Giro Shoes - WARNING!!!!
Non omnino gravis
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
This is interesting. I was looking at picture of the Trans E70 shoes on Amazon and the ratchet buckle is a bit different than what I have on mine. Although the strap looks the same. In the description, on Amazon (for what it's worth), says the buckle is an N-1 while the strap is an N-2. This is very confusing because when I do a Google search for "Giro N-1" I get a ton of hits with pics that look like the buckle I have.
https://www.amazon.com/Giro-Trans-Ro...00NDJPSO8?th=1
I guess Giro changed something along the way.
Who knows? It's time for laces
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
So it is
Quoted: 11442 Post(s)
Liked 4,809 Times
Bad example
Quoted: 853 Post(s)
Liked 282 Times
I am still using my two pairs that are over 20 years old. Great shoes and perfect fit.
Quoted: 132 Post(s)
Liked 39 Times
Having said that, someday, when I have lots of $$$ I'd like to try some higher end Sidi's.
Quoted: 18883 Post(s)
Liked 10,646 Times
I like the concept behind the boa but always found the knob looks weird. Like a mushroom shaped tumor growing out of your shoe/foot.
I've been eyeing the Giro Empire ACC's. I like the laces. They look cool/retro and if you ever have to replace them finding a set of shoe laces shouldn't be a very daunting task. Sure they're not as fast or as adjustable on the fly as boas, buckles, and velcro, but, personally, I never have to adjust my shoes on the fly, nor am I ever really in that much of a hurry to get my shoes on or off.
Liked 406 Times
I don't like laces on any kind of shoe, which is a bummer because they're the obvious best solution. You can make part of the shoe tighter and part looser to fit perfectly. And like you said, they're cheap and ubiquitous. And yet part of the reason I chose the ski boots and walking shoes I have is no laces.
Specifically:
https://www.fieggen.com/shoelace/ianknot.htm
Quoted: 18423 Post(s)
Liked 4,540 Times
Liked 406 Times
You dodge official retail channels to save a buck...this is what you get. Just about all manufacturers everywhere say to seek RMA through your retailer.
Quoted: 138 Post(s)
Liked 16 Times
Google says others have struggles with stuck buckles on Giros -- and on Sidis.
Someone offered this solution: "Like a Chinese Finger Trap, the trick is to actually push it in farther first. Then you should be able to depress the release lever normally."
I've had stubborn buckles on Shimanos. I didn't think to apply a screwdriver or knife or pliers. After working with them some, maybe pushing the strap in farther and then pushing on the buckle release, they let loose, and I'm still using those shoes years later.
Quoted: 132 Post(s)
Liked 39 Times
Liked 4,540 Times
I can get most of my shoes off of my feet without unlacing... except some boots. Perhaps those were cinched down tighter than I normally would do, but too tight, and they would be quite uncomfortable.
Those shoes appear to have a soft upper, so I'm surprised they wouldn't slip off.
Quoted: 4848 Post(s)
Liked 3,980 Times
So Giro's most expensive shoes have laces. My all-time most comfortable shoes have all been laced. The Pumas I raced 40 years ago and the Velcro'd Lakes I paid ~$90 bucks for at Performance. From the first time on the fit was like "ahhh!" but I started having real issues from the straps. (Riding serious hills every day on a fix gear.) I got tired of the doctor's visits so I bought $15 worth of laces, grommets and a tool. Spent an afternoon installing the laces. Those shoes are now super comfortable all-day shoes. Did the same to another pair of identical Lakes with different cleats. Same outcome.
Bugs me that the shoe companies reserve this very cheap fastening system for their $300 shoes. Now that I have the tool, it costs me $5 plus laces per pair.
Ben
Ben
Quoted: 42 Post(s)
I read this when the shoe was stuck on my foot. Did not work on the Giro's buyt has worked with my Sidis. I am guessing the issue was corrected at some point or this would be more prevalent on forums like this.
Non omnino gravis
Quoted: 1235 Post(s)
Liked 190 Times
It's not the buckle that's the issue. It's the strap - specifically the ratchet section of the strap extends too far. It needs to end sooner so that once maximum tightness is achieved there is still room to push the strap further in then back to kick up the release buckle on the un-geared section. The picture I posted on the first page shows the section - I believe the teeth extend further on the smaller sizes.
I hate throwing away defective products that the company refuses to warranty so I'll go pretty far to save. In this case the thing to do seems to be using a soldering iron to melt the head of the ratchet strap so that the tongue will release, then replace strap with a newer(?) model that won't have the same issue.
I've also been scorned by Giro customer service for low-use but older items outside the warranty period. I won't buy Giros and I won't buy shoes online ever again.
So it is
Liked 4,809 Times
Snip off the angled portion of the tab that's to be pressed down, so it clears the elevated part of the strap. I can't tell by that picture where it's mounted, but there are also two positions on the shoe the buckle can be installed. All this is easy to say, outside looking in, but it also helps being familiar with that shoe.
Quoted: 4717 Post(s)
Liked 1,882 Times
It's not the buckle that's the issue. It's the strap - specifically the ratchet section of the strap extends too far. It needs to end sooner so that once maximum tightness is achieved there is still room to push the strap further in then back to kick up the release buckle on the un-geared section. The picture I posted on the first page shows the section - I believe the teeth extend further on the smaller sizes..
No way would I have destroyed the shoe, Sounds like the OP panicked.
Liked 190 Times
He needs a replacement strap, the strap design changed at some point to decrease the length of the ratchet section by ~1/4". You can see it here comparing this set of shoes from mid 2015 production to the same style but 2016 production. I suspect they used the same ratchet section distance as the prior version of the interface - oversight during design refresh is a common issue but should have been addressed properly.
@sooni - do you have a year printed on the sole under the insole?
