Winter base layer
I got a merino wool mesh baselayer this morning, and wore it on a rode this afternoon.
this one: https://us-nordiclife.glopalstore.co...irt-with-inlay
I am happy to report that it works as advertised.
I use the variation with short sleeves (in combination with removable arm warmers) for commuting purposes. Long sleeves too warm for me.
Zircon Encrusted Tweezers
Quoted: 261 Post(s)
Liked 132 Times
I am thinking of getting the synthetic one too, however. It might be even better. Not sure. Price is a bit more attractive compared to the wool. Would probably be more durable too.
While I have not had a durability issue with the wool one so far, I treat it gently. Hand wash in the sink. Roll up in a towel method to get most of the water out, then air dry. When taking it on and off you'll want to be careful not to stretch it unduly. After quite a few uses at this point (probably a good 20-25 or so), I am really happy with it. It seems like it increases the comfort range of whatever I have on over top of it.
Quoted: 7350 Post(s)
Liked 2,475 Times
Yes, I notice merino provides comfort in a wider temperature range than other stuff!
Quoted: 261 Post(s)
Liked 132 Times
It's not night and day, but it IS noticeable to me. I think the mesh helps keep your skin a little drier, and if the next layer beyond the mesh gets a bit damp, it's not in direct contact with your skin, limiting the heat conduction problem of a wet baselayer. The overall problem of sweat and freeze cycle of those of us riding in mountainous terrain is lessened.
Liked 2,475 Times
Interesting points, @Steamer. Thank you. Next time I need something, I'll consider that mesh thing. And a mixture of wool and synthetic is good; it adds strength.
Bikes: Charlescen
My daughter usually wear maidenform baselayer leggings so I thaught its great if another good baselayer for her kindly suggest me
