Addiction LXXIX
#7101
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12778 Post(s)
Liked 7,695 Times
#7102
VFL For Life
Bikes: Velo Volmobile
Quoted: 28621 Post(s)
Liked 1,858 Times
Likes For Velo Vol:
#7103
Quoted: 20810 Post(s)
Liked 9,456 Times
#7104
Bikes: everywhere
Liked 7,695 Times
Likes For LesterOfPuppets:
#7105
Liked 9,456 Times
Nice, easy ride today. On the way home, I got to pick up our new team kit, which was delayed quite a bit because of the ol' covid. Lookin' sharp.
#7106
Bikes: everywhere
Liked 7,695 Times
That has been granting us the unique opportunity to see every single WV game so far this year on OTA TV however.
#7107
Silver Comet Fred
Bikes: 1
Quoted: 8843 Post(s)
Liked 2,989 Times
#7108
Bikes: everywhere
Liked 7,695 Times
Originally Posted by Lest
[QUOTE=WhyFi;21714837
#7109
Quoted: 10238 Post(s)
Liked 5,185 Times
Did I just buy the wrong chain? I put this on, but now it sounds like my chain is rubbing agains something when I pedal and I have verified that it is not.
I sized it following park tool using the largest chain ring and largest cog but somehow screwed that up to so now it’s too short.
#7110
Liked 5,185 Times
#7111
Klaatu..Verata..Necktie?
Quoted: 10435 Post(s)
Liked 11,912 Times
#7112
Liked 5,185 Times
I read somewhere that chains these days are sometimes asymmetrical. Not as severely as the SRAM flat-top chains for their 12speed groups, but with cutouts on one side but not the other. The recommendation is to see if there's stamping on one side but not the other, and the stamping should be visible from the drive side. I have NO idea whether yours is like that, because I use KMC chains.
I didn’t know if the noise was due to the chain being cut to small or if the chain was too narrow or something else. I can shift large chain ring large sprocket but the derailer is stretched out to far.
Question number two, can I add a link back to this chain?
#7113
Bikes: everywhere
Liked 7,695 Times
Then make sure it's facing the right way.
#7114
Liked 5,185 Times
#7115
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
Just back from a neighborhood walk with mrs datlas. We were walking side-by-side, and after several minutes she said the she had been matching my pace but it was too fast.
I think I half-wheeled her, but I don't know what you call half-wheeling on a walk. Maybe an expert walker knows?
#7116
Liked 8,927 Times
I would suggest pics before you do something drastic. I have mis-fed the chain through the RD cage so that the chain goes outside the cage for a small section, and it makes a very loud noise. That's the prime suspect. A chain that is "too short" would be typically be fine in small chainring up front so I am not thinking that's it.
#7117
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
#7118
Liked 5,185 Times
So this is the first issue, I am hoping that If I reroute it then everything will be fine. But this chain has a master link and I do not have the tool or pliers to open it.
#7119
Liked 8,927 Times
I have not used the newer Shimano master links, but most of them you can compress by hand and open them. Or use a needle nose pliers if need be. Give it a try?
#7120
Tonight, however, it was past sunset and they were still buzzing around. Some of them kept landing in a five-foot radius of the nest, walking around. Not behavior I recall from seeing nests in the past.
There was a dead leaf (#Autumn) partially covering the hole. I wonder if I blew it there the first time I passed the nest, and that disrupted normal activities? #NatureAnalysis
Although, once, at a cross country camp I ran for high school runners in the mountains of WV, there was a big yellow jacket nest right next to one of two main trails that we used on daily runs. First day of camp, we were getting lit up. That night, all the coaches pile in a van and drive down a dirt road to use the headlights to illuminate the trail for immolation of the nest. Another coach, he a professional fire fighter, and I move in, pour white gas down the nest hole and ignite the fuel. We forgot to clear leaves and deadfall away from the nest area and we started a wee bit of a forest fire that we were able to douse after about 10 minutes of frantic kicking of dirt and clearing debris. I am sure we looked like the biggest idiots ever during the panic and we still laugh heartily about that night, 15 years after the incident.
#7121
Bikes: everywhere
Liked 7,695 Times
Or you could remove the bottom RD pulley and squeeze the chain around the tab, then reassemble.
#7122
#7123
Liked 9,456 Times
Likes For WhyFi:
#7124
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Not when the crops are out and it's 25ºF with a 20 mph wind blowing across that flat as a board prairie. That's when you have to pick your routes very, very carefully..
Today wasn't too bad with the 15-18 mph SW wind. At least it was a pleasant 70-80º.
Keep the chain tight!
Likes For Trsnrtr:
#7125
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
... and this is why I inspect tires after every ride. It also likely would have kilt a GP5K. Fortunately, this was the semi-squared rear, so I put a new one on the front and rotated.
