Go Back  Bike Forums > The Racer's Forum > "The 33"-Road Bike Racing
Before you start another TT thread, click here.
Old 09-15-12, 05:35 PM
  #276
Creakyknees
ride lots be safe
Creakyknees's Avatar
Quoted: 13 Post(s)
Winning cat 1 went 1:44, winning 40+ went 1:53, I went 2:03. Was so anaerobic coming into the turn that I almost blew it badly. Was seeing spots at the finish. Still sucked.
Creakyknees is offline
Old 10-04-12, 11:40 PM
  #277
Ralsontyres
very nice post ...really is very helpful...
thanks a lot...
Ralsontyres is offline
Old 12-06-12, 05:08 AM
  #278
Carcinogent
Here is some info on pacing a TT with a powermeter from my blog.
https://www.thetallcyclist.com/2012/1...-a-powermeter/
In the future I will post some more info on variable pacing (hills, headwind, etc.)
Carcinogent is offline
Old 03-10-13, 07:16 AM
  #279
Yotsko
Yotsko's Avatar
Question regarding timing. Rode a prologue TT yesterday - didn't get a chance to check the results until I got home and then I noticed that my chip time was significantly higher than my garmin time.
Chip time was 6:39, TOTAL garmin time was 6:30 (hit start 5" prior to actual start, stop a second or so after crossing finish, and didn't have auto pause on), so I figure the chip time is at least 10" off. Is this normal?
FWIW, my power file shows that I ran about a 6:20. Assuming no one else had timing chip "issues", that would put me on top of the podium. No prize money involved and its obviously too late to challenge anyway, but now I'm curious.
Yotsko is offline
Old 03-30-13, 08:11 PM
  #280
rbart4506
You blink and it's gone.
rbart4506's Avatar
Bikes: Race bike, training bike, go fast bike and a trainer slave.
Looking for a TT specific saddle for my wife. She's currently on an ISM Adamo and having issues with numbness and sore lady bits. She's spent a good couple years using it and it's fine for shorter TTs, but for the 40km TTs it gets pretty bad. The TT bike is set up to UCI specs, since she'll be running the bike at Masters Nationals in Canada, so she's hoping to find a saddle to maximize that setup...Hence the ISM saddle. Right now the only two I can think of is the Fizik Ares and the Prologo Zero...
rbart4506 is offline
Old 04-01-13, 09:24 AM
  #281
Nate552
Nate552's Avatar
Bikes: Orbea Orca Trek 5500 Trek Equinox
Maybe the Dash saddle or the new Specialized Sitero?
https://www.dashcycles.com/
https://velonews.competitor.com/2013/...-saddle_279472
Nate552 is offline
Old 04-01-13, 11:05 AM
  #282
rbart4506
rbart4506's Avatar
Yea we saw the Sitero, but the LBS around us said that it won't be available in Canada until October.....
Old 04-11-13, 12:55 PM
  #283
johnybutts
johnybutts's Avatar
Bikes: Type of horse.
Quoted: 8 Post(s)
Are there any center-pull mechanical caliper brakes on the market?..
Also, any opinions on the 3T Aura Pro bar? thinking of an upgrade...
johnybutts is offline
Old 04-11-13, 01:08 PM
  #284
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
Liked 10 Times in 6 Posts
There are some brake options that are an improvement over a "standard" road brake. Thread with a bunch of pics and thoughts
3T makes a good product but I'm not fond of upturned bullhorns.
Racer Ex is offline
Old 04-11-13, 01:11 PM
  #285
rpeterson
You could check out the TriRig Omega. I really like mine, works just like any other brake.
rpeterson is offline
Old 04-11-13, 02:27 PM
  #286
johnybutts
johnybutts's Avatar
Quoted: 8 Post(s)
Thanks guys. Will check those out. Right now I'm leaning towards a Mistral from 3T. In my price range (used) and looks clean. Should be a significant upgrade from the profile design setup that came stock. Reading the reviews, mistral sounds like it allows a lower position than the aura.
RX: Don't like the ergonomics or aeroness?
Old 04-11-13, 05:12 PM
  #287
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
Both.
Racer Ex is offline
Old 04-19-13, 06:57 AM
  #288
Jasper Storm
Quoted: 15 Post(s)
Liked 9 Times in 7 Posts
Is there usually quite a jump from one's selection of road racing saddle to a time trial saddle?
I am building up a TT bike which is fairly aggressive (I am pretty flexible, and the TT's are 20k or less) and was wondering if riders are generally able to use their RR saddle model or if they typically need to make a drastic change.
I use a Fizik Antares on my RR bike and it fits me perfectly. I see they make the Ares, an Antares with a cut-down nose. I was considering the possibility of ordering one.
Jasper Storm is offline
Old 04-19-13, 07:25 AM
  #289
johnybutts
johnybutts's Avatar
Quoted: 8 Post(s)
That didn't work for me, but I'm sure its quite personal. I went through a number of saddles and ended up with an adamo.
Old 04-19-13, 09:01 AM
  #290
AzTallRider
I need speed
AzTallRider's Avatar
Bikes: Giant Propel, Cervelo P2
You will be on the front of the saddle more than you are on the road bike, so keep that in mind.
AzTallRider is offline
Old 04-19-13, 09:37 AM
  #291
Creatre
These Guys Eat Oreos
Creatre's Avatar
Bikes: Yes
Quoted: 13 Post(s)
This. Most of the road saddles I had to "pick a side" when on the TT bike or lose my manhood. I prefer the Adamo so I can center up pretty good, and its quite comfy.
Creatre is offline
Old 04-19-13, 11:49 AM
  #292
Jancouver
Jancouver's Avatar
Would BMC TT02 bike pictured below benefit from swapping the original BMC blade fork for Cervelo Fork? Just asking because I still have an extra fork on hand from my Cervelo years
Jancouver is offline
Old 05-07-13, 08:57 PM
  #293
Mr. Parker
Bikes: Trek 5000
So I haven't raced in a while and wasn't a forum guy back them either (04-05). I loved TT's and even built up a bastardized TT bike out of a Trek 1200 touring frame... It was a fairly tricked out bike minus the frame.
The last incarnation of the bike had longer cranks then my road bike. IIRC I have 172 or is it 172.5's on my road bike and I had read that some TT specialist would run slightly longer cranks on their TT rigs. So I ended up sticking some 175's on for more leverage as the thinking went.
Well I'm getting back into riding after a long long hiatus and once again will put a lot of focus into TT'ing.
I am not sure if I'll rebuild that same TT bike or buy a new frame but the question is, do you keep the crank length the same, longer or shorter then your road bike?
Mr. Parker is offline
Old 05-07-13, 09:19 PM
  #294
Jancouver
Jancouver's Avatar
I have different crank length on every bike. I'm a taller guy at 6'5" so I usually run 177.5. That being said, my TT rig has 180s and my crit bike 175s. Personally I do not see much difference between the 177.5 and 180s. When I look at Taylor Phinney at same height 6'5", he is running 175s. Cancellara is 6'1" and he is using 177.5. So just go and ride the frigin bike and dont worry about the crank size
... and my track bike has 170s
Old 05-07-13, 09:33 PM
  #295
Mr. Parker
Bikes: Trek 5000
Works for me. I will probably end up buying a new frame and finish cannibalizing that old TT bike. Got cranks, BB, Rings, Front Derailure, Dura Ace End shifters brakes/levers and handle bars.
Need Aero Bars, frame, rear derailure and wheels...
Had a HED Trispoke and a Disc... not anymore...
Old 06-12-13, 04:57 PM
  #296
caloso
caloso's Avatar
Quoted: 2952 Post(s)
Liked 3,106 Times in 1,417 Posts
Any thoughts on the Motobecane Nemesis as a cheapo TT frame? It's heavy, but I don't really care about that. It's ugly, ditto. But can it be made into a decent TT bike?
caloso is offline
Old 06-12-13, 05:45 PM
  #297
Racer Ex
Resident Alien
Racer Ex's Avatar
Quoted: 349 Post(s)
It's a flexy POS. I had one and had issues with FD rub and the chain coming off when I was out of the saddle. I'm 155 and it's not like I'm some track sprinter either.
Racer Ex is offline
Old 06-12-13, 05:50 PM
  #298
caloso
caloso's Avatar
Thanks. That's just the sort of thing I was wondering about.
caloso is offline
Old 06-14-13, 12:27 PM
  #299
caloso
caloso's Avatar
Still haven't gotten around to getting a TT frame. In the meantime, a couple of teammates have challenged me to do the local 10 mile TT (Putah Creek Smackdown) in Merckx style. I agreed to use my 32-spoke Open Pros, standard helmet, standard kit, hell I'll even leave on my frame pump and saddle bag. My first question is tops or drops? I am thinking of a picture I've seen of the Man himself on the tops:
I figure that having my hands on the tops near the stem, with my elbows tucked in, would be more aero than the drops. Thoughts?
caloso is offline
Old 06-14-13, 12:29 PM
  #300
johnybutts
johnybutts's Avatar
Quoted: 8 Post(s)
Is IAB not an option?
