Carbon drive or Chain?
Bikes: 2002 Dahon Boardwalk 1, 2003 Sun EZ-Sport Limited, 2011 TerraTrike Path 8, 2018 Gazelle Arroyo C8 HMB
And the belt drives haven't dominated the motorcycle market - still a ton of chains and shafts.
Bikes: something
From being a mechanic: Belt drives seem to be just fine. All tensioning issues aside (Which manufacturers have very elegant solutions to) I would gladly recommend them. Just make sure that the store you purchase from (Or your LBS atleast) is comfortable with working on them and that they are willing to order / stock parts for you.
All in all I would recommend them for basic commuting. Personally I am never gonna do one because I just like my 2X10 drivetrain too much, but if I was going to invest is a real "set and forget" bike, that is what I would choose. Dealing with chain and cassette wear is one of my biggest monetary expenses on my bike (And I need to be sure I catch the chain wear before I eat the cassette). Just go with a belt from a reputable source (Like a Trek SoHo or something).
My overall recommendation is that if you go with a belt drive, don't cheap out on the purchase. Get something from a reputable brand and save yourself the un-godly headaches that a crappily designed bike induces.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
That looks like an awesome bike. I look forward to seeing the pics, and hearing your impressions.
Bikes: 88 Schwin Voyageur, 84 Schwinn World Sport, 85 Univega Alpina Uno, 85 Fuji Espree, 09 Novara Strada, 06 Jamis Durango, 03 Specialized Expediton Sport, 09 Surly LHT, 12 Novara Gotham
My centertrack Gates belt and IGH just goes and goes and goes.......in any weather.
I was already excited when I put in the order but now that one response just has me more excited. I should have it by Saturday if my LBS get's it from Spot by Wednesday. They are doing a few other things to the build but it's gonna be a simple commuter but with a porteur style rack in front instead of a rear rack.
I have the Novara Gotham with NuVinci n360 hub. So quiet and smooth...........
Bikes: '09 Gary Fisher "Kaitai, '09 Raleigh Team", '91 Trek 8700, '97 Cannondale SR500, '12 Raleigh Twin Six
love my belt drive. Center track, alfine 8, jtech combo. It was a little more expensive to run a belt drive, but worth it. Quiet, smooth and nearly maintenance free. Even with the center track there was a learning curve to setting belt tension, but once you get it figured out, its a set it and forget it system. I had my LBS owner give me a lesson on removing the rear wheel before I put a lot of miles on it and it really is not as bad as others make it out to be. After a couple tyre swaps I had it down almost as fast as a qr and derailleur. I've not noticed excessive wear on the front cog wheel, but dry and dusty conditions combined with too much tension early on did a pretty good number on the anodizing. The rear cog is stainless so no issues there. The ride is so smooth and quiet that I really need incentive to get on my well maintained road bike. A quick shot with the hose is the only "maintainence" I've had to do really. I have a more detailed review in the CX forum.
Gates now has a free Iphone app to set your belt tension with. You pluck the belt and it listens to the harmonic to tell you what your tension is. Nice touch!
Motorcycle belts are wider.. motor has more power .. apples and pomegranates.
They also apply dozens, perhaps hundreds, of times the amount of torque through the belt to move a machine that weighs 30 times as much or more than a bicycle. Of course a motorcycle's belt will be wider!
Actually, I'm not so sure the instantaneous torque outputs (the output on the highest torque point of the downstroke (or power stroke on a motorcycle engine)) are *THAT* different. And that's what would determine when things break. Gearing comes into play here, though.
Perhaps torque wasn't the appropriate term to use. Horsepower would be more appropriate. The amount of work being done through the belt in a motorcycle is MUCH higher than a bicycle. I don't know how many horsepower a human can generate (probably less than one), but even a very modest motorcycle will make around 40 horsepower. Many belt driven motorcycles are 100+ horsepower.
Quoted: 19 Post(s)
Liked 7 Times
For belt tensioning, a sliding vertical dropout seems to be the no 1 choice.
You can get an iphone app to measure the belt tension from the frequency of pinging the belt.
The centre track rear cogs are now stainless steel rather than aluminium which is good since the 3-tab fitting was designed for steel. There have been a few cases of aluminium tabs snapping because they were overloaded.
2 of the "round the world" speed records have been set with belt drive bikes.
But, how fast is the belt spinning?
What stresses the belt isn't (usually) speed, it's torque applied (and, increasing speed reduces torque applied for the same power). You use gearing to multiply that torque (trade RPM for torque at the same horsepower) or divide it (trade torque for RPM at the same horsepower).
When the engine's useful power range is from 1000ish to several thousand RPM, not from 80 to 120 RPM...
Bikes: 2012 Motobecane (BikesDirect) Immortal Force; 2011 (?) Civia Bryant Gates Carbon Belt Drive (upgraded to Alfine 11 and Gates CenterTrack)
I must be the only person who can't get reliable readings from the iPhone app. If I try several times in a row, I get readings from 20hz to 120hz.
On the other hand, the mechanic at the shop where I bought the bike told me to tigghten the belt until I heard a clicking or clunking noise from the IGH (Alfine 8), and then back it off until the noise stopped.
The bike (a Civia Bryant) has sliding horizontal dropouts, with a tension adjsuting screw, so that was a piece of cake.
I have only had the bike out for a couple of reltively short rides, and that seems fine. The bike is so quiet that loudest noise (I ride at night) is usually from my clothes. That's eerie.
Still wish I could get reprocible readings from the app.
Mike
Mike
DancesWithSUVs
Quoted: 7 Post(s)
Current Harley belts are 1",I think the older ones were 1.5". Think BMW also uses 1".
Just being pedantic.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
I agree that removing and replacing the wheel itself does not in and of itself pose any significant difficulties and is actually quite easy to do after the first couple of times. However, the re-tensioning remains a PITA after putting the wheel back. I think part of the reason is that the belt does wear a tiny bit between every flat-fix, which moves the tension sweetspot just a smidge higher (in terms of the frequency obtained with Gate's iphone app) every time I go through this. Instead, it would be nice just to be able to rely on a predetermined tension frequency that works forever (which I know is unrealistic since there is no such part that will not ever incur any wear). The other thing that seems to affect proper tensioning is the wear on the rear cog, which on my bike, is aluminum and seems to wear a lot quicker than the steel ones Gates is shipping with centertrack now. So that's another thing you have to compensate for during tensioning, but this shouldn't be so much of an issue with centertrack.
Mike
Mike
Anyone want to go count belt final drive, used on the FIM GP circuits, and Isle of Man TT Races ?
Dear Pedantic,
NB: BMW M/C have drive shafts not belts .. cam shaft is gear driven .. Owned one.
Dear Pedantic,
DancesWithSUVs
Quoted: 7 Post(s)
^^^Apples to oranges. Racing bikes change their gearing for each track,and the fat 180+ rear tires are hard to get a belt around. I've had belt drives on my motorcycles for the past 18yrs,I wouldn't want to go back to a chain.
When you about your builder are you talking about someone who builds custom frames for Gates drive bikes?
Mike
