Folders in the wild - post your photos
#726
It is really a interesting bike, and not like the Birdy, you can easily find compatible parts from the market to upgrade your Jetstream.
The retails price is also much more reasonable.
Perhaps you can contact DAHON if you are inerested, I am sure their is a way to get one. :-)
#727
Quoted: 232 Post(s)
Liked 146 Times
Can you review the Jetsteam a bit?
How does it ride on trails and roads?
Can it handle larger stony terrain?
Is suspension losses a problem when riding fast on roads? and can the suspension be locked out (and how easy is that?)?
What about luggage carrying capability/options?
#728
The front "TopGun" fork cannot be locked. ( I am seeking a "German A-Kilo" fork, which has a lockable air suspention, to replace it)
The rear supension of my Jetstream is alrealy upgraded, so you can tune it to be firmer or softer easily.
For trail use, normally I put on wider tires to get more grip. Schwalbe Black Jack is a good choice. Obviously, the Kojak tires are more for roads.
The only issue is the weight. I am already using some lightweighted parts but it weighs still 11.5 kg now.
I would like to get more carbon and titanium parts to hit 10 kg, but only when I have the budget... :-)
I am not considering to put any rack on it, because for long distance touring I prefer a hard tail and lighter bike.
#729
Quoted: 232 Post(s)
Liked 146 Times
Hi there, in general, it can work pretty well on both trails and roads, but better with some modifications.
Thanks for the speedy reply.
#730
Quoted: 608 Post(s)
Liked 352 Times
Took a trip to Vancouver from Toronto and brought my Brompton. First time using the B & W hard shell case. The photo is at the Olympic flame that was lit during the winter Olympics in 2010. Did lots of riding around Stanley Park and surrounding area.
#732
Quoted: 3462 Post(s)
Liked 1,468 Times
Airnimal Joey in Big Bend National Park, Texas
And in the motel room
#733
besides the pressure differences, i can feel rotational.differences between 406 and 451. 406 accelerates quicker than but does not retain momentum as well as 451. i wonder how 520, a bigger difference between 451 than between 451 and 406, and closer to 559, rides...
#734
Liked 1,468 Times
wheels are ISO520?
Handling. The handling is quite good. Compared to my 26 inch (559) bikes, the steering is lighter, but that might be from a different amount of trail or it might be from less rotational inertia. As far as momentum accelerating or decelerating, that bike is lighter than my 26 inch bikes, so I am not sure how much of the difference in handling is from rotational mass or how much from bike weight.
When I bought that bike frame and built it up, that model with 24 inch wheels was advertised as being a folder that handled as good as a full size regular bike. I like the handling of it, I do not find that the smaller wheel size makes the ride rougher. On that trip in Texas, many of the paved roads were quite rough, you can see in the photo how rough the pavement is. On the first day I had front tire pressure in the high 50s (psi) and the ride was rather rough on my hands but the second day I dropped my front tire pressure to the low 40s and that rode much better.
The tall seat post and seatpost extension means that there is a lot of fore and aft flex that you do not feel on a normal road bike. That bothered me a lot when I first built up the bike, but after riding it for a while I no longer notice it. It now feels like a normal full size road bike to me.
On that trip in Texas, that was a van supported bike trip for a week. The van hauled our camping gear for us and all the cooking gear. There were a dozen riders, I had the only folding bike. The other bikes were a mix of road, cyclocross, gravel and touring bikes. All had drop bars, no mountain bikes in the group. I think my folder handled as well as the other bikes, speed wise it was probably as fast as I would have been on a full size 559 bike with the same tire width of 1.5 (40mm).
I have owned that bike for years, but have not ridden it very much. I wanted to try it for an extended trip to see how it worked out. It exceeded my expectations. I am not sure if I will put racks and panniers on it for a camping trip or not, but I would not rule that out if I could keep my load relatively light. But I have full size touring bikes, so if I was to use that on a camping trip there would have to be a reason to use that particular bike over the others.
As folders go, that is a large bike. To pack that into a case that does not exceed airline luggage size criteria takes a lot of work. To fit it in my S&S case (26 X 26 X 10 inches), I have to pull the fork out of it, crank arms off, etc. It takes about as much work to pack for airline travel as my S&S coupled bike.
#735
#736
Quoted: 232 Post(s)
Liked 146 Times
Its certainly a bike that perks my interest being in the 20" foldable package, being able to take a wide range of narrow and wide tires as well as a suspension if I decide to do rougher MTB type trails overseas.
But as you know, houses in SGP are not big and I already have a few bikes.
#737
...it is the cheap stuff you can find dozens on aliexpress. i dont recommend! the paint finish is great, the headset cone seat and outer axle nut seats i had to mill over to make it work. compared to the bombproof full carbon fork of my Java Air it appears like a joke, absurdly lightweight and fragile, but i ran down 15m stairs with it accidentally (4:30am half sleeping on my way to work, thinking i am on my 29 MTB) on it with my 90+ kilos and it didnt break.
#740
My 2nd trip with the Airnimal was to Houston. Great bike paths this was in front of the Houston zoo.
#741
Bikes: Tyrell CSI, Dahon Mu LT11, Doppelganger Aurora 219
Quoted: 150 Post(s)
Thanks. I had it built to my exact specs, every single part is the absolute best I could find to combine performance/weight/style from the titanium QRs to the carbon Ergon bar ends. Total cost was somewhere over $5000 usd.
My excuse for spending so much is that its like my car, I will use it to go everywhere. The trouble with that is that I am afraid to park it at the train station while at work, you cant lock your bike properly in Japan and the bike racks damage your wheels. So now I am thinking ill just keep riding my dahon ;( ;(
#744
Quoted: 232 Post(s)
Liked 146 Times
Wow! Beautiful bike.
Despite the low crime rate, I did suffer the lost of my cousin's market bike in Tokyo, even though its supposed to be a rare occurrence.
So I don't think locking it outside is a good idea.
I have see decent looking road bikes locked on the fence outside the Asakusa area though.
#747
Bikes: Santana Sovereign Tandem, Five Rings Carbon, Lemond Alpe d'Huez, Miele Latina, Hercules Tourist, Mercian Super Tourist Tandem, Birdy BD-1, Duell Solo, Jack Taylor Marathon Tandem, Raleigh RSW-16, DL-1, and Superbe
Quoted: 97 Post(s)
Liked 242 Times
Pre-weekend beer run... stiff aluminum frame a huge plus when towing a trailer full of beer!
#748
Boognishrising
Bikes: BCA folder circa 1988
BCA folder owner
Hi, I ran across a BCA Folder for sale a couple years ago and it caught my eye and I purchased it at what I feel was a fair price. I've searched all over the web looking for more of the BCA Folders and have had almost zero luck getting any information at all about it. In all my searching I only found one single picture of this bike , it was for sale on eBay but had sold by the time I found it so no information about the bike from the seller was available. So maybe you can help me a little. I just have a couple questions so here goes. As far as quality goes , how would rate the bike? Is it really as rare as it appears to be? Does it have any value or did I waste my money? Thanks, I'll try to figure out how to attach a photo of the bike to this.
