Nishiki Serial Number Database
#1977
Quoted: 4722 Post(s)
Liked 3,039 Times
A Giant manufactured Nishiki would have a date code or serial number starting with a 'G'. Norco was designer and distributor for the Canadian market Nishiki, which would typically have a Giant or Kawamura or Kawamura serial number. The Kawamura built Nishiki for the Canadian market typically had a serial number starting with 'C'. Yamaguchi had a serial number format starting with a 'Y' but the 2nd character was numeric.
#1980
YF87088827 is stamped below the bottom bracket.
i’ve emailed yamaguchi bikes regarding this.
they said serial number is not theirs.
btw, i’m from singapore.
#1981
My bikes became Vintage
#1982
#1983
Liked 3,039 Times
#1985
Quoted: 5 Post(s)
Old Thread, NEW post / question
I believe my Nishiki is a 1971 based on known history and the serial number (Extremely difficult to read). SN is K-71-00190, on bottom bracket, near as I can decipher - it's hard to read between the "K" and the "71". I see no stamps between those two markings. I'm seeking to confirm model, build date/origin. It has the Molybdenum/Chrome frame with Suntour comps - basically. Red paint with bar-end shifters. Serial # doesn't seem to jive with previous posts data or downright lack of info. Previous posts seem to indicate 2nd part of SN is a letter referring to Month of mfr. Mine has no such letter; My SN is K-71-00190. Any insight or info would be appreciated. This is a special bike to me - a gift I received from my brother in the late 70's, that he purchased used(a couple of years old)
in about 1975. Any info would be greatly appreciated by me, and, based upon the lack of info I've found, may be of interest to others as well. I can provide pictures if anyone is interested.
#1986
Liked 3,039 Times
I believe my Nishiki is a 1971 based on known history and the serial number (Extremely difficult to read). SN is K-71-00190, on bottom bracket, near as I can decipher - it's hard to read between the "K" and the "71". I see no stamps between those two markings. I'm seeking to confirm model, build date/origin. It has the Molybdenum/Chrome frame with Suntour comps - basically. Red paint with bar-end shifters. Serial # doesn't seem to jive with previous posts data or downright lack of info. Previous posts seem to indicate 2nd part of SN is a letter referring to Month of mfr. Mine has no such letter; My SN is K-71-00190. Any insight or info would be appreciated. This is a special bike to me - a gift I received from my brother in the late 70's, that he purchased used(a couple of years old) in about 1975. Any info would be greatly appreciated by me, and, based upon the lack of info I've found, may be of interest to others as well. I can provide pictures if anyone is interested.
#1989
Quoted: 5 Post(s)
Welcome to the forums. We know it's not a 1971 model because Nishiki did not exist as a brand until the 1972 model year. I suspect the serial number has a couple of missing characters between the "K" and '7'. Based on the CrMo tubing, colour and bar end shifters, the leading candidate would be a Nishiki Competition but photos would be required for confirmation.
#1990
Liked 3,039 Times
I've tried 2 responses with photos which have been rejected, one due to the fact I've not posted at least 10 times, and the other due to "too many characters" (over 40,000). ??? The photos I'm prevented from posting here show everything. Frustrating. Any suggestions? Admin? Shall I just submit 8 more random worthless posts to meet the 10-post threshold? Kinda stupid, but I'll do it.
I was able to retrieve your photos and what you have is the top of the line Nishiki Professional with some apparent modifications. The tubular wheelset has been rebuilt as wired-on, which was fairly common. Also, the brakes would typically be centre-pull, as opposed to side-pull, and the saddle would not be a leather version.
The first three characters of the serial number appear to be K7E. The year and month indicators are reversed from the format used by Katakua, who typically built the Professional. However, even if we assume this is just a factory error, it would indicate May 1977 and the bicycle appears slightly older. I suspect this was actually built by a sub-contractor who used the Imperial Japanese Calendar and that the frame manufacture date is May 1972. This could be corroborated by examining the back of the crankarms for date codes. I suspect you are going to find 46-x(x) or 47-x codes, where x indicates the month and 46 & 47 are Showa dynasty years corresponding to 1971 and 1972. Please report what you find.
Likes For T-Mar:
#1991
Quoted: 5 Post(s)
Modifications noted, and I'm aware of all with the exception of the saddle. My brother did the rest, for my sake - it originally had sew-up tires swapped out for high-pressure clinchers (as my brother termed). I'm curious as to what the original saddle was. I attempted to post photo of the crank, but not sure if it went through. Crank stamping is "46.11", so is that a November '71 - sold as a '72 model?. All original as far as I know except for the brakes (formerly center-pull - I knew that - ) and the saddle, which I was unaware of prior to you mentioning it. Hope this goes through so I can get some feedback and more insight on this bike which is very important to me.
#1992
Liked 3,039 Times
I am still curious that the serial number format uses the Japanese Imperial Calendar and wonder if Katakura transitioned and changed their format around this time. To this end, I would appreciate if you would check the branding of the handlebars. Early Nishiki racing models manufactured by Katakura typically used Nitto handlebars that carried a Nishiki Road Silk designation. Silk was a Katakura brand, so their presence would increase confidence in it being a Katakura manufactured frame, like the slightly later Professionals. It's unfortunate that the decals have been removed, as Katakura manufactured frames also had Silk designations on some decals.
Regarding the saddle, specs were notoriously sparse during this era. It was rare to mention the brands and models of major components like the derailleurs, cranksets and brakes, let alone secondary components like a saddle. Early Nishiki racing models typically came with a narrow saddle having a plastic base covered with a layer of foam and a leather cover. I've seen both Elina and Tahei brands. Having said that, 1972 saw the biggest sales jump in 10 speed sales, with demand outstripping supply. Consequently, substitutions due to shortages were not unknown, though the Japanese seemed to suffer least in this area. If the current saddle is a Japanese brand,then there is the possibility of a factory substitute but if it is not Japanese, then it is almost certainly a post factory replacement.
#1993
Quoted: 5 Post(s)
Thxs, the crankarm code helps. The crankarm itself was manufactured November 1971, which would be appropriate for a 1972 model year bicycle. It also increases confidence in the frame manufacturing date being May 1972. Japanese manufacturers typically started building the new models around September. This allowed them to build up stock and allocated time for trans-oceanic shipping, customs clearance and channeling through the USA distribution system, yet still have the first shipments in shops for the lucrative Christmas season.
#1994
Liked 3,039 Times
Thxs. It's interesting that bars are SR. At the time, the Japanese component companies were divided into two rival trade associations, JEX and JBM. SR was part of JBM, while the SunTour derailleurs, Sugino crankset and original Dia-Compe centre-pull brakes were part of the JEX group. It was very rare to mix parts from competing trade associations, so I wonder if the bars (and stem) may also have been changed? SR bars typically have a date stamped at the end, but you'd have to remove the tape. However, if the stem is also SR, you could check its date code, which is typically stamped just below the insertion mark. The bars and stem may have been changed by the original owner, to achieve a better fit.
Regarding the saddle, the presence of a Brooks almost certainly indicates a post factory replacement. The original owner probably rode a Brooks Professional saddle prior to the Nishiki and changed it as personal preference.
#1995
Quoted: 5 Post(s)
#1996
Quoted: 213 Post(s)
Liked 1,509 Times
Nishiki International
My current project is an early 80's Nishiki International in the dark blue
with outlined lugs. I measured the seat tube C-T at 58cm
& 58cm for the top tube as well.
I have been perusing thread trying to narrow down exactly what year.
It appears to look like this one that the owner labels as a 1983.
https://www.pedalroom.com/bike/1983-...nal-build-5184
My parts match up with his.
I added 10 pics as perhaps that will aid and document for someone down the road.
The serial number on the bottom of the bottom bracket is GE 03135.
If I am interpreting the SN decode info
correctly the G is for Giant built.
If the E is for year that would signify 1985.
The online 1983 catalog page does not sync up
to this one.
Of course I understand there were many made for different markets
and could be spec'd differently so that could explain the variance.
The Suntour Symmetric shifters could be a significant telling detail.
and both derailers are Suntour Cyclone MII.
Crankset is Sugino GS with 42x52 drilled rings and 170mm crank arms.
The Dia Compe G N500 calipers have 0385M stamped on them
and the Sakae Custom Road Champion bar has C-85 stamped it.
The Sakae Custom stem has 80 & 5355 stamped on it.
It came with 27" Araya rims, Sansun hubs, Suntour Perfect 6 cog freewheel 14x28.
By the way it did not come with seatpost and saddle.
I used some from my parts bin.
Datapoint , seatpost is a 26.6.
Thanks for input on narrowing down year.
Another note, a 40mm wide 700c tire fits this machine front and rear.
I look forward to the rebuild and getting it out on the road.
to this one.
#1997
Quoted: 213 Post(s)
Liked 1,509 Times
This 1983 catalog page shows the International with a triple
crankset ,different Suntour derailers and 700c wheels and no blue color listed.
1983 Nishiki catalog | Flickr
#1998
Quoted: 1612 Post(s)
Liked 2,594 Times
Olympic 12, Giant 86? Any idea on seatpost diameter? Nishiki 4130 tubing.
#1999
Liked 3,039 Times
Try a 26.6 or 26.8mm. Tange was the primary tubing source during this era. With the exception of Prestige, Pro and #4 , all their CrMo tubesets, including plain gauge, used a 26.8mm nominal inner diameter for the seat post.end of the seat tube. Allowing for typical clearance would result in a 26.6mm post but a 26.8mm post might be a better fit if the tube was reamed.
#2000
Liked 3,039 Times
to this one.
to this one.
