#4227
Wow another application for Kapton tape.. that i never thought about, plus if your bike ever catches on fire.. the tape will be fine.. unless it gets over 400 degress F.
I used to work in Electronics Manufacturing and used that stuff all of the time.
#4229
I was surprised by the heft of the Nitto stem the I saw it had a steel jam bolt. Dug up an aluminum one at the LBS to use. Will have to drill and tap to the slightly larger bolt. Something to do during the snowstorm tomorrow.
#4230
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
#4231
I don't have a gram counter but holding the two in opposite hands ready gets the feeling of weight difference.
I no weight wee i.e. At all! Just geeking on things and finding ways to entertain myself.
#4233
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I measured a 21g difference between the stock steel (cast iron?) wedge on an 80's SR stem, and the aluminum one on a newer Nitto stem.
#4234
Next up is the screw in brake cable end on the brake lever. The cables are held tight by a indent which makes cable housing replacement impossible. Have to get out the drill and open the hole back up after finally yanking the old housing out.
#4235
Done.
Next is to solve the problem of the missing rear brake cable adjuster. Snuck into the shed and robbed the white winter Trek of its complete 600 brake set. That way I get the end caps for the housing as well.
#4236
Nice @3speedslow . Looking good, Keep it going.
#4237
Quoted: 628 Post(s)
Liked 316 Times
Love it 3speedslow . I nominate 3speedslow as our resident weight weenie . Being a weight weenie is not to be taken lightly (pun intended) it is laborious and expensive task it could turn out to be your n+1 . To start you on your path of destruction , please check out this site . And God help you . Titanium Bolts, Titanium Fastener, Bike Parts Toronto, Bike Bolts
#4238
Things are still moving.
The BB on there was Tange and in great shape. The spindle was the wrong size, 119 not the correct 116. In my bins was an equally great Tange BB correct size so old one Off and new one on. Much better chainring distance to the stay.
#4239
A better 600 crankset has been mounted while I clean the paint from the original. Pedals will be Shimano SPD. I have several sets of 600 pedals but can't use them.
#4240
Levers and housing set and taped to the bars. Cabling and wrap tomorrow.
Correct width rim tape laid down and wheels shod. Specialized trisport 700X23.
#4241
Calipers mounted and even got 2 of the little black rubber pieces for the bolt hole on the 600 brakes. Those came gratis from my friendly LBS.
Must go find a chain for this bike. Then the winter test ride can begin.
#4243
All cabled, greased, wrapped and adjusted. Used a few items like cable, handle bar tape for this temp build.
#4246
I do not have the star wrench set for HS adjusting but my LBS does so Monday I roll in and properly adjust it. As for now, a short ride around the block confirms it fits me nicely and really handles awesome!
Knee willing, longer ride tomorrow.
#4248
Texaspandj,
Do you have a "Smoke On The Water" yet?
If not... how about this? ... https://dallas.craigslist.org/dal/bi...462037001.html
JD, Dallas
JD, Dallas
I had a "smoke on the water " that is now owned by BF member jamesdak.
#4249
Rode the 86 into the LBS and used the star wrenches to tighten the HS proper. Went on down the road and promptly went under water from the rainstorm.
I will try again tomorrow.
