the top tube, without stretching or straining the housing. IOW make the housing as short as you can while still being able to full turn the bars in both directions. Then make the front brake match the rear in height. In practice usually I did the above but added an inch or so, as did most people.
Quoted: 1829 Post(s)
Liked 3,376 Times
Likes For Salamandrine:
Quoted: 987 Post(s)
Liked 641 Times
In that catalog photo, the cables rise above the bars about 1x the amount of drop in the bars; on my bike, I'm at about 1.5x; some shortening might be in order even if I'm not experiencing any issues while riding.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Kits are fine, but you pay more per bike. I like buying housing by the foot from Asian sources, and then die drawn stainless inner cables in bulk, same with ferrules and such.
Quoted: 987 Post(s)
Liked 641 Times
After a few rides, impressed on how little cable stretch I experienced. BITD, I recall needing to readjust brake and derailleur cables after only one ride. Indeed, working in shops, part of assembling a new bike was really leaning on the brake levers trying to pre-stretch.
Brilliant idea, and the Dremel was within reach the entire time.
100% certain you are right about the cost.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Bikes: 2013 Litespeed M1; 1990 Razesa w/ Campag Components; 2011 Trek 1.5 (sold); 1975 Astra Tour de France (sold)
I had a Jagwire sport (LEX-SL) rear shifter cable fray on my vintage Razesa. Hard to see in the photo, but it's in the middle of the bend. I didn't think the bend was too tight (see bottom photo), but the brazed cable guide location makes it a difficult run.
The step down ferrules were once ubiquitous. You really do need to get a baggie of them to work on vintage bikes. SIS housing should not be used without ferrules. I always use ferrules even with traditional housing. SIS housing will work just fine with friction shift derailleurs. The stresses on the housing don't change because of the click.
FWIW, VO has or at least used to have the plain stainless coiled housing that was traditionally used for the RD.
My Masi has 40 year old cables and unlined housing, and it works fine. Without all the extra bends, cables didn't tend to fray. If they aren't frayed, I see no reason to replace. I prefer the feel of the original thick campy brake cables. While this bike is in semi retirement, I wouldn't hesitate to ride with the old cables.
