ISO and for trade thread part 5
#5251
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
I did just measure the one I have here and it's 3.7mm for most of it, but widens to 4.7 at the top, and only the lower part fits into the levers I've got (the ones on the bikes are cabled up & hooded, so I can't compare....). I wonder if it's supposed to drop all the way into the lever?
#5252
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1086 Post(s)
Liked 1,822 Times
Got hit from behind by a car last night, damaging my rear wheel to the point it'll likely need to be replaced.
Does anyone have an 8-speed wheelset, using Campy Chorus/Record hubs with Exa-Drive cassette body? Hopefully 36h, but 32h would also work.
Failing that, a long shot, but how about just a rim? 32h Campagnolo Omega 19, silver anodized. Clincher.
Thanks!
DD
Thanks!
DD
#5253
Quoted: 2588 Post(s)
Liked 4,824 Times
Nope, not compatible. The set you shared is a tubular set, with a rear hub threaded for a freewheel. My request clearly stated I was searching for a clincher rear or set, with a cassette application. There were numerous follow-up posts with photos approximating what I was looking for. Anyway, my LBS has been on the case, as was noted in a later post, so no worries.
dd
dd
Likes For Drillium Dude:
#5254
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
6s freewheel
My freewheel x-ploded
looking for a 6s replacement.
got a message out for a couple for sale in the C&V sales section
#5257
Quoted: 2364 Post(s)
Liked 1,751 Times
^^^^^^ Index? Friction? Brand preference?
#5258
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by madpogue;[url=tel:22678243
22678243[/url]]^^^^^^ Index? Friction? Brand preference?
no brand preference. I see some really cheap stuff on Amazon. And interloc must be good- it’s expensive. So I’m fishing here for something functional until I build up a QR wheel.
#5259
Liked 1,751 Times
^^^^ PM incoming.....
#5260
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 437 Times
currently 6s indexed. I cleaned out the shifters after i got the bike. Started working. Never opposed to friction.
Likes For VintageSteelEU:
Likes For mrv:
#5262
Quoted: 215 Post(s)
Liked 437 Times
I've got in total 5 wheel sets (3 on bicycles at the moment, 2 with freewheels, 1 with a casette), all of them use track nuts. Just my personal preference. I specially looked for hub versions with threaded axle and nut and converted some as well. On the bright side, never had any other freewheel explode on me. I use Suntour (New Winner) on the Sunday rider, Shimano (casette) on my commuting bike and Shimano (freewheel) on the guest / spare bike.
Good luck with the freewheel. From the posts above, it looks like someone has already contacted you
#5263
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
I had a similar situation (exploding freewheel). I don't remember the make, but it was a generic one and I've put it on the wheel maybe 15 minutes before. Completely new. I was waiting on the crossroads to take a turn and then one of the sprockets shattered when I pressed harder on the pedals. Just like that. Very unpleasant, especially that I was pressing on the pedals harder to make it before the approaching car. Luckily at this point I was about 5-10 minutes walk away from home. I tend to have some tools with me, but usually not a spare freehub.
To get the internal shell off the hub, I ended up using my vice.... after the square bits that the removal tool sits in broke off.... Good Times!
-- needed a pic for my abbreviated strava post....
#5264
Quoted: 215 Post(s)
Liked 437 Times
This is the second freewheel I've had just kind of fall apart. The bearings start falling out, then the shell holding the sprockets comes off the internal shell holding the pawls. Then all the sprockets slide out board, and if you're not careful the chain drops behind the sprocket hub.....
#5265
Bianchi Goddess
Quoted: 2936 Post(s)
Liked 2,933 Times
That’s why I like self extractors, an extra Allen wrench isn’t that heavy and beats walking home.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
#5266
*____*
ISO:
118 Stronglight spindle
M951 V-Brakes
I have cash or I have a decent buildup in my parts bin to trade - some good JIS spindles in ~115mm, a cool pewter finish 94bcd 42T chainring that doesn't play well with my cranks, a couple of decently shiny deore FDs, a brand new brooks C15, set of Tektro CR720 brakeset, Nitto UI-12 100mm, VO Crazy Bars (removed ~8mm from each end)
M951 V-Brakes
#5268
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
ISO:
M951 V-Brakes
M951 V-Brakes
UPDATE: I found something, will send you a PM with the details
#5269
Quoted: 787 Post(s)
Liked 521 Times
#5271
Liked 1,064 Times
as follow-up to this ISO posting:
Originally Posted by GullyFoylesbike View Post
ISO:
M951 V-Brakes
What I found was a pair of XTR V-brakes but they are model M950, not M951, so GullyFoylesbike has declined them.
If somebody else is look for a pair, they are available: PM me
ISO:
M951 V-Brakes
#5272
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,490 Times
Likes For SurferRosa:
#5273
Quoted: 566 Post(s)
Liked 1,053 Times
ISO:
M951 V-Brakes
ISO:
M951 V-Brakes
#5274
buy my bikes
Quoted: 519 Post(s)
Liked 429 Times
as far as a lock ring goes - it's a freewheel.... so i dunno... I mean - when you say lock ring, I think cassette. I'm not saying there's not a ring to disassemble / service the bearings in the freewheel. I never had the freewheel apart for this bike. I picked it up used over the summer. The other freewheels I've used, I've only hosed them out with a solvent or WD40, allowed them to sit overnight, then lubricate with some kind of heavy gear oil.Usually let it sit over night flat on the work bench.
But this is the second time in about 20 years I've had a freewheel disassemble and drop ball bearings all over the road. When I upgrade the wheelset I'll be going to a cassette/freehub deal, for sure.
#5275
señor miembro
Liked 6,490 Times
It's normally really easy to overhaul a freewheel: a much better way to clean one out and install fresh and thick grease. Just use a hammer and punch on the lock ring, which is usually left-hand thread.
