Helix Update?
#776
Señor Mambo
Bikes: TST roadie, Cannondale CAAD 3, Surly Karate Stokemonkey Leap, Tern Cargo Node, Helix Alfine; 36er and 29er Triton Unicycles; a couple Bike Fridays; one Brompton; RadPower Radburro
Quoted: 54 Post(s)
Liked 28 Times
Okay, let me start by saying that I would've rather much preferred to keep things internal but after reading about the possible suspicions on the test bike, I feel that this needed to come out for comparison.
That's the only photo that I'm aware of for the test bike update, helixhelix. I wonder if anyone here with Photoshop skillz can help out.
Peter already stated months ago that internal cable routing was too hard, hence all cable routing will be external.
You’re right though: shifter cable seems missing.
#777
Señor Mambo
Quoted: 54 Post(s)
Liked 28 Times
#778
Quoted: 17 Post(s)
Possibly because it's the single speed model? But then why have that tensioner there...unless it's required to keep the chain from hanging loose in the folded position.
Nah, don't kill 'em. Maybe not at $2K but B's have their place in the ecosystem. For example, I love the "shopping cart" mode which Helix will be incapable of.
#779
Señor Mambo
Quoted: 54 Post(s)
Liked 28 Times
#780
Palmer
Quoted: 1670 Post(s)
Liked 1,825 Times
#781
Quoted: 29 Post(s)
I still have my suspicions. It might just very well be my own little world with my own made up demons.
#783
Quoted: 17 Post(s)
...I still am. I'm still up in the air about the need for a studio-like test bike. More realistic would've been a test bike with a few grease spots on it, attached to a work stand, with a half-eaten sandwich and some empty beer bottles on the work bench....with my own made up demons.
A careful studio photo means the bike used had been ready for some time before which would put into question the timing of the announcement if only to purposely coincide with the holiday season cheer. If indeed there is a facade, the test bike wasn't quite ready. It may have been "close enough" to provide good news.
Further in that line of reasoning, if one takes the bother to get a studio portrait of a for all intent and purposes production-ready build, test completion notwithstanding, why not all configurations and numerous angles, then put it up on the public website for all the world to see including the pre-orderers in order to put them at ease, and generate even more fervent interest among the undecided. Believe me, as an internet software professional, it takes no more than a couple minute to set up FTP (far less if the FTP software is preconfigured with settings for the remote web server) and a few seconds additional to upload even high res photos at speeds common nowadays.
#784
Señor Mambo
Quoted: 54 Post(s)
Liked 28 Times
One of the biggest gripes right now on the backer board is how ugly the seatpost quick-release lever is, which is true.
#785
Señor Mambo
Quoted: 54 Post(s)
Liked 28 Times
#789
Señor Mambo
Quoted: 54 Post(s)
Liked 28 Times
#791
Quoted: 10 Post(s)
Why do you folks like titanium so much? My favorite tubing is 747 triple butted steel. Titanium is *nasty*, like aluminum. It feels shardy and tearing and full of slivers. You have to actually work with the material with tools to get it.
Do you really think you are going to out live the rust? Or do you just like the gunmetal steel aesthetic?
#792
Widely Despised
The joys of titanium.....
- That wonderful color of bare metal...like nickel or stainless
- Lighter weight than stainless.
- No paint to chip
- No worries about fragility, as with carbon fiber
- No corrosion. (Salt is all over the roads here.)
- High strength + low elastic modulus = Lots'o energy absorption without permanent deformation.
- Retains properties at high temperatures.
I had a Dahon disintegrate in a truck fire.
All aluminium became puddles, & the steel turned orange with rust.
At least titanium frames & components would survive.
I know it's nasty to machine & weld.
(A friend ruins tooling machining massive ingots for rolling mills.)
But that makes it feel exotic & a wee bit sinful....a geekworthy illicit pleasure.
- No paint to chip
#793
Why do I like titanium so much?
My Indy Fab Crown Jewel in ti is easily the smoothest ride I've ever owned, and I have two other steel Crown Jewels to compare. On smooth pavement, I get that riding on glass feeling with the ti. On rougher surfaces like exposed aggregate, if steel frames give a rumble, ti gives more of a buzz sensation, like the frequency of the vibration is being shifted into a less offensive and higher spectrum. Neither of the steel bikes gets anywhere near that - not that they're bad rides, they're just not in the same league. So yeah, I like that.
#794
Quoted: 17 Post(s)
Helix bikes are welded inside an inert vacuum chamber to mitigate problems working with titanium. What is puzzling though is there cannot possibly be inert vacuum chambers large enough to accommodate anything the size of $100M+ fighter jet aircraft.That means either (a) inert vacuum chambers are not really necessary to effectively work with titanium, or (b) the most sophisticated fighter jets have structural integrity problems. Neither observations are consistent with all the type about sub-sonic titanium bicycles.
Nearly 6 am Jan 1...awggh... exhausted but just can't fall asleep.
#795
Widely Despised
(TI is used more extensively in the SR-71, which had friction heated wings at mach 3 speeds. Many assemblies were loose at room temperature cuz operating dimensions were only achieved at much higher in-flight temps. But one can make big things with rivets, which can make very strong assemblies. And gas shielded welding works better with simply shaped parts.)
#796
Quoted: 29 Post(s)
Quoted: 104 Post(s)
Liked 8 Times
Btw, the 'pro photo' just requires a large sheet of black paper and appropriate lighting.
#798
Bikes: Montague Swissbike X50
Quoted: 9 Post(s)
The SR71 skin was held together w/ rivets and screws and mechanical fasteners, not welded.
https://www.totalmateria.com/Article28.htm
titanium alloys can be welded by procedures and equipment used in welding austenitic stainless steel and aluminum. Because of the high reactivity of titanium and titanium alloys at temperatures above 550°C, additional precautions must be applied to shield the weldment from contact with air.
#799
Quoted: 29 Post(s)
Yeah, it could be dubious that the piccie has some Photoshope-ing going on.
So how about a non-pro photo? NO paper and inappropriate lighting might result with the same reaction. "Dear Peter, there might be some doubt that the test bike is real. In two weeks, would you be a love and switch the light on for the next test bike photo?"
One POSITIVE 'to what end' fabrication is that we'd all have our bikes right now!
#800
In case some wonder why people question the authenticity of the posted pictures, here are some examples of how good computer renderings can be in terms of realism.
Both images were redered using a popular software called KeyShot .
