Fair price for local store assembling bike?
SE Wis
Quoted: 2747 Post(s)
Liked 3,401 Times
Quoted: 1324 Post(s)
Liked 927 Times
At our shop we charge for a boxed bike assembly a tune up rate plus a bit for the unboxing. This year that's $65 plus $10. Of course this assumes a boxed bike state that is similar to what we would do to ship a bike or like how we get our new bikes as. We do reserve the right to re quote based on actual boxed condition (was the fork removed, are there fenders or racks to be installed too). Andy.
Cheers
Quoted: 4210 Post(s)
Liked 3,879 Times
We sold Peugeots in the late 1970s and some too came poly bagged. The cardboard made Asian stuff look like plywood but the bikes were usually pretty clean. Then there was the crape paper craze. Frames wrapped with brown crinkle paper. Andy
AndrewRStewart
AndrewRStewart
Liked 927 Times
Cheers
Quoted: 514 Post(s)
Liked 451 Times
Take the shop's price for a basic tune-up (everything adjusted, aligned, trued, and wiped down) and add about $20 for unpacking and some extra assembly.
This is definitely what the market will bear kind of thing, and it depends also on how thorough the assembly is.
If you do this, as a pro mechanic, PLEASE KEEP IT IN THE ORIGINAL BOX. Your preassembly does NOT help--it just means more to check. Mechanics have a routine on new builds and will be faster and more consistant if they can just keep to it, rather than checking to make sure nothing was done wrong.
I personally try to match actual build time to cost, since some bikes really do come together faster than others. Canyons, for example, really are more attaching a wheel, straightening the bars, and then checking over what is usually a good assembly. Bikesdirect is pretty similar to how a major brand ships its bikes to shops--needing rather significant assembly and adjustment, even if everything is mostly where it belongs in the box.
Something like an hour at the shop's labor rate is probably around average.
Quoted: 514 Post(s)
Liked 451 Times
The time it takes me to remove packaging is laughably trivial. The amount of time I spend attaching parts? Also pretty low. Believe it or not most of my time on a new bike assembly is on skilled adjustment--I am not saved any work when a bike is slapped together. It, again, reduces my efficiency because I have a consistent build procedure with new boxed bikes.
Learn to build it yourself (which is totally possible!) or leave it to a pro. I'm also totally chill with customers who make an honest attempt at self assembly and want me to check their work--this probably makes relatively little sense from a purely economic sense if your only goal is to have a functional bike for the smallest amount of money and time, but totally makes sense for customers who have the longterm goal of being better home mechanics. I'm only moaning about slapped together bikes. Also, all I'd ever directly say to a customer is a request to please just give me the boxed bike next time, because by the time it gets to you, what're else can you do?
Likes For cpach:
borgey007
General Cycling Discussion
76
12-23-17 05:23 AM
Flounce
148
05-29-17 03:40 PM
