Today I (v2):
Quoted: 16 Post(s)
Today I'm at the Laundromat where a dude has brought his laptop (no big deal here) and ****ING speakers. HE IS MIXING ****TY BEATS. Why use headphones when you make everyone else listen to your ****ty beats?
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Wants to drop that hot mix to speed up drying his clothes. Amirite?
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
today i played bikes in the woods after sleeping in too late and decided the issi pedal is dead. back to the aliums.
Today I put the Cygolite on the lawnmower nd finished the lawn in the dark. Now I have time to ride tomorrow.
Ride Safe,
Joe
Ride Safe,
Joe
Quoted: 943 Post(s)
Liked 20 Times
Today I smoked myself doing lunch delivery during a home college football game. I am sitting here like a zombie. Could go to sleep right now. Must stay awake.
Something is creaking on my Dean, and I can't figure it out. It happens both in and out of the saddle, so it can't be that. Chainring bolts are tight, and I've taken the cranks out and greased everything, along with the cups and greased those threads also. Also took apart the headset to regrease and make sure everything is tight. Also checked that my cleats are tight on my shoe, and lubed the chain, but the creaking is still there, every time the DS arm goes past 4'o clock.
I can't handle this. I have a threaded bb, there shouldn't be creaks.
Fixed Gear Randonneur
A cult within a cult
Brown Jersey Winner
Quoted: 243 Post(s)
Liked 13 Times
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times
Today I rode to the beach to participate in my first polar bear swim.. It was so rad!
Gold chains on everything
Bikes: Heavy Pedal Zephyr, '16 Mash Work, '14 Cinelli Parallax, C-Dale Synapse Disc
Quoted: 17 Post(s)
Bikes: Cannondale CAAD12, Specialized Rockhopper, Norco Fluid FS1
Quoted: 127 Post(s)
I actually did change the pedals, and the noise was still there.
I greased and oiled my rear skewer and clamped down a little harder and it seems to have quieted most of the noise down, but not all the way. I need to do the same for the front, hope that takes care of it.
Today I test rode a TCX, found a geocache, worked on some kit designs, and got my hair did.
do y'all think the brake bridge was brazed in crooked or crooked cuz of warpage/abuse?
granted my rear wheel isnt centered here , but doesnt the right side of the bridge appear to be mounted above the left?
canis lupus familiaris
Bikes: En plus one
^^^ You could take some measurements to check the symmetry of the frame. Use a string or a straight edge to see if the seat stays are straight or if curved then ensure they are symmetrical.
Measure from each base of the bridge to its corresponding fork end (dropout).
Also (and maybe do this first) check the rear fork ends to make sure they are aligned. This is easy to do using a a couple of pieces of all thread attached to each side, they should point at each other in the middle.
=[[[[ unfortunately ive measured everything with said methods and cant obtain an accuracy greater than 1/16" when using a string. knowing my luck thats precisely how much its off. trying to avoid the hassle of mounting it on granite surface plate and using a height gauge. was hoping it was the result of age or sumn; with the benefit of not having to worry bout it.
damnit.
thanks rex.
damnit.
thanks rex.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
Brake bridges don't move without breaking the weld/braze where they attach to the stays. I see no evidence of this in your picture. It's likely that it just installed slightly crooked; it's easy to happen in a production environment, and only a cosmetic issue, not structural. If you really need to know, measure along the seat stay from the top of the dropout slot to the base of the bridge on each side.
Quoted: 127 Post(s)
Laced my wheels today, taking them to get tensioned and trued tomorrow along with my headset installed for project bike.
Bikes: En plus one
Quoted: 16 Post(s)
Someone was giving out nugs of weed as a hand up for todays cx race, it was also the muddiest race of the year. Gonna be bummed next week when it's all over.
